BeckyD @ James Martin Chevy
Old 06-09-2010, 09:31 AM   #1
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
JANNETTY RACING STALL CONVERTERS
Jannetty Racing, in cooperation with Pro Torque converters of NY, is now offering a line of stall converters to suite your particular needs.
We have converters for Stock NA, Modified NA, NOS applications, Supercharged applications both Positive Displacement and Centrifugal configurations.
Torque converters can NOT be sold as a one size fits all, because Stall Speed is in DIRECT Relation to INPUT Torque.
For example a 10 inch converter advertised as a 3200 stall should do just that on a stock NA application it was built for, put that same converter on a PD supercharged car and it may Stall at 5000 RPM, put that same converter on a Centrifugal supercharged car and it may stall 4000 RPM.
And if you put that same converter on a V6 it May only Stall 2000 RPM.
Torque Converters are a Science, I have been Working Very Closely with Pro Torque for 12 years now and He has always been able to meet my expectations with quality, Durability, and What I want out of a Converter.
Driveability is very important, Stall Speed Affects Shift Quality, higher stall speeds Can make shifts feel Very Soft.
Our converters will Flash to a specified Stall speed, but then couple and give Stock like Driveability, and good clean shifts.
With the advent of these completely electronic controlled transmissions they are very sensitive to Torque converter changes, If the Converter is Not designed Properly it could set check engine lights, as the computer sees the difference in input VS Output speed as Transmission Slippage.
We have a 12 inch converters for each application that can Flash 2800 RPM and Drive like Stock otherwise.
Call for a consultation to get the Right Torque converter for your application.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 06-09-2010, 11:17 AM   #2
Supercharged SS
Drives: 2010 Camaro
Ted, what about a trans cooler? Would this be ok without one? What about added stress and strain on the trans, would the converter substaintially shorten the lifespan?
Thank you
Old 06-09-2010, 11:24 AM   #3
Supercharged SS
Drives: 2010 Camaro
I need to see 10.70's!!!! Is that converter on it's way gonna do it? If you say so I'll be by to pay for it today. You haven't been wrong yet.
Old 06-09-2010, 11:44 AM   #4
toehead93
Drives: 2014 2SS/1LE
IMO a converter will get you the .2 you're looking for.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 06-09-2010, 12:08 PM   #5
JANNETTYRACING
Thank you
The torque converter should not put any added stress to the transmission than it currently sees due to your very powerful set up.
In traffic you could see less transmission temps due to the looser calibration, the converter is locked most of the time and there is NO added Temp when Locked.
At the Track you may see a slight increase in transmission temps but I don't suspect it will become an Issue, it should still operate within normal parameters.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 06-09-2010, 12:11 PM   #6
JANNETTYRACING
ET is a Product of improving 60 ft times, your currently running 1.65, if you can go 1.50 by applying more power on launch it is worth 3 tenths on the other end.
The Torque converter I have in mind for your car will increase Torque application at launch by 200 Ft. lbs. or more.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 06-09-2010, 01:57 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Cool stuff!!!
Old 06-09-2010, 03:00 PM   #8
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
are these available for the manual V6's?
Old 06-12-2010, 11:10 AM   #9
Wikedwil
Co-founder of CDCNY
Wikedwil's Avatar
Drives: 2016 Camaro 2LT Hyper Blue
Seriously?
Wikedwil is offline   Reply With Quote
Old 06-12-2010, 12:09 PM   #10
Xtreme Innovations & Fab
Drives: 2010 Camaro
Converters are used with automatic transmissions
Xtreme Innovations & Fab is offline   Reply With Quote
Old 06-15-2010, 05:59 PM   #11
PoorMansCamaro
Drives: Really Slow
aren't stall converters the same as torque converters?
Old 06-15-2010, 06:05 PM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Stall converters are short for higher stall speed torque converters - they serve the same purpose, but one is performance oriented, simply put
Old 06-15-2010, 06:09 PM   #13
PoorMansCamaro
Drives: Really Slow
lol, you know what, i was thinking torque dampeners.
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
Jannetty Racing Track Rental May 28th Friday JANNETTYRACING USA - NY / NJ / PA 11 05-27-2010 05:05 PM
Coolingmist welcomes Jannetty Racing !! coolingmist Forced Induction - V8 25 05-13-2010 07:36 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 01:36 PM
Torque Converters Milk 1027 Wiki 0 08-12-2009 07:31 PM
