Old 06-17-2010, 10:26 AM   #1
MADBOWTIE
400+rwhp and climbing!
MADBOWTIE's Avatar
Drives: 2010 2ss/rs camaro
codes with long tubes and no cats?
I have not yet had my car tuned with the DT long tubes and magnaflow 3" exhaust and it started throwing PO 420 and 430 codes and I expected that and have been turning off the light with a code scanner. t will usualy go for about three or four drives before it trips a code. I drove the car to work this morning and it turned on the light but when I checked it this time it had PO420 PO430 like usual but this time it also had a PO113e fuel mixture code. Is this because it is running either way rich or lean? I plan on haveing it tuned but don't have the money right now and I was wondering if I am hurting the car by driveing it. Thanks in advance for any help!!
MADBOWTIE is offline   Reply With Quote
Old 06-17-2010, 10:30 AM   #2
Merc
In The Circle
Merc's Avatar
My guess is rich. Have ARH system with cat's. Took several hundred KM before it coded out.
Old 06-17-2010, 12:43 PM   #3
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Yes you are driving it Very lean right now. Roll down your window and smell how lean.
After you get the car tuned you wont smell anything ( yes without cats )
Just remember a properly tuned car doesnt stink
if you are scared and have any questions like you are asking
PM ADM or Jenettty and ask them.
Jekyll-N-Hyde is offline   Reply With Quote
Old 06-17-2010, 12:51 PM   #4
Merc
In The Circle
Merc's Avatar
LT's with cat's would that be lean? Dyno shows pig rich. Have not had time to download code yet.
Old 07-03-2013, 08:20 PM   #5
Camaro1954
Drives: 2010 Camaro 2SSRS M6
Anyone go to cat delete and eliminate the PO420 and PO430 codes?
Camaro1954 is offline   Reply With Quote
Old 07-04-2013, 01:04 AM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This is well covered on this site. They are cat efficiency codes from moving the rear O2 sensors further back and not being able to heat up properly. It happens with no cats or high flow cats. Kooks green cats are suppose to not throw the codes but I have no experience with them. They are pricey though. The only other way to not throw the code is to tune the rear O2 sensor out. No ill affect comes from that since the rear set only tells the PCM if the cats are working properly. They have no input on how the car runs.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-04-2013, 01:35 AM   #7
SPCBA
Drives: pleather and Chiclets
kooks green cats work i used them and got no cel. they just are a pricey option...
SPCBA is offline   Reply With Quote
Old 07-04-2013, 01:39 AM   #8
axis
Search Ninja
axis's Avatar
Why are you running the greens if you're tuned?
Halltech CF 102 fed
Old 07-04-2013, 01:43 AM   #9
SPCBA
i no longer am using them... ran them for a few months before i got my cam heads and tune. running straight pipes or connection pipes now.
sitting in garage now...i should sell them
Old 07-04-2013, 01:58 AM   #10
axis
Search Ninja
axis's Avatar
Yeah, that would be a nice $600 or so in your pocket. That's a few suspension mods or two more rear tires.
Halltech CF 102 fed
Old 07-04-2013, 02:52 AM   #11
markas214
markas214's Avatar
Drives: 2012 2SS/RS L99 SIM convertible
I'll take them.
markas214 is offline   Reply With Quote
Old 07-04-2013, 08:56 AM   #12
epstein
Drives: SS/RS
Send a message via AIM to epstein
Just remember a properly tuned car doesn t stink
^^^^^^^^^^^^^^^^^^^ The truth^^^^^^^^^^^^^^
No codes .... No smell..... No soot.......
Jannetty Racing ....
epstein is offline   Reply With Quote
Old 07-04-2013, 03:18 PM   #13
axis
Search Ninja
axis's Avatar
Negative ghost rider. If you're running lean it won't smell much, but a properly tuned car is still a tad on the rich side. Better safe than sorry.
Halltech CF 102 fed
Old 07-04-2013, 03:45 PM   #14
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
The codes for lean are p0171 and p0174.
Lol .. Tuned cars don't stink ... That's good and true.
Mchlgrrsn is offline   Reply With Quote
