SDTW Custom Wheels & Tires
Old 12-12-2011, 09:15 AM   #57
superchris
TRI-COUNTY CAMARO'S 3CC5
superchris's Avatar
Drives: 2010 Red 2SS/RS M6
very good info!
superchris is offline   Reply With Quote
Old 01-19-2012, 02:42 AM   #58
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
This is an awesome read!
I'm in the process of upgrading my suspension and I believe reading this has made my choice much easier, I'll be shooting one of you Pedder's guys a PM in the morning!
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 01-19-2012, 05:56 AM   #59
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
You've made a very good choice
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 01-25-2012, 12:18 AM   #60
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The BOOK has been updated with FE4 / FE5 / ZL1 Sway Bar Information.
Old 01-28-2012, 05:27 PM   #61
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
Pete, what are the suggested damper setting to start out with for XA coilovers for OE ride, performance street, and road course?
Not a Camaro but it works for now!
Old 01-29-2012, 12:08 AM   #62
JusticePete
I sent TAG out of the shop with the fronts at 27 / 3 off full hard and the rears at 15 / middle. For an all out track assault I would dial down the fronts to 18 and pump up the rears to 27 / 3 off full hard. The harder you make the rears in relation to the fronts the more the car will bias to oversteer.
OE is going to be 8 off full soft front and 5 off full soft rear.
Name your poison in between
Old 01-29-2012, 08:09 AM   #63
ssmike
Missing Big Red
ssmike's Avatar
So I'll probably start out with 15 front and 9 rear for spirited street driving, so should I leave my sway bars set to full hard? I'll be 95% street with 1 or 2 track days for fun, no serious racing.
Old 01-29-2012, 10:18 AM   #64
572HP
ACE5 (Atlanta Group)
572HP's Avatar
Drives: "Black Ice"
Having a cheater-card that I could laminate would be an awesome tool. I'd like to have OE, aggressive street, road course, and drag strip settings. I understand that these would be starting points, but for those of us that haven't learned what we are doing yet, and don't have many hours on the track, having a starting point would be very helpful. Notation such as FS+3 (Full Soft plus 3) or FH-8 (Full Hard minus 8) would make it really easy.
Do I remember correctly, that your recommended starting point for drag is front: full soft, and rear set in the middle?
572HP is offline   Reply With Quote
Old 01-29-2012, 08:06 PM   #65
JusticePete
Cheater card --
You are dead nuts on for the strip settings.
Old 02-05-2012, 11:21 AM   #66
JusticePete
Wheel Hop
The #1 source of wheel hop on a 5th Gen Camaro is found in the OEM SUB-FRAME bushes. That would be the reason Chevrolet upgrade the sub-frame bushes by partially filling the Noise Vibration and Harshness (NVH) voids starting with the 2012 5th Gen Vert. The OEM sub-frame bushes are still biased toward NVH concerns and not burn-outs, or performance at the drags or road course weekends. The NVH voided original or slightly improved OEM sub-frame bushes allow the entire IRS to shift side to side while under-load. This motion changes the dynamic alignment of your 5th Gen creating rear end steer, rear end step out and contributing to wheel hop
The #2 source of wheel hop, particularly on lowered Camaros is INCORRECT ALIGNMENT. Too much negative camber places the load of launch primarily on the inside shoulder of the rear tire. Spinning an inch and a half strip of tire doesn't take much HP. Aligning your 5th Gen to less than -.5 degrees rear camber with a TOE IN .17 improves your drag launch by using 90% or more of your rear tires to put power down.
The #3 source of wheel hop is deflection in the toe link bushes. We are not talking about toe link arm deflection we are talking about bush squish in the arm. How do I know? Hard engineering data. When GM built the Leno Twin Turbo Camaro they were not satisfied with the handling. Jay's Camaro has a very aggressive set of wheels and tires that increase the load on the suspension. In speaking with some members of the build TEAM I suggested a couple of Pedders upgrades in addition to the Xa coilovers that were already installed at the Milford Proving Grounds. Being a structured and data driven company, the build TEAM decided they should measure and document the issues on a shaker.
You can see a Camaro on GM's Shaker Rig at 55 seconds in.
What were the results of Leno's car on the SHAKER? The data and data points belong to Chevrolet and GM. The EP1200 sub-frame inserts and EP7323 Toe Link Bushes may be on Mr. Leno's Camaro, but they belong to me.
The #4 source of wheel hop on a 5th Gen is the tie and tread compound. Check aorund the forum and see what happends with wheel hop when you run on drag rubber or shorter tires.
The #5 source of wheel hop is a combination of modest spring rate and a damper map biased a bit too much to ride comfort. We spent a long time working with Lingenfelter to develop a dedicated set of drag coilovers. The front coil rate is 4.5kg and the rear is 12kg. The front monotube has a longer stroke than stock. The rear monotube is a massive 52mm diameter unit that is maxed out for bound control. High RWHP Camaros with slicks bite so har the launch is violent. They compres the rear suspension so fast that it bounces off the bumpstops. Keep in mind this was measured using a well known set of brand-x coilovers on the LPE Black Pig. When we bolted on out of the box Pedders Supercars the Black Pig picked up 2/10ths in the 60'. After we tested, refined and tested and.... you get the idea the LPE Drag Coilovers delivered more than 3/10ths improvement in the 60'
The #6 source of wheel hop is related to side to side load distribution. The factory rear sway bar 2010 to 2011 is a 23mm hollow tube that mounts inboard close to the differential. It is a light weight bar by any measure. The 2012 FE4 features an improved sway bar mounting position that is close to the knuckle. This is a HUGE improvement in geometry and function. The ZL1 comes of the assembly line with a 28mm SOLID bar. The change in geometry coupled with the change in bar strength (GM is now using solid sway bars just like Pedders Camaro sway bars) more effectively distribute load on hard launch. Upgrading to OE Rear Lower Control Arms with the new FE4 / ZL1 sway bar mounting points and a ZL1 28mm solid rear bar will imporve your drag launch. If you are looking for even more improvement your ONLY option is Pedders new 2010 to 2011 ZL1 32mm solid rear bar complete with GM ZL1 Arms and Pedders Droplinks. If you have a 2012 all you'll need is the ZL1 Rear Sway Bar Upgrade.
The #7 source of wheel hop is driveline movement. Driveline twist or driveline torque is a mini-wheel-hop motion. Replacing the OEM NVH biased differential bushes is the first place to start. The front two differential bushes are under heavy load, but that load is dwarfed by the load that the rear differential bush carries. Our solution is the new EP1167HDZ. The front two bushes are very high durometer urethane and the rear bush is machined Acetal for maximum control for optimized launches.
When you are serious about your 5th Gen performance on the drag strip your solutions are found at Pedders and Lingenfelter.
Old 02-08-2012, 10:35 AM   #67
Kronix
Kronix's Avatar
Waiting for my Pedder's coil over package to arrive from JDP Motorsports! This thread made up my mind & helped me with my choices, thanks much!
Old 02-08-2012, 10:37 AM   #68
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Thank you for choosing Pedders and JDP!
Info@PeddersUSA.com is offline   Reply With Quote
Old 02-08-2012, 11:17 AM   #69
v8
v8's Avatar
Drives: GT500 and 14 ZL1
Subscibed, good info here
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
v8 is offline   Reply With Quote
Old 02-18-2012, 11:08 PM   #70
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Dumb question but what is that wrap material on the intake tube pictured?
Nutro is offline   Reply With Quote
100 5th Gen Camaros Meet in SoCal?!?!? tribone California Meets and Events 961 04-24-2010 06:17 PM
First Post, Owned a 69 and am in for the 5th gen pruettfan 5th Gen Camaro SS LS LT General Discussions 5 03-27-2010 02:13 PM
4th Gen 1/4 mile times versus 5th Gen 1/4 mile times Rock36 Dragstrip and Launch Techniques Discussion 52 07-29-2009 10:01 PM
2nd Gen to 5th Gen pikSkip Member Car Journals 0 06-01-2009 05:41 PM
Put ideas of a 5th gen on hold. mxkx250 5th Gen Camaro SS LS LT General Discussions 2 08-10-2008 12:11 PM
