BeckyD @ James Martin Chevy
Old 08-18-2010, 03:22 PM   #393
Edge.128
Edge.128's Avatar
Drives: 2010 Camaro LS
i just re-read this and your other thread and see that. thanks. some good numbers no doubt..... now just have to save for a few years.....
2010 Summit White Camaro LS / M6
MRT V2.0
Edge.128 is offline   Reply With Quote
Old 08-18-2010, 03:38 PM   #394
Edge.128
Edge.128's Avatar
how is the lag when accelerating?
MRT V2.0
Old 08-20-2010, 12:45 AM   #395
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
Not bad. The turbo starts to spool pretty quickly and can get up to 5 psi by about 3,500 RPM's.
Z Madness is offline   Reply With Quote
Old 08-20-2010, 04:47 AM   #396
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
now all you need is that 100 shot of NOS. that would be a LOT of tq.
trudawg660 is offline   Reply With Quote
Old 08-23-2010, 09:01 AM   #397
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
anything Camaro-related happen this weekend?
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 08-23-2010, 09:09 AM   #398
FloydSummerOf68
FloydSummerOf68's Avatar
Drives: Corvette
Looking forward to the new 8psi meth numbers
FloydSummerOf68 is offline   Reply With Quote
Old 08-23-2010, 08:59 PM   #399
Z Madness
Z Madness's Avatar
Okay, this is what happened this weekend. Scheduled dyno time on Saturday (same dyno pack). Did 2 pulls for a baseline and got essentially the same numbers as the last time, which is good. We start playing around with the Boost controller to try and set the high boost. Once we think we have it set at 7 psi., we attemp a run and but the car starts to seriously lean out quickly at about 3,500 rpm, so they dyno guy backs of quickly. One more try and same thing. We try to turn off high boost but we still have the same problem. Disconnect tube with MAF and meth injector and clean it out, but no change and then decided to stop the dyno (was being charged by the hour). Didn't have a chance to look at it on Sunday (autocross day) but did send info to STS and Trifecta for any input. Spoke to Rick at STS and received some information from Trifecta and I have some things to check out, but probably not until Tuesday evening.
Old 08-23-2010, 09:43 PM   #400
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
If the grand national gnx way back 1987 could handle 10psi does this mean at some point we could see 10 psi tunes?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 08-23-2010, 10:21 PM   #401
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
i think with suporting mods we could see 10psi but you cant compare the gnx to the camaro, the gnx was build as a turbo motor our v6 wasnt.
rhd is offline   Reply With Quote
Old 08-25-2010, 12:56 AM   #402
Double G
Houston Boy
Drives: Inferno Orange V6 2010 Camaro
oooooo I want this meth to work soo bad!
Double G is offline   Reply With Quote
Old 08-25-2010, 01:58 AM   #403
Z Madness
Z Madness's Avatar
Me too. I got the base boost working again. Seems like MAF location affected A/F ratio. However, when high boost activated, car leaned out quickly. Ugh. Still working...
Old 08-25-2010, 07:45 AM   #404
FloydSummerOf68
Drives: Corvette
With the proper build anything is possible.
There are 4th gen V6's running 18+ psi with no problems.
Old 08-25-2010, 08:45 AM   #405
rhd
dirtbag
rhd's Avatar
i want to swap out pistons when i do my set-up and see if i cant get 650hp out of 15-20psi
Old 08-25-2010, 02:50 PM   #406
stand-al0ne
Rev Couture
you'll need to swap out more than that i'm afraid. But dulling down the compression ratio to 8.5 :1 or so will be necessary to help get those boost numbers up. I'm just wondering how the motor will respond to lower compression pistons when not under boost. Reading the specs on the motor, it already sucks spend exhaust back into the cylinder to help cool and improve efficiency by detonating any unused fuel from the original compression/ignition stroke.
That said, the car may run very rich with alot of bog when not under boost if you went with lower compression-ration pistons., well ones that are as low as 8.5:1...
Maybe 10.1 : 1 ratio pistons would be enough to get higher boost #'s without changing the engine's normal behavior...
Updated - Twins almost here! - STS (Twin Turbo) Camaro SS 5th Gen SS Forced Induction - V8 249 08-19-2012 10:45 PM
Granatelli / Turbo Tech Twin Bottom Mount Turbo Systems Granatelli Forced Induction 20 11-30-2010 07:47 PM
Why TT over SC? Jefe's SS Forced Induction - V8 10 10-02-2010 04:14 AM
STS Remote Mount Turbo Kit for V6 ZNOLMT Forced Induction - V6 102 06-09-2010 01:18 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
