Old 06-28-2010, 04:50 PM   #1
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
My Camaro is pulling timing!
2SS/RS 6.2L L99 with A6. When I go WOT it pulls timing from a dig. I have TM out or I think I have it out and TC turn off! I am tunning with HPTuners. Any ideas? I was going to attach a log but it will not let me.
2016 ZO6 2LZ A8
CamaroFest II-III-V
Pro Street is offline   Reply With Quote
Old 06-28-2010, 05:59 PM   #2
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
There are many things that can cause timing to get retarded. Burst KR at launch isw fairly common. Very warm intake air temps will cause timing to be pulled under WOT loads. Insufficient octane relative to the tune will be cause for timing retard. Poor quality fuel is another cause. Knock sensors correctly or incorrectly can cause the timing to be reduced (usually overkill too). Good logs with the proper parameters loggged should tell.
2SSCAMARO is offline   Reply With Quote
Old 06-29-2010, 12:22 PM   #3
kelley@vectormotorsports
Drives: 2009 Pontiac G8 GT
Are you sure it is pulling timing? Many cars with the A6 will dive into the part of the timing table that many people do not change. For example at 1600 RPM and .64 grams/cyl of air there is only 9 degrees.
Try to modify the table at lower RPM levels and higher load levels and check it again. If you send me a scan I can tell you for sure. I can read any scan you send me, I don't know what software you are using.
kelley@vectormotorsports is offline   Reply With Quote
Old 06-29-2010, 01:06 PM   #4
DSteck
Drives: 2006 Corvette Z06
Aside from logging total advance... log all of the spark adders/retards to see what sources are pulling timing out.
What conditions are you seeing the timing get pulled out?... A log would help.
DSteck is offline   Reply With Quote
Old 06-29-2010, 01:39 PM   #5
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
Sent you a PM.
2016 ZO6 2LZ A8
CamaroFest II-III-V
Old 06-29-2010, 01:41 PM   #6
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
Where can I send you a log? I can not upload a log here.
Thanks!
2016 ZO6 2LZ A8
CamaroFest II-III-V
Old 06-29-2010, 02:49 PM   #7
Sent you a PM.
Got it. The car is doing as I suspected. Under 1700 RPM you are in a part of the timing table that is very low.
Actually you are at .64 gm/cyl at only 800 RPM. Not very much timing down there!
Bring those numbers up, but dont get crazy. Keep them in the high single digits to start.
Good luck and happy tuning!
Also, you have zero upshift torque management. I would just reduce it by 50% or so. What intake is on the car? You are pulling a 12 Kpa depression in the manifold, thats huge.
Old 06-29-2010, 03:33 PM   #8
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
Thanks Kirk!
I will add timing down in those areas! It stll has the stock air filter system.
Thanks again!
2016 ZO6 2LZ A8
CamaroFest II-III-V
Old 06-29-2010, 04:23 PM   #9
DSteck
Holy crap... and I thought 3kPa was bad!
Old 06-29-2010, 06:02 PM   #10
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
That is why everyone says they can feel a hugh change with a CAI!
2016 ZO6 2LZ A8
CamaroFest II-III-V
Old 06-30-2010, 08:24 AM   #11
DSteck
I get pissed when I see my manifold pressure drop from 99 to 98 by 7200rpm.
Old 06-30-2010, 10:52 AM   #12
Thanks Kirk!
Thanks again!
No problem. Now get yourself a CAI!
Old 07-02-2010, 03:01 PM   #13
thesubfloor
Drives: 2010 Camaro SS
Thanks Kirk!
Thanks again!
Whenever I tune somebody's automatic (usually in C6 Corvettes) that's one of the first things I work on as it can make a huge difference to how the car takes off. In my car I only see about a 2-3 drop when I launch the car at the track.
I agree with Kirk though in that you have to add more timing in small increments until you're happy with the results.
thesubfloor is offline   Reply With Quote
Old 07-03-2010, 11:33 AM   #14
DSteck
After seeing his log, burst knock was a bigger offender... although that stacked on top of already low timing just compounds the effect.
l99
