ADM PERFORMANCE
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 06-26-2010, 04:28 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010camaro
bumpstops-cut or no cut
looking for pete and mikes input here.. install pedders coilovers /sways / diif bush/tie rod ends and few other parts.. i am looking to drop approx 1 1/4 and also have a razzi kit...will be installing next week- my installer does not like to remove bumpstops due to ground effects issue and has seen tires get ripped up inside fenders{ there is a recent post of someone who has done this} ..whats the consensus on this [ someone mentioned trimming them down }...how about it.. thanks:updown:
mikepage0007 is offline   Reply With Quote
Old 06-26-2010, 04:39 PM   #2
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
HMMMMMM???
Fishdadddy is offline   Reply With Quote
Old 06-26-2010, 05:17 PM   #3
Mr Twisty
Mr Twisty's Avatar
Since you have coilovers it's not an issue. The bumpstop issue is with the factory struts/shocks with drop springs.
Do you have factory wheels? If you do, tire to fender clearance is ok at 1 1/4 drop. You'll need to baby that chin spoiler over speed bumps tho
If you have aftermarket wheels and the offset is too far out you can get into the fenders.
How low is that Razzi kit compared to stock?
...Mike & Pete aren't on as much on weekends.
-- Benjamin Franklin
Great Racing Quotes
"Never run out of real estate, traction and ideas at the same time."
"I was doing fine until about mid-corner when I ran out of talent."
"Don't brake until you see God, just don't meet him"
Old 06-26-2010, 08:30 PM   #4
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Have no fear, Mike is here! Actually i am probably on the forums about 10 ours or so on the weekends. Just sometimes at odd hours.
The Xa coil overs are unique. And under no terms do you want to cut the bump stops. Why? One of the reasons our coil overs offer the best ride of any coil over out there is we do not use the lower spring seat to adjust height. We do, however, have an adjustment procedure to out a small amount of compression on the coil to keep it tight when it is in the air. We adjust our height by threading the strut in/out of the lower mounting brackets. Therefore, you have the same great wide quality literally at any height you want to set her at. It seems to average about 1.5 inches is the drop of choice. But put her where you would like.
I have a DIY manual that has just been upgraded. Send me your email, and I will send it to you.
Thanks
mike
dms
Rob Anderson - Business Development
rob@peddersusa.com
Info@PeddersUSA.com is offline   Reply With Quote
Old 06-26-2010, 08:36 PM   #5
Fishdadddy
Fishdadddy's Avatar
Mike,
Can you send me that manual too. Mine will be delivered monday.
Thanks
Old 06-27-2010, 10:59 AM   #6
Info@PeddersUSA.com
Originally Posted by Fishdadddy View Post
Mike,
Thanks
Need to know who you ordered them from and your email address.
thanks
mike
dms
rob@peddersusa.com
Old 06-27-2010, 06:12 PM   #7
mikepage0007
Drives: 2010camaro
thanks mike , i should be getting those parts from you this week..could you send me the manual ..stoxpix@comcast.net...also razzi will def be low up front...and i am now stock wheel but going savini or lexani in near future{ as large tire as i can fit , will stay with 20,s though}...my installer said same , he would rather i bottom out on stops then tear into tires or gf kit...but i read other posts where guys said they cut...wanted to know where pedders stood on this..i feel even better about extreme perf doing my pedders, as they said same as mike..i would like 1 1/2 , just feel nervous with gf, i see pics of petes front and that looks scary close to ground..i will print out post and give to my shop.. kudos to pedders for quik reply
Old 06-27-2010, 06:18 PM   #8
Fishdadddy
Fishdadddy's Avatar
Mike,
i bought the Xa's from a forum member that never opened or used them. I sent you a PM with my email address.
Thanks
Old 06-27-2010, 06:23 PM   #9
mikepage0007
Drives: 2010camaro
b4 pics, 1 1/2 is really gonna set this puppy down..i will give it a try..
Old 06-28-2010, 10:23 AM   #10
Info@PeddersUSA.com
I love the look of your ground affects. She is going ot look really aggressive at 1.5 inch drop of so!
mike
dms
rob@peddersusa.com
Old 06-28-2010, 08:02 PM   #11
Fishdadddy
Fishdadddy's Avatar
Mike,
Thanks for the updated instruction manual. I received my Xa's today. Can't wait to get them on the car. This new manual will definitely help. There seems to be alot more info. and pictures.
Old 06-29-2010, 02:20 AM   #12
Info@PeddersUSA.com
Mike,
Hope it works well for you.
mike
dms
rob@peddersusa.com
Old 06-29-2010, 07:20 AM   #13
mikepage0007
Drives: 2010camaro
recd , thanks mike
Old 06-29-2010, 07:47 PM   #14
Info@PeddersUSA.com
recd , thanks mike
No porblem. So read it. There will be a test in a couple of days!!
If you guys can give me some feedback on it, I would appreciate it. Send it to my pm or if it is lengthy, to my email at mike.white@peddersusa.com
Thanks guys. And drive safe and have fun!
mike
dms
rob@peddersusa.com
Old 06-29-2010, 07:53 PM   #15
Info@PeddersUSA.com
I really love the look of your Camaro. Can you send me some pictures of her dropped so I can add it to my collection?
So how about this height?
AFTER PICTURES SET UP FOR 75% AGGRESSIVE STREET, AND 25% AGGRESSIVE DRAG
This was a little over 1.5 inches. The back end is a little higher than I like, but he needed some room for some drag radials.
mike
dms
rob@peddersusa.com
Old 06-30-2010, 07:19 AM   #16
mikepage0007
Drives: 2010camaro
mike
dms
i will send you pics when done ,also post front and rear ht...i agree looks to high in rear..i feel you should not see a huge diff from front to rear, but this appears obvious..just my iom...
Old 07-01-2010, 05:32 PM   #17
Info@PeddersUSA.com
You will notice the rears are different between the 2 pictures. Customer saw the rears and wanted it taller for a big drag radial.
mike
dms
rob@peddersusa.com
Old 07-02-2010, 07:24 AM   #18
mikepage0007
Drives: 2010camaro
i thought it was taller in 2nd pic.., mike i will be going with lexani lx15,s , 10in on rear , how large a tire can i use..there is mention of offset with wheel protruding past fender with lexani..any input...thanks,also sent you pm on parts delivery
NFL players raising hell about Pay Cut Zeus The Sports Lounge 25 03-11-2010 04:01 PM
pay cut... have to downgrade Brokinarrow Off-topic Discussions 24 12-29-2009 10:10 AM
Just cut 'em off CBH Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 12-06-2009 01:26 PM
NEW CAMARO WINDOW TINT CUT OUTS PUT ON YOURSELF. AutobotSS Exterior Parts & Accessories 17 08-30-2009 12:24 PM
Ever see a plane cut in half? (Pics/Vid ARE UP) Zabo Off-topic Discussions 6 05-18-2009 10:09 PM
