JUICEDMOTORSPORTS
Old 11-05-2010, 06:47 AM   #827
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
Is it finally dyno day ?!?!?!?!?
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Old 11-05-2010, 09:40 AM   #828
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Originally Posted by 4thGen427CI View Post
So Bruce here is my prediction of your Camaro on the dyno...
P.S. Lots of babies?? Like this?
Well, the detailed dyno testing is on an engine dyno, not a chassis dyno. Doing 50 - 100 pulls in the 1,5xx+ range is not something you want to do on a chassis dyno.
...and you are pretty scary with the baby picture. Our Director of Engineering here is 35 and has 12, yes twelve kids !!!
I hope so. I am trying to find out.
Old 11-05-2010, 12:05 PM   #829
4thGen427CI
5th Gen
4thGen427CI's Avatar
Drives: 10 SS
I grew up with a family of twelve! Not all blood related... mostly step siblings but still, I don't know how parents do it! Im gonna tell the future wife, its done at three!
4thGen427CI is offline   Reply With Quote
Old 11-05-2010, 06:18 PM   #830
Mr Twisty
Mr Twisty's Avatar
I got a visual of King Kong chained up in the theatre... everything was fine... then he got PISSED!
.....snapped those chains like butter
You should call your car King Kong
-- Benjamin Franklin
Old 11-05-2010, 06:28 PM   #831
Mr Twisty
Mr Twisty's Avatar
This car is gonna be SO FRIKKIN COOL!!!
I'm excited for you to get it back, won't be long now
Old 11-05-2010, 06:54 PM   #832
garcmol
garcmol's Avatar
Originally I wanted this car to look 100% stock, idle stock, get 25 mpg and pump out 1000 hp, but at this stage it was decided to kick it up a notch. So you have now seen that heads were changed and upgraded for considerably higher flow capacity. Something about a motor making so much power should not idle like it's electric, so the decision was made to chuck the hydraulic roller LS7 cam and run a solid roller with a NASCAR valvetrain. So the heads are now topped with nascar springs and a full T&D shaft roller rocker setup. This setup has proven to be bulletproof and should last for 100,000 miles with no problem.
Still guessing 1952. NASCAR = 700+, normally aspirated.....hmmmmm;
Old 11-05-2010, 07:27 PM   #833
Mr Twisty
Mr Twisty's Avatar
It's not a big cube motor tho... I'm amazed he can use 'dependable' and '1500+' in the same sentence
Old 11-05-2010, 08:47 PM   #834
GFORCE1320
Drives: 05 GTO
Look what I got going together for you Bruce
The 9" pumpkin from Moser with the 35 spline Wavetrac showed up today too.
GFORCE1320 is offline   Reply With Quote
Old 11-05-2010, 08:58 PM   #835
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2008 Sky Redline
Old 11-05-2010, 09:00 PM   #836
Mr Twisty
Mr Twisty's Avatar
Bulletproof! (literally!)
Old 11-05-2010, 09:01 PM   #837
WadeWilson
How U Doin?
WadeWilson's Avatar
Old 11-05-2010, 09:18 PM   #838
speedster
SST...
speedster's Avatar
Thanks guys... It is getting closer. Look at the post from GForce...
Old 11-05-2010, 09:24 PM   #839
speedster
SST...
speedster's Avatar
Well alright Chris !! The indestructible solution is almost done.
I am with you guys. The diff has been the achilles heel of this car and really had me worried until Chris discussed this solution for the SST. This was worth the wait. The last thing you want to do is blow a diff/axle under full power at the track...
Old 11-05-2010, 09:55 PM   #840
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
V I D E O...
V I D E O...
V I D E O...
engine psi > tire psi, f5....., holy crap!, horsepower, omgwtfbbqsaucepowa!!!, speedster, sst, turbo
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
Detroit News panel wants GM to build Camaro concept Tran 5th Gen Camaro SS LS LT General Discussions 12 03-15-2009 04:38 PM
