HeadlightArmor
Old 06-22-2010, 02:12 PM   #1
luisgayoso
Drives: 1968 SS 383ci - 2010 SS Inferno
Clutch noise.
Hi, I recently bought a new SS Inferno edition (manual trans.).
Each time I push the clutch or release it I hear a "clack" sound under the gear box. This happens on any gear.
Does any one that has a manual transmission Camaro has the same noise? I would like to know if its normal or I have to worry about that.
Any advice is welcome. Thanks.
Luis.
luisgayoso is offline   Reply With Quote
Old 06-22-2010, 02:20 PM   #2
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
Is this while the car is moving slowly?
Or does it make the noise even when not moving at all?
If if makes a noise when not moving at all, I'd have it looked at. Sometimes when the car is moving slow, a little clunk noise may be normal which is just the play/clearances in the drivetrain.
Just pushing the clutch in by itself, when the car is not moving, mine makes no noise - and they shouldn't make a noise.
Old 06-22-2010, 02:36 PM   #3
Synergy Green
Synergy Green's Avatar
Drives: 2010 Synergy Green Edition Camaro
Send a message via Yahoo to Synergy Green
I notice a clack noise after I shut the car off under the hood, I have a v6 6M - have not had any performance issues though so I am assuming its no big deal.
Speed is just a question of money, How fast do you wanna go?!?
Mods: Sequential tail lamps, K&N Typhoon CAI
Synergy Green is offline   Reply With Quote
Old 06-22-2010, 02:37 PM   #4
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
The general consensus of the TR-6060 in this particular vehicle is that it "does" make noise. Mine makes noise, and it bothered me at first, until I came up here and started reading lots of posts regarding the same "Type" of noises.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 06-22-2010, 02:38 PM   #5
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
I certainly hear more transmission noise in this car than any manual car I have driven before but like Russell says above there is no noise happening when I push the clutch in, only when putting it in gear. Also the higher the gear the less noticeable the gear engaging is.
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 06-22-2010, 02:39 PM   #6
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Drives: The one with a roof rack
its cus you're slamming the clutch hard. this noise happens to me too on my V6/M6. I dont think its damaging tho. But just like anything else in this world, if you abuse it too much it will get worn down faster.
SnoopyAce7 is offline   Reply With Quote
Old 06-22-2010, 02:46 PM   #7
SSPower
Surely thou jivest...
SSPower's Avatar
Drives: 2SS/RS LS3 CGM/IOM stripes
SSPower is offline   Reply With Quote
Old 06-22-2010, 03:12 PM   #8
BTex68
BTex68's Avatar
Drives: 2010 SSRS
There are people in the world who push on the clutch gently?
BTex68 is offline   Reply With Quote
Old 06-22-2010, 04:09 PM   #9
luisgayoso
Rusell, there is no noise at all when the car is not moving, engine running or not. The noise shows when I change gears while driving. The noise appears just when the clutch engages or disengages, after that no noise at all.
Old 06-22-2010, 08:02 PM   #10
Tom
Drives: 2010 SS Red Jewel 6 spd manual
Normal for this car/transmission/clutch combo.
Tom is offline   Reply With Quote
Old 06-22-2010, 11:10 PM   #11
dwade76
dwade76's Avatar
Drives: Camaro 2LT RS
Yeah mine does that too. I hear a couple of clanks after i shut her down, is it anything i should worry about?
dwade76 is offline   Reply With Quote
Old 06-23-2010, 05:49 PM   #12
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
This is a normal noise of the pressure plate pushing the clutch disk up against the fly-wheel. My car does the same thing - sometimes it "clacks".
Kenji is offline   Reply With Quote
Old 06-23-2010, 06:18 PM   #13
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
Yeah this car takes the cake on transmission noise...partly wishing i'd got an auto. But it is nice to go throughthe gears...
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Heads Up - Clutch Spring noise ffrcobra_65 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 11-22-2009 10:04 AM
why does it make such a clunky noise when putting the clutch in yellow1 5th Gen Camaro SS LS LT General Discussions 16 07-07-2009 07:19 PM
Clutch Noise? GLBL WMR V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 05-24-2009 01:04 AM
