JDP Motorsports
Old 06-13-2010, 11:05 AM   #15
Wayner2k2
Wayner2k2's Avatar
Drives: 2010 Black SS/RS
Originally Posted by Texhawk View Post
As pointed out in the service bulletin, the tires can be balanced, but the tire/wheel assembly may have a high or low spot that only shows up under load testing of the assembly. The wheel may have a slight high point and the tire may have a high point, that if they are not offset by the way the tire is mounted, could cause a vibration.
Could just be a bad set of tires.
Thank God for the service bulletin! It’s called a tire hop. Took it to two dealerships, explained what and how to fix it. Their response was a blank stare. @(*$%^& Idiots! The bad part is the second dealer trip was AFTER the service bulletin was released. I'll stop my comments there. However, I'm going to call the local Caddy dealership to have it looked at this time. Fingers crossed I'll come back with a smooth drive.
Wayner2k2 is offline   Reply With Quote
Old 06-13-2010, 11:28 AM   #16
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
I had this vibration issue on a set of new tires for a different car a few years back. After Discount Tire performed a special balancing (match mounting?) of the tire they finally decided to replace the tires.
After that the car road fine.
But good luck getting your tires replaced on a new car.
"WHEEL & TIRE RUNOUT VIBRATIONS
Sometime wheels will still shake and vibrate even after they have been balanced. The problem is often excessive wheel runout or tire runout. Most tires should have less than .030 to .050 inch of runout. An out-of-round tire can produce harmonic vibrations that come and go at various speeds depending on how many "humps" are in the tire.
As a rule, most steel rims should have less than .050 inch of runout, or .040 inch of runout if the rims are aluminum alloy. Some trucks and SUVs can tolerate up to .060 inch of radial and lateral runout, but others can't handle any more than .030 inch of runout before vibrations become noticeable.
Runout problems can often be corrected by "match mounting" the tire on the wheel (rotating the tire so the tire high spot is over the rim low spot). "
http://www.aa1car.com/library/wheel_balancing.htm
tradosaurus is offline   Reply With Quote
Old 06-13-2010, 05:22 PM   #17
deibelsan
1st Camaro, Love it
Drives: 2010 2LT M6 Black/Black sunroof
No problems at all. In fact, mine is so smooth that I accelerate through 70mph and on to over 80mph sometimes without even realizing it. Definitely cool but a little scary how quick and easy the car gets up there without making a whimper.
deibelsan is offline   Reply With Quote
Old 06-13-2010, 09:59 PM   #18
SamReidland
SamReidland's Avatar
Drives: 17 Black 1LE
GM should go to the unlimited warranty because everything that is wrong with the car they just say "that is normal". I think the engine could fall out of mine and they would say that's normal.
SamReidland is offline   Reply With Quote
Old 10-22-2010, 08:38 AM   #19
domano 68
domano 68's Avatar
Drives: 2014 1LE
My 2010 1SS 6spd does this and has done this for a while. Only at 70mph and higher. I only feel vibrations in the seat however. I plan on taking it to the dealership soon and hope its just a tire balancing issue.
I know this thread is somewhat old but is there any new information here? TIA!
domano 68 is offline   Reply With Quote
Old 10-22-2010, 10:34 AM   #20
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 17 A10 ZL1,14 2ssrs,96,85,79,69&67
I see that they mention you should drive the vehicle 10 miles to releive any flat spotting. My office is only 7 miles from my house. It always vibrates until the tires are warmed up. A lot of people who live in a warmer climate probably have never experienced this. I can not wait to buy new tires, however they still have tons of tread....
Old 10-22-2010, 02:57 PM   #21
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
Smooth as silk from zero to 124 mph.
No issues
camaro52010 is offline   Reply With Quote
Old 10-22-2010, 04:38 PM   #22
PaceSS
Tampa Bay Camaros
PaceSS's Avatar
Drives: 2010 Camaro Z4Z Indy 500 Pace Car
I also have this problem at around 78 and above. Really bad at 83, took it to dealer and they balanced all 4 tire because they said were out of balance, and road forced the tires. They said it was fixed. drove off and the same problem still exists, call the dealer and said we can do anything about it if above 70 (the legal speed limit). I told them that was BS, that this car is biuld for high speeds. The manager never called me back!!!!!!!!!! It's really bad when tires are cold.
PaceSS is offline   Reply With Quote
Old 10-22-2010, 09:10 PM   #23
GhostOutlaw
Drives: Black 2011 2LT/RS
U know what, I have been starting to notice this issue lately too. I guess I'll mention it when I bring it in for the spoiler issue
GhostOutlaw is offline   Reply With Quote
Old 10-22-2010, 09:14 PM   #24
Entaille
Drives: 2011 Camaro 2SS/RS
from the sounds of they are just going to waste my time and tell me it's normal. cannot wait to replace these tires, but it will be a while before I do .. : p
Entaille is offline   Reply With Quote
Old 10-23-2010, 09:42 AM   #25
2011ss/rs
2011ss/rs's Avatar
Drives: 11 ss/rs RJT w/Black Cherry stripes
Send a message via AIM to 2011ss/rs
My 2011 SS is not doing this but my 2009 Pontiac G8 GT is, We brought it back to the dealer for new tires that did not work, brought it right back for four wheel balance job still did not fix it. The service manager said to me well you know the car has 28,000 miles on it I laughed at him I have a 210,000 mile Blazer and 200,000 mile Toyota and they do not have this problem. I have posted the complaint on a G8 site and I got a welcome to the club. Lets hope GM recalls our cars for this problem because it it BS $35,000 plus should not do this.
2011ss/rs is offline   Reply With Quote
Old 10-23-2010, 10:04 AM   #26
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
I have noticed this issue too. Mine is between 65 and 75 mph. The slightest amount of vibration can be felt thru the steering wheel. Bottom line, not going to worry about it.
Old 10-23-2010, 10:31 AM   #27
camaro52010
Camaro4ever
sure sounds like wheel balance or tire pressure
Old 10-27-2010, 05:07 PM   #28
mj2112
Drives: 2LT RS 2010 Camaro
Yes, mine does this as well. Brought it to the dealership, they balanced the tires and it still does it.
mj2112 is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 Yesterday 12:30 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 01:30 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 01:58 AM
Low frequency vibration from 58 mph-68 mph Basenji 5th Gen Camaro SS LS LT General Discussions 5 05-07-2010 12:06 AM
