BeckyD @ James Martin Chevy
Old 10-29-2008, 08:33 PM   #1
13F20
Drives: Soon to be 2010 Camaro SS
need advice on LS9 crate engine from GM
I am starting to gather information from the LS9 crate engin that GM will offer next year from GMPP. I do entend to get the engin as part of a projet that I will be doing. What els do you sujest i get or change on the car, for this to work right?
13F20 is offline   Reply With Quote
Old 10-29-2008, 08:46 PM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
you need the intercooler for the LS9. which is air to liquid to air. you also need all of the equipment for the dry sump oil system. you will probably need the internals from a tr6060 from a zr1 so they will have the strength for use with the ls9. the rear end should be fine.
headpunter is offline   Reply With Quote
Old 10-29-2008, 09:19 PM   #3
ucla1ove3
ucla1ove3's Avatar
Drives: soon to be 2010 CAMARO :]
that's sounds really really really really expensive.
ucla1ove3 is offline   Reply With Quote
Old 10-29-2008, 09:33 PM   #4
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
the upside of sitting in a combat zone for so long is that he rakes in some extra dough that is tax free
i'm definately going to make a trip to check out this project and lend a hand if needed
headpunter already listed everything i could think of, as long as it plugs into the wire harness fine (and if not, thats not a huge deal)
Chewy is offline   Reply With Quote
Old 10-29-2008, 10:22 PM   #5
13F20
give your two cents
The first item i will get is the LS9. As i have said it will take time and money that does not grow on trees. Plus the time this should take will also give me the chance to see if any one els attempts to do the same thing and learn from any mistakes they might have. Plus this is going to be a one time shot for me and if i blow it it will be a done deal. So far the added parts I will apply are listed blow.
1. LS9
2. air liquid air inter-cooler
3. Dry sump oil system
4. ZR1 TR6060 components
5. Peters track 2 suspension system
6. Wire harness
7. 6 piston brimbo calipers w/ 14 inch ceramic rotor cross drilled and slotted.
Old 10-29-2008, 10:27 PM   #6
headpunter
headpunter's Avatar
Drives: Man
1. LS9
6. Wire harness
what brakes are you planning to use for that? if your thinking Zr1 brakes they are actually 15.5 front and 15 rear
Old 10-29-2008, 11:04 PM   #7
13F20
yes the ccm roaters i was wrong on the disk size.
Old 10-29-2008, 11:07 PM   #8
headpunter
headpunter's Avatar
Drives: Man
i was just curious since they have smaller rotors for porsches and other exotics that are just as expensive
Old 10-29-2008, 11:25 PM   #9
13F20
i was jsut curious since they have smaller rotors for porsches and other exotics that are just as expensive
I do remember you did say something a while back about the calipers and rotors for the ZR1. Do you know the cost for the entire set up and were I could go on the Internet to get a print out to apply to my list.
Old 10-29-2008, 11:29 PM   #10
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
Spell check?
I kid, I kid....
themossman is offline   Reply With Quote
Old 10-29-2008, 11:32 PM   #11
headpunter
headpunter's Avatar
Drives: Man
something like $8000 for the set of rotors and calipers...
Old 10-29-2008, 11:33 PM   #12
Jamestwilliams
junior member
Drives: Grand Am
I thought the housing on the ZR1s tr6060 was thicker wall as well, so you may need the whole transmission.
Jamestwilliams is offline   Reply With Quote
Old 10-29-2008, 11:43 PM   #13
13F20
You might be right. But we will see what happens.
Old 10-29-2008, 11:46 PM   #14
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
GMPP's LS9 crate engine assembly comes fully dressed, including the ignition system, supercharger assembly, exhaust manifolds and more. It also includes the production dry-sump oil pan and provisions for the charge cooler's liquid cooling system. Builders will need an external oil tank, external coolant tank (for the charge cooler) and an ECU/wire harness.
SEMA Preview: GM Performance Parts 638-hp LS9 Crate engine
Head Punter speaks the truth.
Robert91RS (GM Parts) Did some checking for me and it looks like a GMPP authorized Dealer can do the install for you... Maybe. That is an assumption based on another conversation.
I'd like to know what GMPP will charge to get this out the door....
SEMA Preview: GM Performance Parts 638-hp LS9 Crate engine CamaroSSforme Forced Induction - V8 59 11-04-2008 09:37 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 07:16 PM
It's official: ZR-1 LS9 engine makes 638hp / 604tq !! Tran General Automotive + Other Cars Discussion 28 04-29-2008 06:38 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
