R1 Concepts
Old 07-01-2010, 09:54 AM   #1
Eric's Blue
Eric's Blue's Avatar
Drives: Cybergray 1SS
Question about 3M emblems etc...
Sorry never attached any type of decals to my car, if you buy the chrome-looking plastic emblems that attach with 3M. how hard are they to take off? Were not talking the GM hundred dollar autobot ones...
"Thou shalt not covet thy neighbor's SS"
Eric's Blue is offline   Reply With Quote
Old 07-01-2010, 02:06 PM   #2
fixxer56
Thin Blue Line
fixxer56's Avatar
Drives: ABM 2LT/RS #10094
Send a message via AIM to fixxer56
Relatively easy...heat gun or hair dryer, fishing line behind the emblem to loosen tape..., some orange oil based cleaner for residue
One of the "Few Blue"
Old 07-01-2010, 11:58 PM   #3
SSinatra Andretti
2$$
SSinatra Andretti's Avatar
Drives: 94 ss, 2008 gxp, soon to be2011 2ss
+1
burn rubber & write your name in the street
SSinatra Andretti is offline   Reply With Quote
Old 07-02-2010, 12:22 AM   #4
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
I didnt even use a heat gun. Some thin, sharp dental floss and some GooGone for cleanup and you are done. Takes a bit of clean up but not hard.
CamaroFTW is offline   Reply With Quote
Old 07-03-2010, 04:15 AM   #5
Wilburbeest
Think With Your Dipstick!
Wilburbeest's Avatar
Drives: 1997 Camaro Z28
Depends on how old they are and how cold the area is to start with. In any case you should at least heat the area up a bit to be extra careful. Ask the small spot of bare metal on my passenger side rear 1/4 panel where I didn't heat my side molding up enough when I took it off. Not a big deal for me because I was beginning prep for new paint anyway, but I know if I had a 5th gen and damaged my paint because I was too lazy to take the <5 minutes to hit the area with a little heat I'd be more than a tad pissed. A hair dryer is generally good enough. Hell if its hot out maybe even just pull the car in the sun for a while.
- Willy
1997 Camaro Z28 (LT1/T56): K&N CAI | Kooks 1 3/4" LTs | 3" Custom Duals | UMI LCAs w/ relocation brackets | UMI adj. panhard bar | UMI adj. torque arm | Koni SA shocks | Strano Springs | Ram Powergrip clutch | Pro 5.0 shifter | skip shift eliminator kit | WS6 Store rotors | Hawk HPS pads
Wilburbeest is offline   Reply With Quote
Question about the heritage grille 06blownSS Cosmetics and Lighting Modification Discussions 1 04-26-2010 05:38 PM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
SS Emblems CamaroSS_LS3 5th Gen Camaro SS LS LT General Discussions 5 08-11-2009 03:23 PM
