Old 06-23-2010, 08:59 PM   #1
BIGK909
BIGK909's Avatar
Drives: 2010 Camaro LT/RS VR
H&R wheel spacers. Good idea or bad idea?
I just lowered my v6 using the H&R springs, but I want the tires to be more flush with the wheel wells. I was playing with the idea of getting the H&R wheel spacers, but im not sure if this is such a good idea. I just want some opinions on whether this is worth doing or not.
BIGK909 is offline   Reply With Quote
Old 06-23-2010, 10:42 PM   #2
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
I wouldn't recommend any spacer more than 1/4" thick. Also depends on how much lug stud protrudes, and to make sure you engage enough threads when you tighten the lug nuts down.
Fquick.com/NineBall
Old 06-24-2010, 01:12 AM   #3
BIGK909
BIGK909's Avatar
What if i used the hubcentric spacer and i got longer lug studs. Would there still be risk of problems or would that be the safest option to go with?
-MRT V1.0, H&R Springs, Injen CAI
Old 06-24-2010, 04:11 AM   #4
Kreature
Kreature's Avatar
Drives: Summit White 1LT/RS
i too would like any thoughts or opinions on these. i totally have no idea what spacers are except that they just spread your rear wheels more far apart. my friend gave me the idea just last night and i decided to do some research but i would rather listen to a car savy man such as nineball.
Kreature is offline   Reply With Quote
Old 06-24-2010, 07:11 AM   #5
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
I ran 1/2 hubcentric spacers on my 04 cobra. I used longer moroso studs and open lugnuts.
Worked fine.
No matter how thick you go I would suggest putting in longer/stronger studs.
g-townmach is offline   Reply With Quote
Old 06-24-2010, 01:34 PM   #6
BIGK909
BIGK909's Avatar
Worked fine.
Did you ever take it down the strip or race it?
Old 06-24-2010, 02:24 PM   #7
KnightRider
KnightRider's Avatar
Drives: Black 2SS/RS M6
I'll be getting a set too when they become available. My car is lowered an inch with Eibach and I don't like how sunken-in the wheels are right now. A set of 20mm-25mm should push them flush with an aggressive stance. The DRM series are hub-centric, bolt-on type with studs build-in so you don't need to bother with longer studs.
As a safety measure, you have to re-torque them once in a while to ensure they're tightened. Only downsides are the increased unsprung weight and the added stress on the hub, which might result in a shorter life span on the hub bearings.
KnightRider is offline   Reply With Quote
Old 06-24-2010, 04:12 PM   #8
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Not on a drag strip.
h&r, spacers, tire, wheel
Price Gouging Dealers KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 1520 08-24-2016 12:59 PM
Is it a good idea to preorder the Camaro. DGordon Camaro Price | Ordering | Tracking | Dealers Discussions 46 03-16-2009 08:30 AM
G8 GXP mini review - some good some bad Crowley General Automotive + Other Cars Discussion 6 11-26-2008 08:38 AM
Camaro... good idea as 1st car? GameOver620 5th Gen Camaro SS LS LT General Discussions 74 10-07-2008 09:06 AM
Is alternative energy as we know it today a good Idea? Angrybird 12 Off-topic Discussions 15 08-09-2008 03:18 AM
