JUICEDMOTORSPORTS
Old 10-30-2008, 10:16 PM   #1
MerlinZero
Big Orange
MerlinZero's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
Difference in launch modes
Ok,
I've been reading but i bet i missed it. I understand how the Launch Mode works with the LS3. But can anyone explain how the Launch Mode works in the L99?
Does it work similarly to how the Ferrari 430 works (just for example) to put it into Launch Mode, you hold down on the Down Shift paddle for 2 seconds then the engine will rev to 4,000 before it engages the gear?
Just a thought i was having.
MerlinZero is offline   Reply With Quote
Old 10-30-2008, 10:21 PM   #2
DMX
DMX's Avatar
Drives: CrownVic,Suburban,Silverado,F150
As far as I know Launch Control is only available on the manual.
DMX is offline   Reply With Quote
Old 10-30-2008, 10:22 PM   #3
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
there is no launch mode on the l99
with an auto you simply floor the brake, give like 2000 rpm on the gas and then let of the brake.....that is your launch mode....works the same as any other torque converter auto.
with the manual you will push the clutch pedal in, put it in 1st gear, then floor the gas pedal, (it will limit the rpm) and then you dump the clutch and away you go....
headpunter is offline   Reply With Quote
Old 10-30-2008, 11:30 PM   #4
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Isn't that going to eat up your brakes real fast though though????
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 10-30-2008, 11:33 PM   #5
headpunter
headpunter's Avatar
Drives: Man
not if you let go fast.....=P
Old 10-30-2008, 11:33 PM   #6
Dom
Drives: 2000 Z28
I don't see how a car standing still can eat up the brakes.
2000 Z28 - current daily
1996 Camaro 3.8 - previous daily
Dom is offline   Reply With Quote
Old 10-30-2008, 11:35 PM   #7
MerlinZero
Big Orange
MerlinZero's Avatar
I think he means from the pressure that is being applied by the gas. Whilst you have full pressure on the brake.
Yeah i do this in my Subaru now, put on the brake, put it up to 3k rpm and then let go... the Brimbo's stand up good to this.
Old 10-30-2008, 11:38 PM   #8
headpunter
headpunter's Avatar
Drives: Man
if the wheel isnt moving you arent hurting the brakes anymore then braking the car into a corner.. mind you that the wheels are rotating more coming from a stop at 60 then they are at launch.
Old 10-31-2008, 02:56 AM   #9
Supermans
Supermans's Avatar
Well than I have to ask the opposite then.. Is this hurting the gears at all running at 2000 rpm when not moving during the time of revving and pressing the brake all the way down? Or does it put pressure on any other component like the auto transmission for example or something else for that matter..?
Old 10-31-2008, 05:38 AM   #10
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
We used to call that power braking in the old days. Only one small problem with it though. You will eventualy wear out the engine as the crankshaft ends up putting a sh!t load of pressure on the bearings doing it.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-31-2008, 08:39 AM   #11
Supermans
Supermans's Avatar
That's what I was afraid of, and perhaps why it is not a good idea to do with the automatic.. So 0-60 times of 4.9 can only be achieved by doing this method???
Old 10-31-2008, 08:50 AM   #12
Scott@Bjorn3D
My understanding is the 0-60 in the Auto was just by stomping on the pedal and they are 4.6 seconds and may get better. I do not think they would get worse.
Old 10-31-2008, 09:41 AM   #13
Evilkosh99
Evilkosh99's Avatar
Drives: 2010 Black SS/RS
Does the launch control feature limit the rpm to the same number every time it is used (for example 2000) or does it limit it to different rpm depending upon sensor inputs - (i.e. suspension mode, tire pressure, miles on the engine, etc.)?
Black on Black 2SS RS is here
Evilkosh99 is offline   Reply With Quote
Old 10-31-2008, 09:46 AM   #14
headpunter
headpunter's Avatar
Drives: Man
same number as far asa we know
What is the difference between a Sports car and a Muscle car (whats your opinion) Camaro Man 5th Gen Camaro SS LS LT General Discussions 33 02-15-2011 11:15 PM
Camaro SS Launch Control jdpickering Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 12-23-2009 09:29 AM
difference between V6 and SS facsia? Yeahyouknwit Camaro Photos | Spyshots | Video | Media Gallery 22 10-12-2008 09:50 PM
2010 Chevy Camaro to offer two V6s at launch; Z28 to trump SS? radz28 Camaro ZL1 Forum - ZL1 Specific Topics 51 06-23-2008 12:12 PM
Ford delays launch of new F-150 KILLER74Z28 General Automotive + Other Cars Discussion 3 06-20-2008 01:37 PM
