sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > Middle East
Old 06-14-2010, 05:42 PM   #1
Camaro_hx
Drives: 2010 1LT/RS CGM
Send a message via MSN to Camaro_hx
SUSPENSION NOISE IS KILLIN' ME!
For the past few weeks, I've started to notice harsh front left suspension noise at rough road surfaces and turns. It wasn't noticeable at first but now its beginning to get worse.
Dangit, its a 2010 MUSCLE RALLY SPORT! It's embarrassing especially when I have someone with me and a harsh knock sound appears at a minor turn!
Im suspecting an oil leak from the damper. I have 16,400km on the clock.
Any suggestions or similar problem?
I'd appreciate your comments.
Camaro_hx is offline   Reply With Quote
Old 06-15-2010, 12:28 AM   #2
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Drives: Black 2SS/RS 14; Jeep 5.7 GC 15
Did you hit your left tyre with something solid?
You need to lift the car up and check the axle boosh and the spring.
Im not Gray any more !!
Cyber Gray is offline   Reply With Quote
Old 06-15-2010, 05:18 AM   #3
Darkone
Darkone's Avatar
Drives: 2011 Camaro LT/RS SIM
Dealer check? Possible warranty fix?
Darkone is offline   Reply With Quote
Old 06-17-2010, 07:17 AM   #4
Camaro_hx
I'll report it on my 20K service.
I know they'll say "its not under warranty and due to driver misuse, you have to pay".. but believe me i'll speech them to put it under warranty.
To Be Continued...
Old 09-21-2010, 11:25 AM   #5
Mach
Mach's Avatar
Drives: White M6 1LT RS
I am expierencing the same problem... Any updates?
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 09-22-2010, 12:24 AM   #6
Skoulikimou
Skoulikimou's Avatar
Drives: Camaro SS LS3 2010
http://www.camaro5.com/forums/attach...6&d=1277904219
Skoulikimou is offline   Reply With Quote
Front end suspension noise. BabyHauler Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-10-2012 09:12 AM
Save $$$ with Pfadt suspension packages from Apex Motorsports Apex Motorsports Suspension / Chassis / Brakes 75 12-13-2010 10:29 AM
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 12:57 PM
Rear suspension noise ? RealQuickCamaro 5th Gen Camaro SS LS LT General Discussions 18 01-21-2009 04:02 PM
