Old 06-30-2010, 09:39 AM   #1
Berean
Drives: Truck
Questions about TPMS and valve stems/adapters.
With all the problems after market wheels are having and the proposed solutions to keep the inside stems from rubbing the brake line and control arms, I'm still not sure I understand everything.
Here's my questions:
1. Why do the aftermarket wheels have the second inside stem anyway? Can't the TPMS be attached to the outside stem?
2. Many of the adapters don't work on the inside lip of the wheel. Why can't the adapter be installed on the outside hole and used there? Then put a short rubber stem on the inside?
Thanks,
Berean is offline   Reply With Quote
Old 06-30-2010, 11:12 AM   #2
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
1. Most wheel manufactures tend to place the valvestem hole where it is less likely to affect the appearance of the wheel. Some wheels have the valvestem protrude through the face of the wheel, taking the place of a rivet. Most wheels have the valvestem hole behind the face somewhere, usually on the drop-center of the wheel (the hump). TPMS sensors attach in various ways, they cannot always fit properly on that valvestem hole location. This is why adapters are required.
2. The TPMS sensor must lay flat, whether that is within the drop-center or on the hoop surface. This way, if you have a flat tire it won't get damaged. The sensor body itself must always remain below the outer edge of the wheel, never sticking out past the outer edge of the wheel diameter. Various pics attached.
The main reason is that there are only a handful of actual hoop makers that supply all of the wheel companies. These hoops are not built with TPMS fitment in mind, as thousands of cars do not have TPMS sensors. Therefore, the need for adapters exists. Also, TPMS sensors come in a variety of sizes, angles, mounting methods, so wheel makers cannot plan for each of them. Most of the time, the second hole is just for an adapter, the other one used for air. Whenever possible, yes it is best to try and get the valvestem hole provided to work, but that just isn't always the case. Every brand of wheel has their own hole locations, it is not a standardized industry. You are more likely get at TPMS to fit like OEM if you go with a stepped lip or cast aluminum wheel, as these tend to have the drop-center (hump) towards the front of the wheel much like an OEM wheel does.
Tony
Fquick.com/NineBall
Old 06-30-2010, 01:27 PM   #3
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Tony, what kind of TPMS mounting does the Pro Wheels "Boost" utilize ?? Does the Boost end up having a 2nd valve stem pointing out the back of the wheel ??
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 06-30-2010, 02:48 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Tony
Nice.....thanks for posting these pics. I'm new with all the TPMS stuff and it's nice to actually see what they look like and how they fit on the wheel.
Build Journal
Old 06-30-2010, 03:00 PM   #5
Nine Ball
Nine Ball's Avatar
Pro Wheels typically have one hole, located behind the face on the drop-center, but aimed towards the front of the wheel. We've used aftermarket sensors directly in that hole no problem. Brands vary on hole locations, but it doesn't really matter as long as you have the proper adapters that work. The goal is to get the sensors inside the tire, and not have them stick out past the wheel diameter. Too bad the OEM sensors have such long stems, they were probably intended for SUV's.
Fquick.com/NineBall
Old 06-30-2010, 03:25 PM   #6
Berean
Drives: Truck
Thanks. I'm going to try and use adapters/TPMS on the outside hole, and use short rubber stems, or mount them upside down, on the inside hole.
Old 06-30-2010, 03:47 PM   #7
Nine Ball
Nine Ball's Avatar
Berean, if you want to play safe, mount the sensors however it works, then bolt the wheel onto the car - before mounting the tire. Make sure it rotates freely without hitting anything. Also be sure the jack is under the suspension, so that the suspension is in the normal position and not hanging down. For front wheels, be sure to turn the steering wheel completely in both directions to check for clearance too.
If everything clears, you are good to go.
Fquick.com/NineBall
Old 06-30-2010, 04:53 PM   #8
Berean
Drives: Truck
Wouldn't it work just to put the stock stems/TPMS in the outside hole? You could get a chrome sleeve and cap. It would be kind of long but it might be better than an adapter.
Old 06-30-2010, 06:18 PM   #9
Nine Ball
Nine Ball's Avatar
Every single wheel brand has different hole locations. You can't just make a blanket statement about putting a sensor in the outside hole. Not every wheel has two different holes. Sometimes you even have to drill your own hole (rare) for TPMS fitment. Just about every forged wheel has the hole on the inside of the wheel, not the outer face. Like I said, only stepped lip wheels have the outer hole on the face.
Yes, it is always preferred to try and make the TPMS sensor work without an adapter, but that is not always possible. Sometimes that valvestem collides with the brake caliper, or the suspension arms, or the brake lines. The smaller the diameter of the wheel is, the bigger the possibility of clearance issues. Larger wheels move the stem/sensor further away from the typical collision areas. Lowering a car can also increase potential of clearance issues, due to it changing the geometry/location of the suspension components relative to the wheel.
And then there are those pesky "Roller Skate" weighted brake pads on the later 2010 Camaro builds. Luckily those can be removed by simply changing out the brake pads to an aftermarket brand. Those roller skates are realllllly dumb.
Fquick.com/NineBall
Old 06-30-2010, 06:30 PM   #10
Nine Ball
Nine Ball's Avatar
Examples.
Here is a "Stepped Lip" wheel. On these wheels, the drop-center area (the "hump" on the hoops) is toward the front of the wheel. Notice it has the valvestem much like an OEM wheel would be, on the outer lip.
On a smooth lip (aka "soft lip", or "reverse-drop") wheel, it provides a more modern appearance at the sacrifice of moving the drop-center to the rear side of the wheel. This allows the wheel maker to use a larger diameter center on the wheel, making a wheel visually larger looking. Most forged wheels are built similar to this. The valve stem is then located within the middle of the wheel. It just looks better like this.
And then you have some smooth lip wheels that pass a 90-degree elbow type valvestem through the face of the wheel. You definitely need TPMS adapters for this type of valvestem, show above on my first reply. The one with the 90-degree elbow.
Fquick.com/NineBall
Old 06-30-2010, 06:49 PM   #11
Berean
Drives: Truck
I have Foose Legends. The outer valve stem is right between the spokes on the flat chrome surface. The inner TPMS stem is at an angle on the back lip.
It seems like either the adapter or the direct TPMS valve stem solution would work with mine. I'll plug the back hole with a reverse stem.
Old 06-30-2010, 06:50 PM   #12
will69camaro
will69camaro's Avatar
Drives: 1969 and 2010 Camaros
Those bottom wheels are SICK!
Planetlsx.com online magazine rep
will69camaro is offline   Reply With Quote
Old 06-30-2010, 08:57 PM   #13
Nine Ball
Nine Ball's Avatar
A couple more different adapters. Quite a few of them out there.
Fquick.com/NineBall
Old 07-01-2010, 05:14 PM   #14
flht99b
flht99b's Avatar
Tony, exactly what parts do I need to install factory TPMS sensors in the Pro Wheels Boost wheels ?? I bought the wheels and tires from Roger. I'm having the same issue most others are having with the aftermarket sensors. They learn fine using the owners manual tire pressure learn sequence but then drop out within about 20 miles giving the "service the tire monitoring system" error.
Ed M.
Dealership stole my TPMS sensors! MacTruck 5th Gen Camaro SS LS LT General Discussions 47 04-20-2010 11:18 PM
TPMS Trouble after installing 3 Piece Custom Wheels. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 6 04-06-2010 07:35 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
TPMS Sensors on Aftermarket wheels. What style does OEM Camaro use? 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 8 10-26-2009 12:49 PM
AFTERMARKET WHEELS AND TPMS dnr427 Wheels and Tires Talk Sponsored by The Tire Rack 6 07-10-2009 12:35 AM
