JUICEDMOTORSPORTS
Old 06-26-2010, 05:32 AM   #1
Hephaestus1
Hephaestus1's Avatar
Drives: 2010 2LT/RS A6
Question Question about RS DRLs--PWM driven by BCM??
I finally got the Helm service manuals, as I have been salivating about how to "fix" the DRL operation (to my tastes). Since I got the AAC P13 LED bulbs, I see the DRLs as DRL/Fogs, so I plan to install a forced, manual switch which allows me to decide when/if they are on (I do NOT want the side-marker harness solution).
In reading about the RS DRLs, I came across some very disturbing verbiage and schematics which show the BCM providing unfused, Pulse-Width Modulated "power" to the DRLs. Is this correct? Why would any engineer in his right mind ever power a DC light bulb with half-baked AC? Surely there has to be another component in the path between the BCM and the DRLs that I'm missing...
Thanks,
Brian K.
Hephaestus1 is offline   Reply With Quote
Old 06-26-2010, 07:43 AM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Yup, PWM
http://www.camaro5.com/forums/showpo...9&postcount=41
http://www.camaro5.com/forums/showpo...1&postcount=50
Old 06-27-2010, 01:20 AM   #3
Hephaestus1
Okay, thanks Slick. At least I've not completely lost my mind. That fracks up my original "easy" plan, have to do some more noodling.
Sounds like they're sacrificing bulb life for a simpler way to run the bulbs in a "reduced-power" mode.
Old 06-28-2010, 01:37 PM   #4
Mag-Tex
Drives: 2010 Camaro 2LT/RS
The DRL bulbs may, in fact, be PWM. But I can verify that if you put 12v DC direct to them, there is absolutely no difference in look or brightness. I have mine on at night via fuse block feed and cabin switch (with diode to prevent backfeeding BCM). In the daytime there is no difference if I turn the switch off. Been this way almost a year with no problem, too.
Mag-Tex is offline   Reply With Quote
Old 06-28-2010, 04:50 PM   #5
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
There is another solution other than the sidemarker harness that will allow you to do what you want.
fieldgoal00 is offline   Reply With Quote
Old 06-29-2010, 12:48 AM   #6
Hephaestus1
Good info there, Mag. Hmmm, no difference between DC and PWM? Sounds like the BCM is running at least 88% duty cycle. Did you grab your fuse from the IP block, or under hood?
Fieldgoal, I like making the "art" mine, to a degree. And I'm not bad with a soldering iron (Next "planned" project is a T-bar gear selector with ray-skin wrap)
Old 06-29-2010, 01:07 AM   #7
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
If the DRL's are anything like GM's other DRL's, i would think its closer to 70% based on past experimenting. Im talking to the bulb though, not BCM. I could be wrong though with the camaro though, thats just how it was for me in past GM DRL cars.
2010 Camaro 2SS/RS/LS3 -Black on Black - Kooks 1-7/8 Headers, Dyno Tuned, ADM Race CAI, QTP Cutouts, Hurst Short Throw, SJM Line Lock, Alpine PDX 1.1000, (2) Alpine Type R's, ...Soon to be cammed!
HaZe_X is offline   Reply With Quote
Question: Cars only driven by one wheel? JMROD General Automotive + Other Cars Discussion 17 08-29-2010 05:04 PM
1991 RS question bouncertime 3rd Generation Camaros 11 03-03-2009 02:25 PM
1989-1992 RS question Zabo 3rd Generation Camaros 5 02-12-2009 11:42 PM
Stripe Opinion and RS Package Question AirBoyzT Cosmetics and Lighting Modification Discussions 27 01-23-2009 02:48 AM
Fbodfather/ Anyone who's driven the new Camaro... question? (just curious) scotchsride09 5th Gen Camaro SS LS LT General Discussions 13 09-23-2008 07:45 PM
