Old 06-22-2010, 12:57 AM   #1
acamellis
IAMACE
acamellis's Avatar
Drives: 2010 2SS/RS Black A6
Send a message via AIM to acamellis
Blowout!
I was driving around tonight and drove my car into this big, desolate parking lot to see it I could bread the tires loose. My tires were reading about 38 psi. The first thing I did was go into a hard turn and punch it. (I have an automatic)
All nannies were off etc.
It broke loose and when I recovered it bit hard and gained traction back well.
Then I heard a hissing sound and my low psi light came on.
My front driver side pirelli went from 38 psi to 0 in about 20 seconds
Tried the tire sealant and inflator kit but it just spewed out onto the ground. My tire is toast.
Called OnStar
Im taking it to the dealer first thing in the morning because I have the tire warranty.
Im going to leave out certain details when I tell them what happened
But my question to y'all is this:
That shouldn't blow my tire like that should it?
They have 6500 miles on them of 99% easy driving. This was the first time I've tried this...
acamellis is offline   Reply With Quote
Old 06-22-2010, 01:01 AM   #2
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
Not that it has anything to do with your case, but you should be carefull when turning the wheel all the way to one side and jumping on it. I was reading posts yeaterday that said that could cause the power steering hoses to burst from too much pressure or cause the pump to stick. Good luck at the dealer tomorrow.
Silver2SSRS6spd is offline   Reply With Quote
Old 06-22-2010, 01:09 AM   #3
khabboub
Tampa Gulf Coast Family
khabboub's Avatar
Drives: 2010 Black Camaro 2LT M6
just make sure that you have a good story. if you dont make it sound like it was a road hazard they will not replace the tire.
khabboub is offline   Reply With Quote
Old 06-22-2010, 01:11 AM   #4
cterry
So Cal Race Team
cterry's Avatar
Drives: 2010 Carmaro SS/RS
Sounds like you put so much force on the side wall when turning and accelerating, that you popped the bead of the tire off. Was their a hole, or did the sealant come out the side?
cterry is offline   Reply With Quote
Old 06-22-2010, 01:17 AM   #5
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
This is my guess, the tire might be fine just needs to be reset and re-inflated. You could always get a can of either.
NO seriously don't get a can of either though, I've seen tires explode .
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 06-22-2010, 01:19 AM   #6
acamellis
IAMACE
acamellis's Avatar
There is a 3.5 inch rip across the tread of the tire. It's weird to me because there is no sidewall damage.
Old 06-22-2010, 01:19 AM   #7
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
i think you just got a nail or something, if you would have poped a bead then you would hear a bang, and not the hissing sound you mentioned.
It was just tough luck i guess.
christianmotox is offline   Reply With Quote
Old 06-22-2010, 01:20 AM   #8
KungFuHamster
KungFuHamster's Avatar
Drives: Grabber Blue Mustang GT
Called OnStar
lol
KungFuHamster is offline   Reply With Quote
Old 06-22-2010, 01:22 AM   #9
acamellis
IAMACE
acamellis's Avatar
lol i'll use the either right after you do
But there's no hope of it being reset and re-inflated.
See above post
Old 06-22-2010, 01:23 AM   #10
acamellis
IAMACE
acamellis's Avatar
Thanks and I was careful not to put full deflection on the steering wheel.
Just enough to get a lil sideways
Old 06-22-2010, 01:26 AM   #11
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
I'd say that since it was a desolate parking lot and night, you may have hit something in the pavement that tore the tread...
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 06-22-2010, 01:30 AM   #12
acamellis
IAMACE
acamellis's Avatar
Its an empty college football stadium parking lot and I checked it out earlier today before it got dark... But who knows. It doesn't take much...
Old 06-22-2010, 01:31 AM   #13
daphatgrant
June '10
See above post
Gotcha, I've never used either myself but I've seen it used a couple times, amazing yet scary way to get a tire on a rim, lol.
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 01:35 PM
Auxiliary Gauge Pack BLOWOUT SALE at GMPARTSHOUSE!!!!! patrickt Audio / Visual / Electronics/ Gauges / Nav 22 08-23-2010 10:49 PM
Pacesetter exhaust blowout sale Ernie@P V8 Bolt-Ons & Tunes 17 07-22-2010 04:52 PM
