Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 10-28-2008, 05:29 PM   #1
Rman91Bird
People call me a ricer
Rman91Bird's Avatar
Drives: 1999 Grand Prix GT
3.8 S/C in 91 FBird?
Someone wants to sell me a 3.8 S/C for my 91 Firebird. It currently has a 3.1 v6 w/ TH350 automatic. This engine he wants to sell me has 99k on it and my car has 174k. heres what he said:
$600. That's including a 4t60e trans w/165k (which you couldn't use but could turn around and sell if you wish) and the whole engine harness/ecu.
Everything is still in the car, ('96 SSEi Bonneville) so I would have to know ahead of time if it's sold in order to pull/clean it up.
I only put one mile on the motor and got into an accident after putting it in. From the little driving I got with it, it felt very solid. Can give you compression results if you wish.
Comes with a polished s/c (inlet/outlet) and polished lower intake mani.
Brand new oil and coupler in the nosedrive, stock 3.8'' pulley good for around 7-8 psi.
Any question you have about this, I can answer, have a lot of experience with the 3.8l s/c and n/a.
Do you guys think this would be a worth it/good/easyish swap?
Rman91Bird is offline   Reply With Quote
Old 10-28-2008, 05:44 PM   #2
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
First thing you 'll need to figure out is how to run it! Simple plug and play won't work and I'd imagine you'll have a mile or two of wiring to figure out if you plan to run the ECU from the donor car. Solution...stand alone ($$$$)
Second...if you are running the SC only, will the manifold bolt up to your block? How are you going to drive it (the SC...it's a roots-type right) and is there a belt that fits it? (Custom fab work...$$$$) Do you have AC and if not, can the system run
Fuel is your next issue...larger injectors will be needed and will your engine take the extra power? Will they fit in your fuel rail? What's the solution? Also...will the ECU pull timing and all? Potential to blow this thing up goes way up once you add F/I!
If you plan to pull the motor and run it then you'll have to custom fab the mounts for not only the engine, but the tranny too (maybe...IDK those engines too well). Also...the ECU and wiring will have to be completely redone. Even your dash cluster will be affected buy an ECU swap and may not work right!
IDK much about the 3.1 but I'd think this would not be easy as pull it off and put it on! Heck, I added the GMPP SC (M62) to my ride and it was a day install and still had to get the tuning done! Total cost was about $3K!
Dont' be fooled you can just plug this thing in...in most cases you'll spend more money and time than it's worth.
My 2 cents.
Legend is offline   Reply With Quote
Old 10-28-2008, 05:46 PM   #3
Legend
Hello!
Legend's Avatar
Oh yeah...forgot you'll be relocating the throttle body and you'll need more throttle cable so that's another thought?
IDK...it's not easy I know that!
Not undoable either but it's work and if you are willing to put it in then go for it.
Old 12-04-2008, 11:57 PM   #4
lil_red_v6
one wheelin
lil_red_v6's Avatar
Drives: 2004 yamaha r6
Send a message via Yahoo to lil_red_v6
you dont want to do it
lil_red_v6 is offline   Reply With Quote
Old 12-05-2008, 11:29 AM   #5
shadowed_Stranger
WAITING!
Drives: 97 V6 5spd
Well semi- on topic, how easy would it be to put the same supercharger (although from a 3.8 park avenue) on a camaro that already has the 3.8?
Originally Posted by Nine Ball View Post
Telling Camaro owners to do the speed limit is a lot like telling a room full of straight men to kiss boys.
Originally Posted by C P View Post
I'll go ahead and say it... how could GM let this happen? They have 5 years to develop the new Camaro and no force field to protect from uninsured drivers???? I'm buying a Honda.
shadowed_Stranger is offline   Reply With Quote
Old 12-05-2008, 07:53 PM   #6
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
if you can get the pcm and wiring harness, then it wont be that hard of a swap.
its the same motor. only difference is the trans setup whether the vehicle is a fwd or rwd. the motor is the same. and the s/c will bolt up just the same.
I piss excellence
and fart awesomeness
Old 01-08-2009, 05:04 PM   #7
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 79 Z28, 86 Camaro, 94 Burb 4x4
i think it would be worth it, its a better motor, and has less miles on it. good luck fixing up tht Fbird! looks like a project lol
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
The Creampuff Fleet-
Supercamaro64 is offline   Reply With Quote
Old 01-08-2009, 11:38 PM   #8
Mr Twisty
Mr Twisty's Avatar
Consider a TPI 350 from the same model year or close. Or look for a crashed donor car for your Firebird. Those TPI motors are good. Just a thought.
Those year models are fairly inexpensive, maybe you can catch one before it gets to the crusher.
Old 01-09-2009, 12:34 PM   #9
CamaroSpike23
Truth Enforcer
or swap in an LS motor
I piss excellence
Old 02-17-2009, 12:37 AM   #10
Shadow-phoenix
Terrorizing the streets
Shadow-phoenix's Avatar
Drives: 06 GTO, 92 Camaro RS, 84 Trans Am
Send a message via AIM to Shadow-phoenix Send a message via MSN to Shadow-phoenix Send a message via Yahoo to Shadow-phoenix
Spike, you and i both know that swapping a v8 into a v6 car is way easier said than done. and can cause major headaches...
as for the 3.8 s/c swap, that just requires that all the parts that the S/C needs have to be pulled from the original motor, and hooked up to the new motor. it's fairly simple.
-Creating a monster-
Rust is the vehicular form of cancer.
A stupid owner is a Camaro's worst fear, second only to the though of going to the crusher.
Camaro: a vicious animal that eats rice for breakfast, and mustangs for dinner.
Shadow-phoenix is offline   Reply With Quote
Old 02-17-2009, 12:04 PM   #11
CamaroSpike23
Truth Enforcer
well, that all depends on your budget and how much prep you put into it. if you get a motor and decide to throw it in, then months later get a transmission, then months later decide you should go carbd, then months later realize that the trans x-member is the wrong size,
where as if you get a full motor/wiring harness/pcm and trans it makes things easier. lol
I piss excellence
Old 02-20-2009, 05:26 PM   #12
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
Not if the car came with a V-8 from the factory. All that reallyis needed is V-8 motor mounts bolted in and the front springs swapped. That is assuming the tranny and driveshaft came with the V-8. It all depends on what the project is.
A swap to a carbed motor is no prob but the OP swap will be near impossible. Problem is that is a FWD 3.8. It WILL NOT bolt into your car. Don't waste your money. Its transversely mounted in the Bonneville. IT could be done perhaps with extensive fabrication but not worth it in any form.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 02-20-2009, 08:33 PM   #13
CamaroSpike23
Truth Enforcer
but swapping a v-8 into a v-8 car isnt the point of the discussion. lol
that is something I didnt think about. FWD vs RWD. and I dont know off the top of my head about whether GM casts the Longitudinal mounting holes into the block on all of their V-6's.
I piss excellence
Old 02-21-2009, 01:15 PM   #14
Super83Z
Super83Z's Avatar
Unfortunately they don't. Plus the intake is backwards the list goes on and on.
Current cars:
99 Z28
06 Silverado
14 Silverado
Can you S/C an active fuel mgt engine? Fast1 Forced Induction - V8 40 10-23-2008 09:06 PM
New to Forced Induction? Gale Banks talks about FI (Boost). GTAHVIT Forced Induction - V8 19 08-24-2008 08:51 PM
