HURST
Old 08-04-2010, 06:22 PM   #337
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
Originally Posted by PoorMansCamaro View Post
Oh, so them i would get $600 off the price for sts, right?
I would assume so.
As far as cost to install, I did it myself in my little garage. So I can attest that it can be done (but I would suggest a second pair of hands). But, if you can get it installed for $6700 including the kit ($5,995), I would say that's a great deal. It would be worth $800 to get it done by a shop that will back up their install. Can you believe I paid $500+ bucks just shipping to Hawaii!
Z Madness is offline   Reply With Quote
Old 08-04-2010, 06:32 PM   #338
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
$500! Wow! Yeah, I would love to tackle this with a buddy. I back up my own work
Old 08-04-2010, 08:48 PM   #339
Z Madness
Z Madness's Avatar
How's this, I just dyno'd my 2000 Z-28 (LS1) that has an SLP intake/MAF, long tube headers/exhaust, Pro. Prod. Intake/Throttle Body, Comp Cam, MSD coils/wire, etc. and she dyno'd at......350 rwhp. Of course, its a lot lighter that the 5th gen but I found it interesting that my two Camaro's dyno'd in the same. Says a lot about these engines and what a Turbo can do.
Old 08-04-2010, 09:11 PM   #340
Dyk-NO
Trust me I'm a Scientist.
Drives: My wifey ;P
What your next step after this Z? and your target hp?
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator.
Dyk-NO is offline   Reply With Quote
Old 08-04-2010, 11:07 PM   #341
Z Madness
Z Madness's Avatar
Boost controller and meth/water kit to run low boost/high boost, probably 5 and 8 psi. Hopefully that gets me to the 400 rwhp. Then, might add short-tube headers with the Solo Hi Flow Cats. Still debating on that though since that would be another $1500! I was thinking about polishing the intake manifold but waiting to hear the results from BMWdon and others. I'll be pretty happy with 400 rwhp and probably just add some gearing and figure that should keep up with most of the NA V-8's out there. Just having fun with the V-6! 1LS ftw.....
Old 08-05-2010, 03:11 AM   #342
Dyk-NO
Drives: My wifey ;P
Old 08-05-2010, 09:13 AM   #343
LosingReality
LosingReality's Avatar
Drives: Camaro LS
I would assume so.
Wow, I used to live on Oahu.....Military guy, so you probably hate me. Just messing with ya.
$500 shipping is rediculous.....So you pretty much DID pay to have it installed then lol.
Do you NEED the meth kit to run it at the boost your running it at right? Basically asking if i got this installed would I NEED the meth kit?
LosingReality is offline   Reply With Quote
Old 08-05-2010, 10:32 AM   #344
PoorMansCamaro
Drives: Really Slow
i'm pretty sure the answer is no, on the meth kit. i think he just wants to get his car at 400rwhp with it.
Old 08-05-2010, 10:57 AM   #345
Mach
Mach's Avatar
Drives: White M6 1LT RS
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 08-05-2010, 11:16 AM   #346
LosingReality
Drives: Camaro LS
Mybe im not even sure what a meth kit does....Its for cooling no?
Old 08-05-2010, 11:22 AM   #347
FloydSummerOf68
FloydSummerOf68's Avatar
Drives: Corvette
Yeah, a meth kit cools the intake charge and you can reliably run higher PSI.
FloydSummerOf68 is offline   Reply With Quote
Old 08-05-2010, 11:26 AM   #348
PoorMansCamaro
Drives: Really Slow
I'm not too familiar with meth kits. i'm sure Z can fill us in with more detail. But i think what it does is reduce air inlet temps, increase charge density, helps safely run higher boost pressure, and suppress detonation which will allow the utilization of more timing and boost. If that makes any sense to you. lol
Old 08-05-2010, 12:55 PM   #349
LosingReality
Drives: Camaro LS
Yep, kinda like overclocking a computer? More heat produces needs more cooling.
Old 08-06-2010, 09:23 PM   #350
Double G
Houston Boy
Drives: Inferno Orange V6 2010 Camaro
So I'm kinda curious, how many of you guys out there have the BA STS V6 Camaro?
Double G is offline   Reply With Quote
Updated - Twins almost here! - STS (Twin Turbo) Camaro SS 5th Gen SS Forced Induction - V8 249 08-19-2012 10:45 PM
Granatelli / Turbo Tech Twin Bottom Mount Turbo Systems Granatelli Forced Induction 20 11-30-2010 07:47 PM
Why TT over SC? Jefe's SS Forced Induction - V8 10 10-02-2010 04:14 AM
STS Remote Mount Turbo Kit for V6 ZNOLMT Forced Induction - V6 102 06-09-2010 01:18 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
