Old 06-08-2010, 04:19 PM   #1
Nitrosniffer
40 Years Later
Drives: 2010 2SS Camaro w/ RS - CGM
TR6060 Max Torque
I was going through the wiki on this site, and I saw that the TR6060 was rated for a maximum of 430 ft.lbs (gearbox) of torque. More research on the TR6060 states that it is rated for a maximum of 600 ft.lbs of torque.
Is there a problem with the wiki, is the clutch rating acting as a limiter, or are there some weaker components in the 2010 Camaro version?
Obviously, this is a cause for concern, because you should avoid out-torquing your transmission/clutch, and the way the wiki is written, that doesn't leave a lot of room for improvement.
Nitrosniffer is offline   Reply With Quote
Old 06-08-2010, 04:28 PM   #2
SonnyakaPig
Drives: C63 P31
The 430 number seems very low. For the 6L80 the gearbox torque number is a lot higher than the max engine torque. But, like you said, perhaps the OEM clutch is a limiter. There's a formula I believe for the 6L80's that calculates gearbox torque from max engine torque. I think gearbox is 1.5 times max engine torque. I could be wrong. I'm not sure if there is a similar formula for the M6.
It seems that once M6 owners buy the new 1000 rwhp twin disc clutches, their cars can handle 500-650 rwhp no problem.
As an A6 owner, I'm obviously jealous.
SonnyakaPig is offline   Reply With Quote
Old 06-08-2010, 07:56 PM   #3
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
The torque rating for the TR6060 is NOT the maximum torque that the transmission can take before something breaks. It just means that it has been rated at 430 ft-lbs. to live for the life of the vehicle with durability testing run at 430 ft-lbs. A good rule of thumb in automotive design is that a safety factor of 3 is usually what most components are designed to in automotive applications.
Kenji is offline   Reply With Quote
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
Interesting article on LSA powered 2010 Camaro Sax1031 Camaro ZL1 Forum - ZL1 Specific Topics 43 05-26-2010 08:30 PM
2011 Mustang Info (Keep all threads here) RealQuickCamaro General Automotive + Other Cars Discussion 2648 04-15-2010 09:09 PM
Torque Converters Explained tbyrne V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 01-07-2010 01:38 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 01:36 PM
