Emblempros
Old 06-22-2010, 12:34 PM   #1
ctk1
Camarofanatic
Drives: 1969 SS, 1998 RS, 2010 VR 2SS/RS
Question about replacing running lights with LEDs
How do you go about getting to the bulb in the running lights? Do you have to remove the entire front fascia?
ctk1 is offline   Reply With Quote
Old 06-22-2010, 12:58 PM   #2
cubjag
cubjag's Avatar
Drives: 2010 Camaro 2SS/RS Black
No you can reach the lights by going through the wheel wells.
cubjag is offline   Reply With Quote
Old 06-22-2010, 11:02 PM   #3
ctk1
Camarofanatic
Thanks Man, I appreciate the help!
Old 06-22-2010, 11:28 PM   #4
markgoodson
markgoodson's Avatar
Drives: 2010 2 SS RS
The rear ones are a bit more tricky.
markgoodson is offline   Reply With Quote
Old 06-23-2010, 12:21 AM   #5
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
You didn't remove the rear fascia just to get the sidemarker light, did you?
They just pop out by reaching up...
Just curious...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 06-23-2010, 06:46 AM   #6
markgoodson
I did, it's simple really. There are only four screws in the wheel well that you have to remove and then it pops right off. I tried reaching up to get at it first but didn't have any luck.
Old 06-23-2010, 10:37 AM   #7
Michael_Js
Michael_Js's Avatar
Interesting...I just laid down, with the car on the ground, and popped out the rear ones. Very simple...
However, whatever works!
Old 06-24-2010, 12:35 PM   #8
ctk1
Camarofanatic
How hard is it to replace the foglights also? I have the RS package so mine are only used for daytime running lights, but I had the yellowish color. I want them more white like the HIDs? Are they hard to get at?
Old 06-25-2011, 07:25 PM   #9
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
+1 You did way too much removing those 4 screws...
FL1CK is offline   Reply With Quote
Old 07-08-2011, 07:25 PM   #10
smiffsonian
smiffsonian's Avatar
Drives: 2011 2SS/RS Camaro
where did u get those side markers from? thats exactly what im looking for
smiffsonian is offline   Reply With Quote
Old 07-08-2011, 08:45 PM   #11
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
These are the showstopper concept led side markers... Aac makes them also, but I'd go with showstoppers.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 07-08-2011, 09:18 PM   #12
Synerbee
SoCal Headturners
Synerbee's Avatar
Drives: 2010 SGM
Those are AAC. On the Showstoppers set, the LED strip run along the top of the sidemarkers. AAC sidemarkers do not flow as nicely, but are cheaper
Synerbee is offline   Reply With Quote
Old 07-08-2011, 11:32 PM   #13
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Ah, my bad... You're right. I should know this, I own those markers.
Old 07-09-2011, 05:03 AM   #14
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Those are AAC. On the Showstoppers set, the LED strip run along the top of the sidemarkers. AAC sidemarkers do not flow as nicely, but are cheaper...and collect moisture in the housings
Showstoppers FTW
[B]
Fog lights camarogolfguy 5th Gen Camaro SS LS LT General Discussions 36 12-03-2017 08:42 PM
Quick question about HID and Halo LIghts ttazzijr700 5th Gen Camaro SS LS LT General Discussions 81 01-30-2011 09:43 PM
I have a question regarding foglights / running lights NoodlesSS 5th Gen Camaro SS LS LT General Discussions 34 10-12-2009 04:53 PM
Question about Halo LED lights retrofit mbavenger Cosmetics and Lighting Modification Discussions 8 05-31-2009 05:06 PM
HID Light's question. Th3Nigh7Stalk3r 5th Gen Camaro SS LS LT General Discussions 6 12-29-2008 10:22 AM
