Old 06-19-2010, 08:19 PM   #1
SSinatra Andretti
2$$
SSinatra Andretti's Avatar
Drives: 94 ss, 2008 gxp, soon to be2011 2ss
pressure sensor D.I.C.
anybody know if i buy some 22;s or 24s.. will the tire pressure in the d.i.c. read correctly or will it not work at all......... i want to know before i commit to buy some rims!!???? please respond..
burn rubber & write your name in the street
SSinatra Andretti is offline   Reply With Quote
Old 06-19-2010, 08:23 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I see no reason it would not work.
Old 06-19-2010, 09:04 PM   #3
SSinatra Andretti
2$$
people telling me the tire pressure monitor are in the tires.. can they be removed and placed in new rims??
Old 06-19-2010, 10:12 PM   #4
BackinBlackSS/RS
Go Blue!!!!!
Remove from old rims install in new rims.
Old 06-19-2010, 10:36 PM   #5
SSinatra Andretti
2$$
is it that easy? i hope so
Old 06-19-2010, 10:53 PM   #6
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
yes ,it's that easy . most tire shop will have new valve stems that you will need . thy are around $3 -$5 each
1 BAD RS 2 SS is offline   Reply With Quote
Old 06-19-2010, 10:54 PM   #7
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Yes it is that easy!!! Your owners manual will tell you how to reset the tpms sensors it is very easy!!!!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 06-19-2010, 11:31 PM   #8
SSinatra Andretti
2$$
freaking awesome... i was afraid with new rims.... the tpm in the d.i.c. wouldnt be operational or come up blank on the instrument panel... thanks c5..... guess now that the worries are over i can shop for rims....
Old 06-20-2010, 01:55 AM   #9
oldfriend
Drives: Fiat 500 E
If you put the sensors on the same order that was before, it will work like nothing happen [ask the guy to put the sensor from front left and install it back on the same front left and so on , and yes is that simple there is only one small screw that secures it to the inside valve steam and that's all there is , i just did something like that [installed GIOVANNA MARTUNI MATE BLACK ] worked like a Swiss clock
Old 06-20-2010, 02:14 AM   #10
SSinatra Andretti
2$$
yo thanks @oldfriend does it matter what order FL, FR, RL, RR? front left, front right, rear left, rear right... one by one, or in pairs such as both front, then rear...
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
now logging actual line pressure in A6, less than 100psi in 3rd parish8 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-20-2010 10:46 PM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 09:04 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 04:34 PM
