Old 06-21-2010, 12:36 PM   #1
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
Trunk light bulb removal
I've done the search mod on how to do this and nothing came up.
Trying replace the bulb with a LED. I've done the dome and license plate bulbs and this is the last one to remove. I have it out and see there is some sort of metal clip over the bulb but I don't see it pulls up or the bulb just slides out. What I do know is the bulb get hotter than shigady!
Anyway, if some can advise I'd appreciate it!
Never grow up, it's a trap!
chozn4service is online now   Reply With Quote
Old 06-21-2010, 01:25 PM   #2
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
If I remember correctly there is a little indention on the plastic cover to stick a flathead in. Just pry out from there. If there isn't and I'm wrong just pry from one of the smaller sides and it comes out pretty easy. Yes it gets hot fast so work quickly haha
ackeight is offline   Reply With Quote
Old 06-21-2010, 01:27 PM   #3
TK
Drives: Black 2SS/RS M6
Hmm, i just ordered a set of those bulbs from AAC so I decided to go out to the car, i can't even figure out how to get the interior bulb changed hah, the first step says to remove the switch cover but i can't seem to "pop" it out without ****ing up the plastic, is there a good side to pry from?
TK is offline   Reply With Quote
Old 06-21-2010, 01:28 PM   #4
LadiesMan217
LadiesMan217's Avatar
Drives: '10 IOM/IO 2SS/RS
He's not talking about that. The housing restricts your fingers from getting around the actual bulb.
I used needlenose pliers wrapped with the same material as the rubber that helps your remove jar tops. (That non-slip rubber material).
You can always pull the fuse or disconnect the battery so the light doesn't light...it's only hot when it's lit
Proud Member of NEC5!
LadiesMan217 is offline   Reply With Quote
Old 06-21-2010, 01:30 PM   #5
LadiesMan217
Just be careful...it pops out rather easily. A small flathead worked fine.
Old 06-21-2010, 01:45 PM   #6
TK
Thank you, got both out without a hitch.
Old 06-21-2010, 03:29 PM   #7
chozn4service
The dome light was easy. Just pry it on each end and it comes out but that trunk light was another issue. First you need to leave the trunk open until the light goes out so it's cool to touch, then take a screw driver and push the contact end out towards you. I have my LED's installed and all looks good good! I have LEDs at my entry lighting up the Camaro sill plate and footwells and now the dome, trunk and license plate with LEDs. Paid like $28 bucks for my four 5202 bulbs.
The total look is awesome!
Old 07-12-2010, 06:09 PM   #8
thebighar
Drives: 2010 1LT CGM RS/CC
I read these posts to take out my trunk light and had to laugh at some of you after i did it, seems i got lucky. I pulled the plastic plate off and yes the bulb is hotter than the sun, but if you keep pulling you can pull the excess wire out and you can see that you can unclip part of the housing and just pull the bulb out with part of the housing attached. Take the bulb out a minute later when it cools and put the new bulb in and snap the housing back together, then just snap the plate back on.
thebighar is offline   Reply With Quote
Old 07-12-2010, 06:50 PM   #9
LadiesMan217
Hehe, I replaced mine while I had the battery disconnected putting in the Knightlight. Can't get hot if no power is getting to it :-)
Old 07-12-2010, 08:43 PM   #10
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
Old 07-12-2010, 10:07 PM   #11
CamaroVision
CamaroVision's Avatar
Drives: 2010 Black 1LT/RS
You can push in the 2 'prong' like things on the trunk lid (eye level or something like that, the pin things sticking out on the left and right side of the escape-pull thingy. Pushing those to prong/pin things in turns the trunk light off, or just one I don't remember....but then push it out from the bottom with a screwdriver or something.
CamaroVision is offline   Reply With Quote
Old 08-04-2010, 01:21 PM   #12
wangtangjf7
wangtangjf7's Avatar
Drives: CGM LT/RS
Are you talking about the inside dome light? if so, the best side is the side closest to the window and pop out the right corner first. once, you've done that, the rest is really easy to get off.
CGM LT/RS
Trifecta Tune "Ghost Cam"-ARH LT Headers w/ Straight Pipe-Bullet Mufflers- Magnaflow Resonated X Pipe-Injen CAI-RX Catch Can-Pistol Grip Shifter w/ Tap shift-Xenon Dome Lights
wangtangjf7 is offline   Reply With Quote
Old 12-13-2012, 11:10 PM   #13
johnriganati
Drives: 2013 SS/RS BLACK WITH INFERNO ORANG
Send a message via Yahoo to johnriganati
how long does the trunk have to stay open before the light goes out??
johnriganati is offline   Reply With Quote
Old 12-13-2012, 11:14 PM   #14
johnriganati
riggzy
how long did the trunk have to stay open for the light to go out??
New! ABS Hard Plastic Side Marker, Reverse Light and Tail Light Kits! Not cheap vinyl RPI Designs Exterior Parts & Accessories 126 12-16-2017 02:01 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
Any hints on how to remove nuts from inside trunk lid? OHIOSS 5th Gen Camaro SS LS LT General Discussions 25 06-09-2010 11:49 PM
Trunk Light?!?!? ToFast 5th Gen Camaro SS LS LT General Discussions 3 10-15-2009 11:26 PM
How many forum members does it take to change a lightbulb? stovt001 Off-topic Discussions 28 05-26-2009 10:17 PM
