BeckyD @ James Martin Chevy
Old 10-29-2008, 03:07 AM   #1
Evilangel
Evilangel's Avatar
Drives: 2003 Evo(450hp) , 95 CamaroZ28
Tuning LS3 vs L99
Hi I just wanted your opinion on how hard it will be to modify/tune the L99 vs the LS3. I know that the LS3 already has a large aftermarket following, do you think the L99 will as well, or will the AFM keep it from reaching the aftermarket status of the LS3? Has anyone worked with AFM cars before? I'd like the L99 as I prefer auto for the drag strip(although I enjoy and currently have a manual vehicle) however I'm wondering if having the L99 will defeat the purpose.:(
Evilangel is offline   Reply With Quote
Old 10-29-2008, 03:10 AM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
they are practically the same engine, once you disable AFM you should be able to use any ls series part on it.
headpunter is offline   Reply With Quote
Old 10-29-2008, 03:18 AM   #3
Evilangel
Evilangel's Avatar
I see.. so you would have to disable AFM then. So any chance of saving gas vs the manual would be gone. What would have to be done to recuperate the power the 22 hp that was lost vs the ls3?
Old 10-29-2008, 03:20 AM   #4
headpunter
headpunter's Avatar
Drives: Man
turn off afm and get a tune....
Old 10-29-2008, 03:25 AM   #5
Evilangel
Evilangel's Avatar
Hmmm... after doing that then the parts will be interchangeable?
Old 10-29-2008, 03:33 AM   #6
headpunter
headpunter's Avatar
Drives: Man
for the most part yes, exhaust manifolds, headers, intakes should all be interchangeable
Old 10-29-2008, 07:46 AM   #7
baileyrx
baileyrx's Avatar
Drives: 2003 g35
i thought i read that the cam profile was different for the l99, not as much lift thats why, the redline is different... but everything else is exactly the same
baileyrx is offline   Reply With Quote
Old 10-29-2008, 07:59 AM   #8
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
So to take off with the automatic on a drag strip you would simply press down on the pedal or have it on neutral with the gas down and then switch to drive? Or are you using the paddle shifters?
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 10-29-2008, 08:06 AM   #9
baileyrx
baileyrx's Avatar
Drives: 2003 g35
not on any car i own...
on a side note, in h.s. my friend would do this to his chevette ALL THE TIME and his car ran for ever!!! well until a trunk ran a red light
Old 10-29-2008, 10:28 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It sounds like the AFM is defeatable because I remember reading a little about the development of the Maggy' 1900 on the G8's 6.0 and they were saying, if I'm not mistaken, that they could turn it off if they needed to, although they were trying to run the car with it on to see if they could.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 10-29-2008, 12:17 PM   #11
carfansince73
carfansince73's Avatar
Drives: Carefully
Check out G8board.com. There are some there who have s/c'd their AFM powered G8 GT's. There will be no shortage of aftermarket tuning parts for the L99 Camaro.
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! I wonder if the state would allow this vanity plate---> KISSMYSS
2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock
carfansince73 is offline   Reply With Quote
Old 10-29-2008, 06:36 PM   #12
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
I am doing some speculating here, but I believe if you put the standard LS3 cam/lifters in the L99 you could gain back the 22hp, and most likely safely move the rpm limit up to 6600-the same as the LS3. May as well do this if you are going to tune out the AFM mode anyway. With the more aggressive gearing of the auto car this would be one nice mod. Of course, economy would suffer but oh well. The only thing I am not sure about in terms of raising the rpm limit is the VVT setup, but I don't see why that would hurt, I think the timing is most likely fixed above a certain rpm/load anyway.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 10-29-2008, 07:05 PM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Aren't the cams different between the two too?... Better watch where you're shifting that tranny also.
Old 10-29-2008, 08:06 PM   #14
rayhawk
rayhawk's Avatar
Yes, the L99 has a less aggressive cam, that is what I meant, to put a LS3 cam and lifters in to get the LS3 with the auto, effectively. Of course, to go to that trouble you may as well step up to the hot cam anyway. I don't know much about automatic transmissions, but why would that extra rpm be a problem? Does'nt the vette use a similar auto trans (obviously rear mounted) and have a 6500 rpm redline?
-Al Bundy
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Why the L99? The Vette uses a LS3 with Auto 6-sp! Why cant the SS Have this option? D-Unit Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 02-17-2009 08:16 AM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
Tuning the L99 Lifted07Sierra Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-02-2008 11:28 AM
