Old 06-11-2010, 02:57 PM   #1
obzidian
obzidian's Avatar
Drives: 98 camaro turbo
Weight Reduction?
Is there a list of mods specifically tailored to drop the weight out of these heavy 5th gens.?
Of course brallie batteries is a common mod and can drop about 10-15lbs.
Are there any companies making k-members, control arms, 2-piece rotors, Driveshaft, solid rear?
obzidian is offline   Reply With Quote
Old 06-11-2010, 03:06 PM   #2
Mr Twisty
Mr Twisty's Avatar
Factory mufflers are heavy...
Forged wheels ...
Here's an interesting weight savings idea. http://www.camaro5.com/forums/showthread.php?t=87589
-- Benjamin Franklin
Old 06-11-2010, 03:09 PM   #3
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
I was about to say the mufflers as well. or just kick out ur passengers and ride solo!
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 06-11-2010, 03:57 PM   #4
Xtreme Innovations & Fab
Drives: 2010 Camaro
Hi obzidian, We various ways to cut fat off the Gen 5 Camaro. I have tubular k-members, working on the rear tubular axle cradle, we are offering a straight axle conversion. If you have any question , give me a call.
Xtreme Innovations & Fab is offline   Reply With Quote
Old 06-11-2010, 03:59 PM   #5
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Forged wheels ...
Yep. Craig at Xtreme above makes good stuff...
Old 06-11-2010, 05:55 PM   #6
obzidian
obzidian's Avatar
Excellent... will check the site out.
My brother and pops both have 5th gens and I'm trying to convince them to build something to deal with those pesky 5.0's!
A.
EDIT: I remember you guys from camaro5fest. I was the lone Z06 in the sea of f-body's!
PM sent!
Old 06-12-2010, 07:43 PM   #7
JL88
JL88's Avatar
Drives: Black 2SS RS
How much weight savings from the tubular k-member?
Are they for sale yet?
JL88 is offline   Reply With Quote
Old 06-13-2010, 01:09 AM   #8
Drives: 2010 Camaro
Hi JL88, The K-members are 29lbs lighter and yes they are on the market already. I have so several units already. Thanks for the inquiry..
Old 06-13-2010, 01:38 AM   #9
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Racing Brake makes 2-piece brake rotors that are about 6 lbs lighter each than the stock ones (for the SS with Brembos):
http://forums.racingbrake.com/forumdisplay.php?f=6
A set of Pedder's Xa coilovers are 20 lbs lighter than the stock shocks and coils.
Replacing the factory exhaust with a 3" catback system should knock another 25-30 lbs off depending on what you get.
I'm trying to find an affordable 1-piece carbon fiber driveshaft; waiting on a couple of possibilites. That should save about 10-12 lbs of unsprung rotational weight.
Getting 2 or 3 piece forged rims in a 20 or 19" size can save about 6-10 lbs per corner.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 06-13-2010, 08:32 AM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
In addition to what was already mentioned, several companies make carbon fiber body panels. The factory seats are pretty heavy so switching to some Sparco Evos or some other racing seat would help. GForce is coming out with aluminum and carbon fiber one-piece driveshafts which will save you a few pounds.
Old 06-13-2010, 11:58 AM   #11
Doc
Doc's Avatar
The factory driveshaft is already aluminum and weighs about 18 lbs but it's a 2-piece. A 1-piece carbon fiber would not only reduce unsprung rotational weight, but improve efficiency which would see a bit more horsepower getting to the rear wheels.
1SS/RS LS3 M6 IBM
Old 06-13-2010, 06:22 PM   #12
nl12
Drives: Unicycle
Depends how extreme you want to go, remove wipers/sprayer system use rainx instead, remove airbag system, use racing seats and harness, racing steering wheel, remove hood blanket, remove engine cover
nl12 is offline   Reply With Quote
Old 06-22-2010, 06:31 PM   #13
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
ARH headers will save you about 25 pounds. Pedders coilovers about 25 pounds.
Old 06-22-2010, 08:21 PM   #14
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Heck I saved 44 pounds on exhaust alone! Without the headers!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Weight reduction on camaro? LDGn63 5th Gen Camaro SS LS LT General Discussions 201 02-11-2013 09:13 PM
New Brembo Brake Upgrade for 2010+ Chevrolet Camaro SS CarNutzCustomz Wheels and Tires Talk Sponsored by The Tire Rack 42 12-22-2011 05:58 PM
ANYONE WANNA START EXCERCISING/LOSING WEIGHT WITH ME? Matrix Off-topic Discussions 143 10-19-2010 04:51 AM
Great deal on 2-piece rotors Doc Suspension / Chassis / Brakes 90 11-28-2009 09:53 AM
weight loss CamaroSpike23 Off-topic Discussions 8 09-17-2009 08:16 PM
