BORLA
Old 06-09-2010, 01:49 AM   #1
firefighterEMT33
firefighterEMT33's Avatar
Drives: 2010 IBM 2SS/RS
High Pitched Noise
I've had my SS/RS M6 for about a month and a half now and whenever I get up to about 70 MPH I hear a high pitched noise when in 5th or 6th gear. It's hard to tell if it makes the noise in 3rd or 4th because the engine noise drowns it out. I thought it was wind at first, but when I push the clutch in or go down a hill it goes away just about instantly.
It definitely seems to be speed dependent and not RPM dependent as the motor is only turning about 1700 RPM in 6th gear at 70 MPH, and no other gear makes this noise at that RPM.
I couldn't find anything here on the forums about this yet and was wondering if anybody was having the same issue or knows of somebody who is.
Any help is greatly appreciated!!
IBM 2SS/RS, M6, Polished Wheels, 3M Clear Bra, 27% Windows, CAGS Eliminator, Barton STS
Upcoming Mods: Cold Air Inductions CAI, Kooks 1 7/8" LTH, and 3" Exhaust, Tune.
1100 Order accepted at dealer: 3/15/2010 - NVTZ1X
3300 Scheduled For Production: 3/17/2010 TPW 4/5/2010
3800 Produced: 4/7/2010 2G1FT1EW3A9208281
5000 Delivered To The Dealer: 4/21/2010
6000 Delivered To Customer: 4/23/2010
firefighterEMT33 is offline   Reply With Quote
Old 06-09-2010, 04:34 AM   #2
DaveT
DaveT's Avatar
Drives: 2010 2SS CGM LS3
Your GF????
JK.....I hope you figure it out.
DaveT is offline   Reply With Quote
Old 06-09-2010, 07:41 AM   #3
Scrapppy666
Scrapppy666's Avatar
Drives: 2010 2SS/RS M6 Black/Black
Brother in law had a problem like this in his truck, anything over 70 there was an extremely high pitched noise (almost out of normal range of hearing) coming from the transmission area. Dealer told him they couldn't do anything about it because there was no where they could legally test 70mph around here.
Pittsburgh Automotive Photography
Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake
Scrapppy666 is offline   Reply With Quote
Old 06-09-2010, 08:55 AM   #4
firefighterEMT33
Originally Posted by DaveT View Post
Your GF????
HA! She knows better than to speak while the Camaro is speaking...
Old 06-09-2010, 08:58 AM   #5
firefighterEMT33
That's what I'm afraid of. Closest 70 MPH zone is like 50 miles away. Eh... If it's something grinding, it'll go away sooner or later. That or it'll destroy that frequency in my hearing range and won't be a problem anymore.
Old 06-09-2010, 09:51 AM   #6
wylde1
I am the Stig
wylde1's Avatar
Drives: Black w/ IOM stripe 1SS
WIN!
2010 Camaro - 1SS, Black w/ Orange stripes
wylde1 is offline   Reply With Quote
Old 06-09-2010, 12:11 PM   #7
JSC81
JSC81's Avatar
Drives: 2010 1SS/RS M6
I had a similiar noise.. It had nothing to do with what gear or whether the clutch was pressed in or not. It was from 65ish-75ish mph. It was found to be the transmission. Service tech said it was 5th or 6th gear resonating. They tried to rebuild the transmission at 1st but you cant order all the parts for them yet. Sooo new transmission installed no noise.
Hope that helps~! Goodluck.
JSC81 is offline   Reply With Quote
Old 06-09-2010, 02:26 PM   #8
firefighterEMT33
Sounds exactly like it! The research I did pretty much confirms it. The 2004 Cadillac CTS had this problem and they used the T56 transmission in those. We'll see what the dealership says when I make a phone call...
Old 06-09-2010, 03:21 PM   #9
JSC81
JSC81's Avatar
I took the service manager for a spin and had no idea what was causing it. As of now GM still has no clue as to why the transmissions are doing it. My service rep said my car was 1 of 2 cars that have been reported with the same issue. It took about two weeks once I dropped it off to get it back as well. There are protocals that must be followed from service departments. Pretty much although they know all the parts for a rebuild arent orderable(if thats a word) lol.. They still have to order them and wait a predetermined amount of time before they call and request a new transmission due to the parts request being over a certain period of time. If your service rep act stupid you can hit me up and I'll send you the contact information for mine so he can pick his brain.
Old 06-09-2010, 03:23 PM   #10
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
Take them to the track.
Shuffler is offline   Reply With Quote
Old 10-05-2017, 07:46 PM   #11
keith.wilkinson.10
keith.wilkinson.10's Avatar
Drives: 2010 2SS/RS IBM
Bump... any word on this I think I have the same issue.
Sent from my SM-G955U using Tapatalk
keith.wilkinson.10 is offline   Reply With Quote
Old 10-05-2017, 08:10 PM   #12
Spec
Spec's Avatar
Drives: 2010 Camaro 1SS LS3
Not coming from the differential? Haven't experienced this before, but the gear may need a flush? How many miles guys?
Spec is offline   Reply With Quote
Old 10-05-2017, 08:20 PM   #13
keith.wilkinson.10
When I noticed mine I changed fluid, but didn't go away It's only in 5th or 6th between 70-80mph on stock differential.
Old 10-05-2017, 08:29 PM   #14
Spec
Spec's Avatar
Check for alignment, and while you're at it, have them thoroughly check and torque your suspension to specs. Hard to find a good shop capable, but they may find something out of the ordinary with a good check. Rule out the wheels/tires/suspension if you can... that's fairly cheap. If you've already ruled out the differential, then it may indeed be your transmission.
Need help with Strut noise FFPM73 Suspension / Brakes / Chassis 15 04-19-2015 03:56 PM
Noise from Air Vents 1baer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 21 02-13-2012 08:11 AM
SPEC Clutch/Flywheel Upgrades | Single & Twin Disc!! AJ@ECSMotorsports Transmission / Driveline 21 11-13-2010 04:58 PM
HID Headlamp Noise? Taz_FL Cosmetics and Lighting Modification Discussions 3 03-26-2010 01:08 AM
Noise from Air Vents 1baer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 03-19-2010 09:19 AM
