Old 06-14-2010, 11:32 PM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Cant get my SS to relearn TPMS Sensors
Alright folks, so I bought some 21's from a fellow member. Got them, and did the TPMS sensor learn, letting air out of the tire until the horn honked, did it for all 4 and it worked no problem. Well 2 days later I get in the car and it starts beeping at me saying to check TPMS, so I pull it up on the DIC, and the Driver rear was no longer reading, ok whatever, all others are reading fine.
So I go out today to relearn all of them because you cant just do 1, or if you can It doesn't say how, and per the manual you set it to active learning mode and start at the drivers front, let air out until it honks, proceed to the pass front, then the pass rear, and finally drivers rear.
Well I cannot get the passenger rear to read. I will let air out for 30+ seconds and it never honks and before you know it its timed out of active relearn and it does not store the front 2 since it was not completed as a whole.
Any ideas?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 06-14-2010, 11:36 PM   #2
Camaro21
Drives: SOLD - 2013 M6 ZL1
Either the Sensor is bad on that wheel or you might try adding air instead of letting it out.. Other than that, it sounds like you are doing everything else correct.. If not, WARRANTY !!
Camaro21 is offline   Reply With Quote
Old 06-14-2010, 11:40 PM   #3
Jeanius
Jeanius's Avatar
But if I take it to the dealer cant they see all the original options my car was ordered with and see I did not get the 21" option?
and also the sensor worked fine before I tried the relearn, it was the drivers rear that stopped reading
TRADED: 2016 2SS M6
Old 06-14-2010, 11:49 PM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Damn. This sucks. These sensors are pissing me off.
I never had a problem with those ones when they were on my car Jeanius, but my new ones will read to set, but completely drop off after about an hour. And I've reset them 5 or 6 times. But they ALL drop off. And I've also had mine do the same as you. Where the right rear wouldn't read at all.
Another member I met Saturday said the same thing. His woulnd't stay paired.
I'm confused too. These things are screwy.
Old 06-14-2010, 11:59 PM   #5
Jeanius
Jeanius's Avatar
Wierd, it worked the first time absolutely no problem, and it took less than 10 sec of decreasing the tire pressure for it to honk on each tire
In the manual it says you can use some sort of tool, I'm gonna swing by the dealer tomorrow I guess, Ill update
TRADED: 2016 2SS M6
Old 06-15-2010, 12:06 AM   #6
PQ
Booooosted.
PQ's Avatar
Please do. I'm going nuts.
Old 06-15-2010, 07:28 AM   #7
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
If your having trouble with your TPMS give this reset tool a look.
http://www.tpms-tool.com/ATEQ_TPMSRE...set_Tools.html
mickss is offline   Reply With Quote
Old 06-15-2010, 09:12 AM   #8
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
+1 Mine are doing the exact same thing. Fronts are fine, rears drop off.
Hylton is offline   Reply With Quote
Old 06-15-2010, 09:29 AM   #9
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Does the option on your data thing(forget what its called) where you check your tire pressure on the screen, it has an option to relearn your tire pressure, you tell it to relearn and the horn honks, and it resets it and after a while it reads correctly
csjcsj is offline   Reply With Quote
Old 06-15-2010, 09:32 AM   #10
Hylton
Hylton's Avatar
Originally Posted by csjcsj View Post
Does the option on your data thing(forget what its called) ....
How can you forget something called a DIC?
Old 06-15-2010, 10:07 AM   #11
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Dealer charged me $75 to reprogram them because I couldn't get the rear driver side sensor to communicate.
yea ... total
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-15-2010, 10:11 AM   #12
Hylton
Hylton's Avatar
yea ... total
That bill should totally be on warranty afaiac....
Old 06-15-2010, 10:45 AM   #13
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
same oh
Funny that this same thing happened to me after tire roatation on my wifes Yukon last month.Tire Discount could not reprogram,manually,with a hand held computer at all.It would take then immediately erase.Well After about 45 mins.They said just go drive it and if it doesn't re-learn on it's own in a few days bring it back.I was pis--ed. They stated that they" have trouble with GM systems all the time.Sometimes it has to relearn on its own!
Well I drove it for two days and bingo it re-set itself.I don't know how long you guys have been living with this but you would think it would eventually re-learn on its own?
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 06-15-2010, 12:18 PM   #14
Bell040
Bell040's Avatar
I agree, but it is not worth the time for me to fight it
Ordered: 10-13-08
Recieved: 6-12-09
Dealership stole my TPMS sensors! MacTruck 5th Gen Camaro SS LS LT General Discussions 47 04-20-2010 11:18 PM
22" Lexani LSS-5 wheel and tire package - Includes new TPMS sensors Speed Depot Wheels / Tires 2 04-13-2010 11:42 PM
SS: 1SS and 2SS The_Blur 5th Gen Camaro SS LS LT General Discussions 86 03-12-2010 12:12 AM
TPMS SENSORS hot ss Wheels and Tires Talk Sponsored by The Tire Rack 2 07-06-2009 02:57 AM
camaro ss or 06 vette? Robin 5th Gen Camaro SS LS LT General Discussions 45 08-23-2008 06:10 PM
