Old 06-12-2010, 12:06 AM   #1
GQ4Life
Drives: 2010 Camaro SS LS3
will these BBS CH-R fit?
http://www.bbs.com/en/_downloads/bbs_ch-r_flyer_en.pdf
Front
20 x 9" offset 24.00mm
matt black
5x120
center bores- 09.31.149,09.31.313,09.31.291
Rear
20 x 10.5 offset 24.00mm
matt black
5x120.00
Center Bore - 09.31.149,09.31.313,09.31.291
quick fab up on car.. sorry did in 20sec
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 06-12-2010, 12:11 AM   #2
killinemsoftly
killinemsoftly's Avatar
Drives: Summit White L99 2SS Forgiato 22"
doubt it offset isn't right but nice ride by the way
White 2SS H&R Springs, Blacked out emblems and lights , black roof, Forgiato Martellato Custom Painted 22's
killinemsoftly is offline   Reply With Quote
Old 06-12-2010, 01:09 AM   #3
monstertodd
monstertodd's Avatar
The recommended fitment for the BBS CH-R on the Camaro SS is:
front:
Offset: 29mm Backspacing: 6.18" Bolt Pattern: 5-120
Rec. Tire Size:245/45-20
Weight: 28.2lbs.
rear:
Offset: 35mm Backspacing: 7.20" Bolt Pattern: 5-120
Rec. Tire Size:275/40-20
Weight: 28.8lbs.
But I'm sure there is probably some wiggle room with offset and backspacing. And I'm sure you could probably fit larger tires as well.
FYI, I got this info off of Tire Rack. They sell the fronts for $730 per wheel and the rears for $750 per wheel. These are the same wheels I want, but I want the bright silver finish instead of black.
Old 06-12-2010, 03:40 AM   #4
Dan@showstopper
Dan@showstopper's Avatar
I wanted these wheels till I saw the actual widths and the fact that they are cast wheels. I have another idea in mind now. I read somewhere on this site that the offset is wrong on tire rack and is actually a BMW wheel and now BBS has released the proper offset or the Camaro. Problem is they still only offer a 9" front and 10.5" rear which basically recommends stock size tire sizes.
BTW, they have already been installed on a Camaro
Dan@showstopper is offline   Reply With Quote
Old 06-12-2010, 05:14 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Sweeeet!
Old 06-12-2010, 06:11 AM   #6
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
A possible alternative for these wheels is the TSW Nurburgring's.
http://www.camaro5.com/forums/showthread.php?t=85896
They have basically the same wheel pattern. You can get them in 20x9.0 and 20x10.0. They're also very light weight
23 lbs (20x9.0) and 24 lbs (20x10.0).
Old 06-12-2010, 10:27 AM   #7
J@Wheelsboutique
J@Wheelsboutique's Avatar
Drives: SVT Ford Lightning
Send a message via AIM to J@Wheelsboutique
This looks fantastic!
J@Wheelsboutique is offline   Reply With Quote
Old 06-12-2010, 12:17 PM   #8
GQ4Life
thanxs thoase TSW are nice..
though the 305s suppose to be on a 10.5 rim but it might work.. usually some wiggle room..
reason I want 10.5 in rear I want 305s or 315s in rear for traction and 275s in the front..
Old 06-12-2010, 12:19 PM   #9
GQ4Life
10.5 will fits 305s or 315s.. tire rack just always only recommends stock tires sizes..
yea the BBS CH-R is a BMW wheel.
So they now offer the rear 10.5 in 34mm or 32mm offset?
Old 06-12-2010, 12:43 PM   #10
SGOS252382
SGOS252382's Avatar
305's are recommended on a 10.0'' wheel (10.0 - 10.5). You can also run 315on a 10.0 wheel with no issues. I'll be running 315s on a 10.0 wheel in a couple months. But I'm going with the Nitto's and they run skinny compared to BFG's, etc. I'm more concerned with the tire sticking out a bit. I know a 10.0 wheel will handle a 315 with no problems at all.
What's a little scary is the number of guys running 315s on a 9.0'' wheel.
Recommended 20" tires for 2010 Camaro
245/45-20 = 28.7" tall, 8.0-8.5 wheel
255/45-20 = 29.0" tall, 8.0-8.5 wheel
265/40-20 = 28.4" tall, 8.5-9.0 wheel
275/40-20 = 28.7" tall, 9.0-9.5 wheel
285/40-20 = 28.9" tall, 9.0-10.0 wheel
295/35-20 = 28.1" tall, 9.5-10.5 wheel
305/35-20 = 28.4" tall, 10.0-10.5 wheel
315/35-20 = 28.7" tall, 10.5-11.0 wheel
Old 06-12-2010, 01:04 PM   #11
The 2010 Sin
weaponsinc.com
The 2010 Sin's Avatar
Drives: 2014 Lifted 1500, 2013 2SS CRT
BBS wheels are amazing! I had a set on my M3CSL
The 2010 Sin is offline   Reply With Quote
Old 06-12-2010, 05:47 PM   #12
GQ4Life
where can u order the TSW
Old 06-12-2010, 05:49 PM   #13
GQ4Life
2005NUR255120G76
20x10.5
5x120
25
MATTE GUNMETAL
0
2005NUR255120S76
20x10.5
5x120
25
GUNMETAL W/MIRR
22
TSW 20x10.5 made for 2010 Camaro SS rear
SWEET!!!!!
Old 07-18-2010, 03:52 AM   #14
monstertodd
They look amazing! I knew I had the right wheel picked out all along. I am bummed though, the only car I've seen with the bright silver finish is the Jay Leno car. Would love to see a members car with the BBS CH-R's in bright silver finish.
Coil covers fit that fit the LS3? full of days Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 09-24-2010 11:43 AM
GMPP Axle Back Does NOT Fit w/ GFX My 5th Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 05-09-2010 12:14 AM
18" Wheels that fit SS d69chris Wheels and Tires Talk Sponsored by The Tire Rack 0 03-04-2010 02:58 PM
LMR CAI Fit and Finish Review themossman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 09-21-2009 03:47 PM
Fit and Finish Camaro Goon 5th Gen Camaro SS LS LT General Discussions 76 12-19-2007 06:28 PM
