SDTW Custom Wheels & Tires
Old 07-06-2010, 06:23 PM   #15
ProudLS
ProudLS's Avatar
Drives: Camaro SS
Originally Posted by DSteck View Post
Holy crap... and I thought 3kPa was bad!
Which parameter you are talking about? I thought I only need to recalibrate the MAF when changing the CAI..!!
ProudLS is offline   Reply With Quote
Old 07-07-2010, 08:11 AM   #16
DSteck
Drives: 2006 Corvette Z06
We're talking about manifold absolute pressure during WOT. Typically, you want to see MAP as close to barometric pressure as possible... the bigger the difference between the two, the more restriction you have.
DSteck is offline   Reply With Quote
Old 07-08-2010, 10:00 AM   #17
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
I get pissed when I see my manifold pressure drop from 99 to 98 by 7200rpm.
Are you saying that maintaining 100 for the entire run after launch is achievable? I hit 100 at launch but then varies between 98, 99, 100 to the traps.
2SSCAMARO is offline   Reply With Quote
Old 07-08-2010, 10:24 AM   #18
DSteck
Desired, yes. Achieved... sometimes. With the key on and engine not running, I see 99kPa. During a WOT pull, I can maintain that 99 until about 6500, where it drops to 98.
It's more worthwhile to compare MAP to barometric pressure, instead of just thinking about MAP in the number itself.
Old 07-08-2010, 11:20 AM   #19
ProudLS
ProudLS's Avatar
Drives: Camaro SS
Are you referring to BARO High and Low? I have it set as 98 and 84 kpa in my stock tune, should I adjust these parameters? Is there other parameters I should look at beside this? Thanks a million.
Old 07-08-2010, 12:14 PM   #20
DSteck
You don't have to adjust anything. It's ju...
Nevermind. I'm too brain mushed today.
Old 07-08-2010, 01:52 PM   #21
ProudLS
ProudLS's Avatar
Drives: Camaro SS
aha ok I am just keen to know every single detail
Old 07-08-2010, 07:06 PM   #22
ProudLS
ProudLS's Avatar
Drives: Camaro SS
Just to make sure that I got that right, do I need to do anything besides recalibrating the MAF for installing new CAI? Thanks,
Old 07-08-2010, 07:23 PM   #23
2SSCAMARO
2SSCAMARO's Avatar
You need to do a proper cruise log to see where your long term fuel trims are at after adding the CAI. Some can be cause of positive fuel trims (lean condition). This on it's own is not cause for worry BUT positive fuel trims get added to the open loop/PE tables during wide open throttle operation and can be cause for an undesireably rich AFR. Log your LTFT's and adjust accordingly to get them around -2.
Old 07-08-2010, 09:15 PM   #24
DSteck
Not really. Just make sure the car is in pure MAF mode when you're doing it. You might have to play with the P0068 criteria to prevent reduce engine power from happening after WOT pulls.
Old 07-09-2010, 06:13 AM   #25
ProudLS
ProudLS's Avatar
Drives: Camaro SS
Got that already but I was worried if I missed anything related to CAI tune in WOT mode. Thanks
Old 07-09-2010, 06:27 AM   #26
ProudLS
ProudLS's Avatar
Drives: Camaro SS
You are the best..
Old 07-09-2010, 06:56 AM   #27
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
I have the CAI installed now and just maybe if I get some time this weekend I will get back started on the tune. It has been raining here but to be clear the next couple of days!
ProudLS what part of Texas you in?
2016 ZO6 2LZ A8
CamaroFest II-III-V
Pro Street is offline   Reply With Quote
Old 07-09-2010, 07:43 AM   #28
DSteck
You are the best..
Let's not say things we can't take back.
Just because it's raining doesn't mean you can't begin to calibrate the MAF. WOT is a nightmare to do in the rain, obviously, but everything else is still easy enough. Please, please, please tell me you have a wideband to install before the catalytic converter to do your WOT tuning!
l99
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area Info@PeddersUSA.com USA - California 6 04-30-2010 08:02 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
