Gen5DIY
Old 06-15-2010, 01:20 AM   #15
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Originally Posted by wylde1 View Post
I keep hearing that this speed limiter was set at 157 mph.... I've been told from a reliable source he had his at 280 km/hr (170 mph) and still had 6th gear to wind out a bit more. So if there's a speed limiter.. they set it high
It's not a mechanical speed limit, it's a computer limit. It can be turned up or off with a tuner. From other thread discussions, a stock car won't reach much higher than 170-175. I haven't personally tested this yet but others seem to have.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-15-2010, 05:23 AM   #16
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by cdigiovanni View Post
stock is 342.. no? 373 can't give you that much more... can it? also 411 are limited to 110mph or a bit more... i cruz at 110... tickets to prove it.
That is completely incorrect. The auto comes with the 3.27s so going to 3.73 make a big difference. There is no limit on the 4.10s. They may shave a few MPH off the top end, but no where close to 40-50 MPH.
Old 06-15-2010, 12:47 PM   #17
cdigiovanni
Drives: 2010 SS2, 03 vette supercharged,
... it was in the form of a question!
i had an 87 GTA that i built for the strip and street which ran 10.23 @132mph
car had 383ci stoker, blower, 411 auburn rear amoung other mods and it would top out a 140ish ... beyond 135 it was hitting a wall.
cdigiovanni is offline   Reply With Quote
Old 06-15-2010, 10:36 PM   #18
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Is the increase in pinion speed with 4.11's enough to worry about oil cooling the differential? What would the rpm's be at 80 mph in 6th with 4.11's? I had a 4.56 spare pumpkin made for my 73 corvette and had 4.56's in my 68 Camaro, and it definitely made highway cruising more of a "buzz", but the stoplight to stoplight giddiup was way more fun!
Meh
My 5th is offline   Reply With Quote
Old 06-17-2010, 05:22 AM   #19
Apex Motorsports
Originally Posted by My 5th View Post
What would the rpm's be at 80 mph in 6th with 4.11's?!
Low 2000s. At 70-75 its right at 2000 rpm with the Richmond 4.10s.
Old 06-20-2010, 10:51 AM   #20
ZooDad
ZooDad's Avatar
Drives: 2010 Camaro SS/RS
Here are some quick numbers for those interested in side by side comparison.
ZooDad
ZooDad is offline   Reply With Quote
Old 06-20-2010, 11:45 AM   #21
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
I contacted Motive and they said they have a 3.91 and 4.10 in the works which should be available in the fall but haven't decided on prices yet.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 06-20-2010, 05:39 PM   #22
Apex Motorsports
We are all over the new Motive stuff and will have that along with the Richmond gears that we currently stock as soon as they are available.
Old 06-20-2010, 05:55 PM   #23
VRMMMM
VRMMMM's Avatar
Drives: 2010 Camaro 2SS/RS LS3
very interested in this.
Detroit Speed springs and Sway bars, MGW short shifter, BMR upper and lower control arms, BMR bushings, Roto-Fab intake, Magnaflow exhaust, MTX factory sub, painted stripes, blacked out, recessed tail lights, Pedders sub frame bushings, more on the way
VRMMMM is offline   Reply With Quote
Old 06-20-2010, 11:17 PM   #24
lakers67
Drives: Camaro 2SS
So should we wait for 3.91 gears to come out if we have the automatic? Which is better in your opinion 3.73 or 3.91? Thanks!
lakers67 is offline   Reply With Quote
Old 06-21-2010, 05:09 AM   #25
Apex Motorsports
I would go with 3.73s. The automatic transmission is already geared pretty aggressively and 3.91 will probably be too much for most people.
Old 06-21-2010, 07:27 AM   #26
Jason 98 TA
Drives: Camaro
We have the 373s in stock!!
Jason 98 TA is offline   Reply With Quote
Old 06-21-2010, 06:40 PM   #27
Apex Motorsports
ZooDad
Very nice chart. This should help a lot of peoples out.
373, gears, l99
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 10:58 PM
Richmond Gears V8 and V6 - Group Buy ZZcamaro Transmission / Driveline 175 04-30-2010 12:29 AM
MTI Racing Review (Camshaft, Gears, Suspension, Handling) Deric884 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 04-14-2010 08:11 PM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 10:36 AM
Motive Gears says no Camaro Gears ZZcamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 60 01-07-2010 02:47 PM
