sjm autoprod
Old 06-16-2010, 01:47 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
6l80E newer o/s
just had a newer build 2010 camaro built in the 126,000 range come through the shop,, i did a read on it and did a compare with my original file from my 10,000 build car,, 137 differences in the tcm portion of the file, and all different segment numbers, im going to program my tcm with the newer o/s when i get some free time and see if any good changes were made with the newer o/s
my tcm segments:
24249179
24253492
24246432
24246433
build 126,000 tcm segments:
24256025
24255637
24255638
24255639
Old 06-16-2010, 01:58 PM   #2
SonnyakaPig
Drives: C63 P31
Should be interesting to see why GM changed things up.
I found this out some months back because Vortech asked to use my car for "cold start" testing in exchange for a discount on their Camaro kit. Lo and behold, they found out that GM had changed the operating system for the PCM as well as having changed the actual vendor that makes the TCM and the accompanying tune.
Fortunately, everything is running well on my car now, but at first, man oh man, not good.
SonnyakaPig is offline   Reply With Quote
Old 06-17-2010, 12:23 AM   #3
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
keep up the good spy work, dude!!!
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 06-19-2010, 01:00 PM   #4
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: 2015 ZL1 for weekends mostly
PoleCat2SSRS2010 is offline   Reply With Quote
Old 06-26-2010, 09:29 PM   #5
Frost
Frost's Avatar
Drives: GM anything
my tcm segments:
24249179
24253492
24246432
24246433
24256025
24255637
24255638
24255639
This may be a bad idea. I hope it doesn't brick a module. Going by date, I'd say you've done it by now. How did it work out?
Frost is offline   Reply With Quote
Old 06-26-2010, 11:27 PM   #6
camaro1
camaro1's Avatar
the newer o/s will not go with TIS,, it gets all the way done then it reset's and erases the tcm,, i did flash a 09 ctcv file in with TIS but the manual mode and tap shift did not function,, then i put my original file back in( hpt write cal only) and the trans has never shifted better, all the shift times are .100+ quicker and firmer,, no tcm codes and 400 miles later still shifting faster and firmer for some reason , with the same file i had in it for many months
6l80e stall tune camaro1 Tuning / Diagnostics -- engine and transmission 19 09-25-2011 07:38 PM
V8 Camaro A6 6L80E - I think its breaking down hamad_311 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 06-05-2010 12:29 PM
Ambient Light Dash install, newer 2ss no factory plugs - Lessons learned skuttduck Camaro DIY & HOW-TO instructions & discussions 4 06-01-2010 08:31 AM
Newer pics of my CGM SS with iForged 22s Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 32 02-26-2010 06:36 PM
new hptuners custom O/S camaro1 Tuning / Diagnostics -- engine and transmission 6 01-23-2010 11:17 AM
