Gen5DIY
Old 06-18-2010, 09:43 AM   #1
soniccj7
soniccj7's Avatar
Drives: 2010 1SS/RS IBM
Opinion on dealer removing/installing new stripes.
Sorry if this questions has been asked before.
I am in the market for a IBM Camaro with white stripes. My dealer located one with black stripes. He said they can remove the black stripes and install white stripes.
I am afraid they would damage the paint if they try to remove the black stripes. What do you guys think?
Thanks,
Ed
soniccj7 is offline   Reply With Quote
Old 06-18-2010, 10:02 AM   #2
Patriot
Drives: 2011 LS3/RS on order... ..
They can be removed easily. They heat up an edge to soften the vinyl, then the peeling begins. They come right off if they are fairly new.
Patriot is offline   Reply With Quote
Old 06-18-2010, 10:13 AM   #3
rlchevy
Drives: Current Scion future Camaro
removing stripes
I had several issues with my dealer that I won't get into now. However, I had white stripes applied to my jewel tint red Camaro. They applied them crooked and had to remove them. It was not a problem for them at all. So that shouldn't be a problem.
rlchevy is offline   Reply With Quote
Old 06-18-2010, 10:41 AM   #4
hot_rod
hot_rod's Avatar
Drives: 2010 2SS RS
Removal is easy. As rlchevy noted, I would be more worried about the installation.
hot_rod is offline   Reply With Quote
Old 06-18-2010, 12:08 PM   #5
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
How did the White look on the RJT?? I'm still muddling over really metallic silver or Pearl white stripes.
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 06-18-2010, 12:10 PM   #6
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
This
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 06-18-2010, 02:31 PM   #7
soniccj7
soniccj7's Avatar
Who usually installs the stripes? I know last year the dealer said it was a dealer installed option.
Thanks,
Ed
Old 06-18-2010, 02:34 PM   #8
Brownhornitt
Brownhornitt's Avatar
Drives: 2006 White Corvette Convertible
Have them remove. That should be fine.
The Corvette is an animal.
Brownhornitt is offline   Reply With Quote
Old 06-18-2010, 05:25 PM   #9
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
They use a big ice scraper, comes right off, not to worry.
rjcamaro is offline   Reply With Quote
Old 06-18-2010, 05:59 PM   #10
Bluestreak 2010
Bluestreak 2010's Avatar
Drives: IBM 2010 Camaro LS
Removal will be fine. I ordered mine without stripes then decided I wanted the rally stripes. My dealer claimed they tried two sets and still left air bubbles, ripped the thin outline stripe and did not line the stripes up evenly. After bringing this to their attention, they said they would either order me one more set and I would need to install them myself, or I could leave them on and they would give me $350 back. Hopefully your dealer is more respectable! I finally got them to remove them and give me a full refund. I would recommend looking for a shop that does this professionally (as I did with my aftermarket rallys), or be sure your dealer can do this right.
Bluestreak 2010 is offline   Reply With Quote
Old 06-18-2010, 06:11 PM   #11
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Thanks,
Ed
Reading the note below is why the dealers are no longer in charge of the install when the stripes are ordered from the factory. There is a local shop near the factory that handles the stripe installs. This way they are done correctly and consistently.
Old 06-18-2010, 06:13 PM   #12
soniccj7
soniccj7's Avatar
I just came back from the dealer and they said their vinyl guy cuts their own rally stripes. Would it be possible to order them direct from Chevy? I am afraid aftermarket cut ones won't look right.
Thanks,
Ed
Old 06-19-2010, 12:37 PM   #13
Bluestreak 2010
I'm sure you can order the GM ones from your dealer's parts department. However, there are several shops that have both the rally and bumblebee style, and from what I've seen there is little or no difference from the factory ones. Take a look at my garage if you think it can help you decide.
Old 06-19-2010, 02:10 PM   #14
lwlkr92
lwlkr92's Avatar
Drives: 2010 IOM Camaro 2SS/RS 6M
I would save the $$ and have them painted on when you can afford to. I love the look of mine, but they always seem to have white swirl marks on them. I plan to have them painted on in the near future.
lwlkr92 is offline   Reply With Quote
Potential Problems With Dealer Installed Stripes 69er 5th Gen Camaro SS LS LT General Discussions 36 05-12-2010 08:17 PM
Who else got mis-aligned stripes from the dealer? harlow00 5th Gen Camaro SS LS LT General Discussions 22 08-05-2009 08:12 AM
The Day Has Finally Arrived - Round 3 - Black Rally Stripes!! Embalmer Camaro Photos | Spyshots | Video | Media Gallery 73 04-26-2009 08:48 PM
Dealer Installed Stripes HUGE MISTAKE!! RPO_Z28 5th Gen Camaro SS LS LT General Discussions 81 01-21-2009 12:22 PM
Factory vs Dealer applied stripes wjones14 Cosmetics and Lighting Modification Discussions 6 01-18-2009 10:39 AM
