Solo Performance
Old 07-01-2010, 10:07 AM   #71
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Old 07-01-2010, 12:58 PM   #72
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Originally Posted by Z Madness View Post
Intercooler came in today so I decided to put it on and take some glamour shots for everyone. Didn't have time for a test drive. Hopefully tomorrow afterwork.
Victory!!!!!! Well almost. Thank you! Thank you! Thank you! I'm so excited I can't even see straight.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 07-01-2010, 01:11 PM   #73
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Drives: Mikes Hard Lemons
Looks awesome so far!!!
CAMAR0 is offline   Reply With Quote
Old 07-01-2010, 01:17 PM   #74
SIXJAK
SIXJAK's Avatar
Thank you. That seems to be about right
Originally Posted by scrming View Post
Think they were around $320ish...
K Thanks. Just trying to make sure I'm getting a good price.
Old 07-01-2010, 01:18 PM   #75
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
That is so cool, I see you got some more goodies on you're Camaro, I really like the blue color on those calipers.
You are definitely an inspiration to all of us with the V6 engine.
christianmotox is offline   Reply With Quote
Old 07-01-2010, 02:57 PM   #76
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
Thanks, I used StopTech on my LS1 and thought they are great brakes and were cheaper then Brembo or Baer. They are 6 piston fronts, 4 piston rears, with 12 inch rotors. Should look great once I get my Forgeline Rims installed.
Z Madness is offline   Reply With Quote
Old 07-01-2010, 02:59 PM   #77
Z Madness
Z Madness's Avatar
Originally Posted by CAMAR0 View Post
What are the dimensions of the intercooler?
Did not measure but the piping is 3" going in and out and the its probably about as wide as the radiator but obviously a little shorter. Sorry, if I take the bumper off again I'll try to remember to measure.
Old 07-01-2010, 03:41 PM   #78
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
:popc orn:
rhd is offline   Reply With Quote
Old 07-01-2010, 03:56 PM   #79
darwin
darwin's Avatar
Drives: 1SS/RS 2010 Camaro
i was going to do a setup like ROD1 but if i see one of these turbos with sound, i am going to be dissapointed i didnt get it. i can tell this turbo will be fast.
darwin is offline   Reply With Quote
Old 07-01-2010, 04:03 PM   #80
Abygale
Abygale's Avatar
Drives: .
Z, did you have any problem mounting the front fascia over the intercooler? Do you have any pictures from the front of the car after everything has been put back on?
Abygale is offline   Reply With Quote
Old 07-01-2010, 04:44 PM   #81
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Where does the oil come out of on the motor when it gets pumped back to the turbo?
Old 07-01-2010, 08:27 PM   #82
Z Madness
Z Madness's Avatar
I was definately impressed with Rod1's 1/4 mile time. But I must tell you, this Turbo sound is definately different (and noticable) compared to stock. Sound will be posted soon!
Old 07-01-2010, 08:30 PM   #83
Z Madness
Z Madness's Avatar
No problems with front facia. If you look at the pictures, its inside the bumper support and above the bottom support, which the facia goes right around. Actually, there is a lot of room in there.....wonder if GM had plans for this space??? I'll get a picture when I get home of the front. Right now I have the stock facia and just took off the lower "grille" to show off the bling. I am actually waiting for a custom front facia from Unrestricted Motorsports which has a bigger lower opening which should show the intercooler nicely through a mesh grille. Check tomorrow for pics of the stock bumper.
Old 07-01-2010, 08:38 PM   #84
Z Madness
Z Madness's Avatar
Right below the oil filter is the pressure sensor and you put in an included t-fitting. From there, they provide a 1/4 in. stainless steel line that routes along the center of the car (with the wastegate hose) and the after you get over the rear, the stainless goes to the top of the turbo on the passenger side (wastegate on driver side). The return hose goes from the bottom of the turbo unit and up along the passeger side (like the intake piping) which is then hooked-up to the STS oil pump which is mounted in the passenger front wheel well (I think I included a picture). You then attach a line from the pump back to the motor and the oil is returned via a modified oil fill cover (you should be able to see this in one of the pictures I posted).
Updated - Twins almost here! - STS (Twin Turbo) Camaro SS 5th Gen SS Forced Induction - V8 249 08-19-2012 10:45 PM
Granatelli / Turbo Tech Twin Bottom Mount Turbo Systems Granatelli Forced Induction 20 11-30-2010 07:47 PM
Why TT over SC? Jefe's SS Forced Induction - V8 10 10-02-2010 04:14 AM
STS Remote Mount Turbo Kit for V6 ZNOLMT Forced Induction - V6 102 06-09-2010 01:18 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
