Old 06-23-2010, 02:51 PM   #1
tom692010
Drives: 4 wheels
20-`18 tire change issues
I put on nitto on an 18" rim I normally run 20" for racing only. When I drive 5 miniutes thought all the gauges come on . Was I supposed to do something when I install the 18"?
tom692010 is offline   Reply With Quote
Old 06-27-2010, 06:47 PM   #2
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Same happens to me. The size difference front to back fakes the sensors into thinking that the rears are slipping. Even with trak/stabil off you get the xmas tree on the dash after awhile. Nothin you can do that I know of. Were you able to get the malfunction light off the dash some way. I found that the only way was to retune the car or put the 20s back on and drive it. I wonder if it bothers anything having the malf light on. I read somewhere on here that some guy was bracket racing and his car went nuts on his last pass and he almost lost control after making several passes with the malf light on..
ROD1 is offline   Reply With Quote
Old 06-27-2010, 07:40 PM   #3
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
You should be able to run the 18" wheels without problems provided you use the proper tire size to equal the 28.7 inch height of the stock 20" wheels with 275-40-20 tires. See the tire and wheel combination heights in this forum.
2SSCAMARO is offline   Reply With Quote
Old 06-28-2010, 01:15 PM   #4
tom692010
Drives: 4 wheels
Once I threw 20"s back on everything was normal again.
Old 06-29-2010, 09:41 AM   #5
ROD1
Retired
Yupper but then ur giving back all the gear ratio you gained!
Old 06-29-2010, 04:12 PM   #6
2SSCAMARO
2SSCAMARO's Avatar
Did you run the same type nittos on the 20" rim also and if so how much et improvement did the 18" wheels do?
Old 07-01-2010, 12:29 PM   #7
600hp-lpe
Drives: 2010
you need 18's on the front too.. if the fronts and rears are the same height there is no light issue.
The different size front / rear is raising havoc with the stabilitrac.
600hp-lpe is offline   Reply With Quote
Old 07-04-2010, 06:32 PM   #8
HJ's Garage
HJ's Garage's Avatar
Drives: Black on Black 2SS RS A6
What type and size of 18" rim did you use? I am looking to mount a set of Nitto 305/45 drag radials on 18x10 rims of some sort. That keeps the tire diameter at 28.8" and gives it some tire wall to work with.
HJ's Garage is offline   Reply With Quote
What song are you listening to right now Muscle Master Off-topic Discussions 6398 02-16-2018 01:04 PM
Ruined Tire scott53 Wheels and Tires Talk Sponsored by The Tire Rack 10 05-20-2010 08:00 PM
Bridgestone RE11 Performance Tire Review Info@PeddersUSA.com Suspension / Brakes / Chassis 4 12-28-2009 11:58 PM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 04:45 PM
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over bigralph Off-topic Discussions 15 02-06-2009 08:07 PM
