Old 10-23-2008, 11:19 PM   #1
Rekt
Rekt's Avatar
Drives: Z34 370Z
Concerned about handling...
So, does a 3800 lb SS as an auto-x competitor sound feasible?
Discuss.
Rekt is offline   Reply With Quote
Old 10-23-2008, 11:21 PM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
Does a 3800 lbs BMW M3 sound feasible as a auto cross car?
headpunter is offline   Reply With Quote
Old 10-23-2008, 11:35 PM   #3
andyrew
andyrew's Avatar
Drives: Audi A4 STG3, Porsche 914 v8
Anything is feasible as an autox car. I have a 3600lb Audi a4 w/ quattro that smokes most street tire cars (I generally run in the porsche club, and I am on the top of the street tire cars).
I was able to do 1.04 continuous G's on bridgestone RE01-R street tires on a skidpad (with no real setup of the suspension)
With the right tires and a properly done suspension the camaro will be just fine.
The problem it will have is transitions such as slaloms. Being such a heavy car it will need a fairly heavy suspension in order to keep the weight transfer and turn in right.
Some nice aftermarket lowering and stiffening springs will probably do the car justice, and most likely it will be tuned to have understeer so a bigger rear sway bar will probably also make a huge difference.
I am an avid autox'er and I plan on autoxing the Camaro (assuming thats what I get..)
Its more about driver ability than the cars.. Assuming the car is well balanced, has a decent amount of grip and has good turn in, any car can do very well at an autox.
andyrew is offline   Reply With Quote
Old 10-23-2008, 11:54 PM   #4
Rekt
Rekt's Avatar
Drives: Z34 370Z
Never seen one, unless you have been to meets with one around?
Old 10-23-2008, 11:55 PM   #5
Rekt
Rekt's Avatar
Drives: Z34 370Z
Sounds good.
I hope that not only does the car carry its weight properly, but allows the driver to feel more connected. That in itself is extremely important.
Old 10-23-2008, 11:55 PM   #6
headpunter
headpunter's Avatar
Drives: Man
well the BMW M3 is known for good handling, and it weighs in at 3800lbs...
Old 10-24-2008, 12:18 AM   #7
andyrew
andyrew's Avatar
Well the M3 is a performance beast and everything was tuned for road racing so I would assume that car would handle fine.
The Camaro is a moneymaker for GM, where GM is more concerned with numbers for the general public (however it would be great if they made a "track package" with tuned suspension for road racing, I hear that ford is going to do this). One would expect the camaro to be more of a compromise for comfort than a "racing tuned suspension".
Old 10-24-2008, 01:08 AM   #8
karr1008
Supercharging
karr1008's Avatar
Drives: 20XX Camaro SS
I don't see why this Camaro can't do well in AutoX but as Andyrew said, It's more about driver ability than the cars. Coming from an STi, at 3350 lbs. fully nannied and AWD it will be interesting to see how I will do with a powerfull brute RWD.
After trying the stock suspension for a while, I plan on beefier front and/or rear swaybars depending on how bad it needs them, better springs or later some coil overs and stickier tires and some lighter aftermarket wheels for the track.
Does anybody else has any other options in mind?
karr1008 is offline   Reply With Quote
Old 10-24-2008, 01:16 AM   #9
andyrew
andyrew's Avatar
I agree with your plan of upgrades 100%.
Also if for some reason I get the v6 i'll also go with a brake upgrade if the car see's track days.
Old 10-24-2008, 08:47 AM   #10
TomServo
Drives: 2007 Z06
On a small technical course, don't be surprised if Miata's and Mini's post faster lap times. Since you aren't on the track at the same time it's only numbers posted on a white board. But if you were actually on the track together I'm sure there will be some frustration with these light weight cars able to out corner/brake you.
I learned this first hand with my Z51 vette. That's why I stopped attending (just to chew up tires and brakes) and now participate in HSDE's like the F-Body Association Road America weekends. There a car like the vette and even Mustang GT500 etc can out power these cars and post considerably faster "lap times".
TomServo is offline   Reply With Quote
Old 10-24-2008, 11:30 AM   #11
andyrew
andyrew's Avatar
You cant compare a light weight properly setup miata to a stock vette on a tight autox course... You should be comparing yourself to other cars in A stock and SS (super stock) (not familiar with the Z51 package).
However once you get a taste of a track day with a highly capable high hp car you really dont have the lust for an autox anymore.. Thats like a hamburger to a steak... Sure the hamburger is good but a steak is just that much more enjoyable..
Autox is a very good way to hone your driving skills and quicken your reflexes. Same as (dare I say it) Drifting; drifting teaches you how to control your car PAST the limit; if your autox sanctioning body approves of it, try drifting around a autox course. However you want to have camera's setup so you dont waste the fun you had destroying your tires
Old 10-24-2008, 11:39 AM   #12
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Take about 100 lbs off and you would be right ..
BTW .. everyone . .stock for stock .. don't expect the camaro to hang w/ the M3 in the twisties .. M3 is in a different league ..
Crowley
Crowley is offline   Reply With Quote
Old 10-24-2008, 12:15 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
The FE3 package is GM's top-end RWD suspention platform before you get into car-specific setups like the Corvette and CTS-V. This will be found underpinning the SS. FE2 is a step lower, and is found on the V6 models. During recent test-drives, among various praise, one reviewer called the V6 car "The American G37". Now...think better than that, there's your SS handling. I'm 100% confident it's more race-tuned suspension than compromising for comfort. (In fact, they even said the V6 car made the SRT8 feel "plodding") Bottom line: Handling will be exceptional. But don't take my word for it, get out and drive one in a few months!
Old 10-25-2008, 03:35 AM   #14
andyrew
andyrew's Avatar
I just test drove the G8 GT, and I am confident that the handling of the camaro SS will be JUST fine for autox. It was very well proportioned and felt very stable.
In fact Its on my list right under the Camaro right now. In fact if I cant fit 4 adults in the camaro, im getting a slightly used G8... That car was a blast and a bargain...
Handling SdustinK 5th Gen Camaro SS LS LT General Discussions 10 10-17-2008 02:07 PM
Everyone talks about horsepower, but what about handling? exilio 5th Gen Camaro SS LS LT General Discussions 30 10-15-2008 04:06 PM
Concerned GoldFire Camaro Price | Ordering | Tracking | Dealers Discussions 1 10-15-2008 06:48 AM
g8 handling vs camaro mega 5th Gen Camaro SS LS LT General Discussions 37 08-02-2008 07:39 AM
Handling? mprhead5 Wheels and Tires Talk Sponsored by The Tire Rack 34 12-29-2007 07:30 AM
