Old 06-23-2010, 04:26 PM   #1
IPSjeff
Drives: 2009 ZR1
IPS TT Kit -- 795HP on STOCK LS3!!
We completed tuning today on our prototype Twin-turbo Kit and even in the 90+ degree heat and 80%+ humidity the car made 663rwhp and 649 ft/lbs on pump gas and 8psi. Properly corrected (SAE) the car actually made 689rwhp but even that number is a bit off due to the extreme heat in the shop (Dyno graphs show it was 96 degrees lol). It is no secret how Turbo / FI cars hate heat so we plan on doing a final pull or two in "Normal" conditions if the opportunity presents itself this week.
At just 5psi the car made 581rwhp and 564 ft/lbs in "Valet" or base-boost mode and then we followed that up with the 8psi pulls today. We didn't push the car in terms of any further peak numbers due to the rough conditions in the shop today but some timing tweaks really bumped the torque in the mid-range a substantial amount.
The 8psi graph is here:
The 8psi graph as compared to stock is here:
The 8psi graph compared to the 5psi graph is here:
Here is an interesting graph showing the "Lag" or spool-up similarities between our Twin-turbo Kit at 8psi and a Cammed / Header / D1 Procharged 2010 SS 6-speed also running 8psi:
Here is a graph comparing the TT kit to a BIG heads/cam car with a FAST and all the usual bolt-ons:
I am working on getting the actual kit pics off the camera and pricing and options and such up this week as well. In the mean-time I wanted to get the graphs posted and info on what is included in the kit posted up. The "Basics" of the kit are as follows:
1. Garrett / Tial Turbos (Your choice of GT3076R / GT3582R / GT3586R) all come standard Ball-bearing and only option is a Billet / HTA upgrade. All three turbo options are the same price so up to a 62mm wheel is "Standard".
2. Tial V-band housings in 1.03 or 1.06 A/R standard.
3. Garrett compressor covers featuring 4" inlets standard.
4. 4" Thick Bar & Plate FMIC Core.
5. Tial 44mm WG's and Tial "Q" Blow-off Valve.
6. 304 Stainless hot-side tubing.
7. Aluminum cold-side tubing.
8. Aluminum Intake Tubing to K&N Filters.
9. 3" Stainless downpipes to 3" or 2.5" exhaust.
10. Vac block & PCV / Catch-can included.
11. Oil return pump and timer.
12. Upper / Lower intercooler deflectors
13. Polished aluminum charge-pipe (Can be powdercoated as well)
14. EV14 91Lb Injectors and NEW MSD Boost-a-Pump
I am sure there is more but you get the idea...
Pics to come and will be added with the graphs here:
http://www.flickr.com/photos/ipsmoto...7624216913609/
IPSjeff is offline   Reply With Quote
Old 06-23-2010, 04:44 PM   #2
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
Edit: What turbo was used on this test?
Heliwrench is offline   Reply With Quote
Old 06-23-2010, 04:51 PM   #3
IPSjeff
Drives: 2009 ZR1
GT3582R's w/ 1.03 A/R
Old 06-23-2010, 04:54 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
I remember seeing this setup being made when I got my car dyno tuned there.... very sick setup.
I may trade my motor for a stock ls3 just to get my hands on one of these kits this winter....
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 06-23-2010, 05:10 PM   #5
Heliwrench
Heliwrench's Avatar
Kit says it comes with a boost a pump... do you need one to run the low 5 psi?
Old 06-23-2010, 05:11 PM   #6
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
This is the best resulting kit I've seen so far for Camaros. Top notch components and from the result, it looks well engineered.
Z_Rocks is offline   Reply With Quote
Old 06-23-2010, 05:13 PM   #7
Z_Rocks
Z_Rocks's Avatar
It's good to keep the fuel pressure up but I don't care much for BAP, when it burnt two of my fuel pumps (That was the fault of the installer setting voltage too high);
Old 06-23-2010, 05:18 PM   #8
Z_Rocks
Z_Rocks's Avatar
Jeff, how do you control the boost, via WG spring? So you provide different springs or Boost controller?
Don't forget pic of FMIC.
Old 06-23-2010, 05:20 PM   #9
SonnyakaPig
Drives: C63 P31
The results for this kit look great! Very impressive.
Is the 795 hp number at the crank when the kit is running 8 psi?
SonnyakaPig is offline   Reply With Quote
Old 06-23-2010, 05:22 PM   #10
SonnyakaPig
Drives: C63 P31
You love you some FMIC's.
Old 06-23-2010, 05:23 PM   #11
Z_Rocks
Z_Rocks's Avatar
These are all RWHP/RWTQ
Old 06-23-2010, 05:26 PM   #12
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
We have the standard dual pump drop in (CTSV) dual intake setup for those whom do not wish to use a BAP and to have a 800hp capable fuel system. However it is our opinion that the most obvious solution to increase fuel flow rate for this increase in horsepower output is initially to add a BAP.
Regards
IPS Brandon is offline   Reply With Quote
Old 06-23-2010, 05:26 PM   #13
Z_Rocks
Z_Rocks's Avatar
It's more of a Concern than love!
Old 06-23-2010, 05:28 PM   #14
IPSjeff
Drives: 2009 ZR1
This car it is controlled by WG spring but you can easily add in a boost controller. Most would probably just leave it at 8psi but if you wanted a base spring at the 5psi mark and add in a controller to bump it to 6-8psi from inside the car that is no problem at all
Oh, and once our revised deflector is finished I will post up a few FMIC pics.
Jeff
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
2010 LS3 stock short block $2,500? nuptualnemesis V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 06-26-2011 12:24 AM
What's the top end on a stock LS3 2010 Camaro BoomBoomKid USA - California 34 06-25-2010 05:18 PM
LS3 Tune Only Results .. Also stock LS3 vs. L99 dyno graph LPFSTheFett Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-05-2009 08:04 AM
