Old 10-24-2008, 01:01 AM   #1
a6pk2go
a6pk2go's Avatar
Drives: ...
Gear for rear end
Does anyone know if they will be offering a 373 rear end gear? Myself I think it is a really good road gear. My brother used to have a 488 in his Chevelle and it would be cranking some serious RPM's going about 55 mph. That would be good on the low end but I want a gear that will do good on both ends. I have search this forum and I hope it can come in something besides the airplane gear I saw earlier.
a6pk2go is offline   Reply With Quote
Old 10-24-2008, 02:13 AM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
they will be offering 3.73's in the second model year.
headpunter is offline   Reply With Quote
Old 10-26-2008, 04:37 AM   #3
a6pk2go
a6pk2go's Avatar
Drives: ...
Thanks Headpunter
Do you know the rear gear that is going to be in the 2010?
Old 10-26-2008, 08:43 AM   #4
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
^ 3.42
Badger is offline   Reply With Quote
Old 10-26-2008, 01:07 PM   #5
a6pk2go
a6pk2go's Avatar
Drives: ...
I probably can't wait.
Old 10-26-2008, 01:09 PM   #6
a6pk2go
a6pk2go's Avatar
Drives: ...
Originally Posted by Badger View Post
^ 3.42
Thanks
Old 10-26-2008, 07:04 PM   #7
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
look under wiki, drivertrain, trans, says final drive for auto in 3.27, manul 3.45.
2010 2SS/RS, OBX l/t headers, with high flow cats, MBRP full 3" exhaust, modified air intake (CAI), Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidampr 25% upd, MGR shifter, VTC, and tune by Jannetty Racing. MRR M228 rims, phantom grill, vinyl wrapped hood and rear spoiler.
tbss1 is offline   Reply With Quote
Old 10-28-2008, 08:07 PM   #8
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
For those of us that wanna swap the gears out on the 2010 car for 3.73;s, what would be a good brand to buy?
logan1080 is offline   Reply With Quote
Old 10-28-2008, 08:48 PM   #9
Dom
Drives: 2000 Z28
Why do you guys want gears already? A6 is geared much higher then A4. You might end up over gearing.
2000 Z28 - current daily
1996 Camaro 3.8 - previous daily
Dom is offline   Reply With Quote
Old 10-28-2008, 09:10 PM   #10
10redrocket
Drives: 2SS Camaro LS3
A6 Ratios:
first 4:03
second 2:36
third 1:53
fourth 1:15
fifth 0:85
sixth 0:67
Rear 3:27
You can do the math to figure RPM and how it changes for different rear gears.
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block
67 Chevelle SS Big Block
05 Cobalt SS Supercharged
07 Cobalt SS Supercharged
10 Camaro 2SS LS3
Soon: 18 Camaro 2SS 1LE
10redrocket is offline   Reply With Quote
Old 10-28-2008, 09:38 PM   #11
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
If somebody wanted to swap...What would they want to look for? Would it be the same gears as a corvette? maybe a GTO? I don't think I will change gears as I am going to build a high horsepower forced induction car, and too high of rpms on th ehighway will be BAD!!!! But I know that is what some people reading this thread want to know.
ZZcamaro is offline   Reply With Quote
Old 10-28-2008, 10:29 PM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm going to assume you're thinking staightline racing -
Well, if you go too short in the rear, with a lot of power, you could be just wasting a lot of time spinning your tires unless you have a great set of meats and your suspension is dialed-in. Off the line, unless you can get good enough weight transfer, all that gear is going to be more harmful than good. I know there are gear calculators out there, so it'd be nice to see what tranny gear would be optimal to match the rear gear to, so depending on if you're running an 1/8th mile, or the 1320, you could set your car up to be in the powerband as you go through the line. I think GMHTP was running their stock G8 GT through the traps just after shifting into 4th gear, so maybe 4.30s would get you close. I think, depending on your tranny, and subsequent engine, you're going to have to consider redline and fuel shut-off too because it won't do any good to expect to run your L99 to 6500 RPMs when it redlines at 6000 (I don't recall if that's the correct redline..) More-or-less, you should probably put together a plan on what you plan on running, power-wise, get an idea of your powerband, and then calculate the gear you'll be in going through the traps, and adjust your ring and pinion to that number.
JM.02
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-04-2010, 08:36 PM   #13
5thdan
5thdan
5thdan's Avatar
Drives: 2010 Camaro 2LT RS
FHJHQJBFWEGDFJWEQJKenfjqfjqdebjebJKBFCJHJWANFJJJJc dasddWHJBDQhjdnMEH
5thdan is offline   Reply With Quote
Old 08-04-2010, 09:03 PM   #14
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Well said for your second post here!
CamaroFTW is offline   Reply With Quote
Gear choices? ZZcamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 10-15-2008 03:22 PM
Fifth Gear - Dodge Challenger SRT8 ihc95 General Automotive + Other Cars Discussion 27 10-01-2008 04:57 PM
blew second gear. carguy_z28 4th Generation Camaros 5 09-18-2008 12:14 AM
Forged btm end for the SS? Cessna510 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 07-22-2008 11:44 PM
