Old 07-25-2010, 09:47 AM   #253
formare
Suspension by Pedders
formare's Avatar
Drives: Synergy Edition 13.71@102 1.95 60'
Originally Posted by MustangConvert View Post
And that is why I have only upgraded the air filter. Granted it is going to be awhile before I get a turbo/SC (call me paranoid, but waiting 'til the warranty runs out), but no need to to spend 1k+ when I'm going to be replacing it down the road. Good advice for those that hadn't thought about it.
Can't wait to see those dyno numbers.
Are you waiting for 100,000 mile power train warranty to run out before the turbo install?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 07-25-2010, 11:09 AM   #254
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Drives: Mikes Hard Lemons
Ha!
CAMAR0 is offline   Reply With Quote
Old 07-25-2010, 11:10 AM   #255
CAMAR0
Loose is Fast!
CAMAR0's Avatar
If he has a smartphone he could do rough runs with an app to compare.
Old 07-25-2010, 02:45 PM   #256
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Max, Just curious. What did the inside of the maf tube look like? Is it just a straight tube or is there something inside it?
ROD1 is offline   Reply With Quote
Old 07-25-2010, 06:24 PM   #257
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
Rod1, are you asking me or MaxKamai? This is a picture of my intake and if I recall, it's just straight through. What are you looking for? Somewhere to inject your N2O?
Z Madness is offline   Reply With Quote
Old 07-25-2010, 07:36 PM   #258
ajax.
ajax.'s Avatar
Drives: 12SS,12SRT8,14COPO,77Vette
Couple questions. to verify the single turbo gives the V6 454 and twin turbo gives it 750???? Can this be done to a Automatic transmission?
ajax. is offline   Reply With Quote
Old 07-25-2010, 07:49 PM   #259
Z Madness
Z Madness's Avatar
Turbo kit is for either transmission. They are only selling the single for the V6 and the twin for the V8's. The single has the capability of much more boost, it's more limited by what the engine can safely handle.
Old 07-25-2010, 09:41 PM   #260
spoone123
Next is SS camaro.....
spoone123's Avatar
Drives: 2010 Camaro LS, Rally yellow
This single turbo give you like 7 PSI isn't it? and you don't have to upgrade any transmission etc? Since i have LS I think i have to get Z rated tires
Airraid CAI, Havoc Rims, Perreli tires, Remote start
spoone123 is offline   Reply With Quote
Old 07-25-2010, 09:50 PM   #261
ajax.
ajax.'s Avatar
Thanks for the quick reply and great videos btw. I was just checking them out. What kind of HP are you getting out of the system?
Old 07-26-2010, 12:57 AM   #262
Z Madness
Z Madness's Avatar
350 rwhp.
Spoone- if you have an LS, you will be speed limited to 118. You will need Trifecta to turn it off if you plan to exceed that level. Wastegate came with a 7psi. Spring, but during the testing, max boost was just under 5 psi. This was designed for a completely stock motor.
Old 07-26-2010, 02:59 AM   #263
SDCamaro10
SDCamaro10's Avatar
Drives: 2010 Camaro 1LT RJT
Just remember guys, you wont be able to go much higher then what Z is already at. Start getting up at those boost ranges and thats when fuel management comes in to play and you'll need to do some upgrades to get it to work. The LLT being direct injection is why most companies havent even tried to give us FI yet. Anyways.. i wouldnt go any higher than 6psi unless we see some aftermarket fuel management modifications(injectors, pumps, etc).
SDCamaro10 is offline   Reply With Quote
Old 07-26-2010, 04:14 AM   #264
Z Madness
Z Madness's Avatar
Dyno Video
In case anyone is interested...
Old 07-26-2010, 04:52 AM   #265
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
that thing sounds SOOOOOO SICK!!
rhd is offline   Reply With Quote
Old 07-26-2010, 05:46 AM   #266
King Sun
Casual Camaro Owner
King Sun's Avatar
Drives: 2010 Black LS V6
sooo we are basically making stock l99 power with 5psi??? oh my
King Sun is offline   Reply With Quote
Updated - Twins almost here! - STS (Twin Turbo) Camaro SS 5th Gen SS Forced Induction - V8 249 08-19-2012 09:45 PM
Granatelli / Turbo Tech Twin Bottom Mount Turbo Systems Granatelli Forced Induction 20 11-30-2010 06:47 PM
Why TT over SC? Jefe's SS Forced Induction - V8 10 10-02-2010 03:14 AM
STS Remote Mount Turbo Kit for V6 ZNOLMT Forced Induction - V6 102 06-09-2010 12:18 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 01:29 PM
