Old 07-03-2010, 01:04 AM   #1
GuidosCamaroSS
Drives: 2010 Black Camaro SS/RS MTX
Question about a tire size.
Will a 22x10 rim fit a 315/25-22 tire?
Thanks guys.
GuidosCamaroSS is offline   Reply With Quote
Old 07-03-2010, 02:58 AM   #2
SSinatra Andretti
2$$
SSinatra Andretti's Avatar
Drives: 94 ss, 2008 gxp, soon to be2011 2ss
bro read the top of this section it shows what tires will fit
burn rubber & write your name in the street
SSinatra Andretti is offline   Reply With Quote
Old 07-03-2010, 02:58 AM   #3
SSinatra Andretti
2$$
Recommended 22" tires for 2010 Camaro
245/35-22 = 28.8" tall, 8.0-8.5 wheel
255/35-22 = 29.0" tall, 8.0-8.5 wheel
265/30-22 = 28.3" tall, 8.5-9.0 wheel
275/30-22 = 28.5" tall, 9.0-9.5 wheel
285/30-22 = 28.8" tall, 9.5-10.0 wheel
295/30-22 = 28.9" tall, 9.5-10.5 wheel
305/30-22 = 29.2" tall, 10.0-11.0 wheel
315/25-22 = 28.2" tall, 10.5-11.0 wheel
Old 07-03-2010, 04:43 AM   #4
GuidosCamaroSS
Bro. That says "recommended". I'm asking if it will or will not fit, not if it's recommended or not. Thanks tho.
Old 07-03-2010, 08:46 AM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Yes, it will physically fit on the wheel. It will bulge quite a bit though, and probably handle a little sketchy in corners. I wouldn't sell a 315 tire for a 10" wheel, personally. 10.5 wheel is already on the narrow side for the 315. Even a 305 wide tire bulges quite a bit on a 10" wheel.
Also, your wheel offset will need to be completely different if you plan on using a 315 tire on the 10" wheel. The tires will stick out past the quarter-panels unless you increase the offset to account for the extra width back there. This is very critical if you decide to lower the car.
Tony
Fquick.com/NineBall
Old 07-03-2010, 02:39 PM   #6
GuidosCamaroSS
Reason I'm asking is cause I originally bought a 22x10.5 rim for the rear and bought pzero Nero 315/25-22 for them. But something happened with those rims, so now I'm getting a rim that's 22x10 and I am wondering if I should send the tire back and get the pzero Nero 305/30-22 instead. But you're saying that will buldge too huh? How bad. I eventually want to drop it 1".
Old 07-03-2010, 04:16 PM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I don't know about 22'' wheels, but 305s fit perfectly on a 10'' rim with the correct offset.
Old 07-03-2010, 05:41 PM   #8
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
When you look at larger wheels and tires you need to be careful and consider all factors impacting fit. A tool like what Rims-N-Tires has on their web site is quite helpful, see: http://www.rimsntires.com/specs.jsp --> once there put in both the stock wheel/tire sizes and then what wheel/tire combination you want to use.
The tool will show you all around clearance comparison to the stock setup.
It will also show you what size wheels are recommended for a given tire size which would answer your original question.
It shows that for a 315 tire you should use a wheel size ranging from 10 to 12 inches in width - so the 10 inch wheels would be on the small side for this tire.
edneyens is offline   Reply With Quote
Old 07-03-2010, 05:47 PM   #9
GuidosCamaroSS
...and what is the correct offset?
Old 07-03-2010, 06:16 PM   #10
edneyens
edneyens's Avatar
On the front the perfect offset would be ~ +35, on the back +40 --> based on what I put on my car (I have 20 X 10 with +40 offset front and back - the front is real close to strut tower on mine).
I have 275 tires on front 305 tires on back - if you are going with 305 all around you may need something like +30 on the front.
Old 07-03-2010, 06:23 PM   #11
SGOS252382
SGOS252382's Avatar
You can also give Alex at Speed Depot a call (954 - 625 - 2264). He sells a lot of wheels, and I know he sells some 22'' x 10.0 wheel packages (with 305 tires) for the 5th gen Camaros. He would know the best off sets, etc.
Old 07-03-2010, 06:46 PM   #12
GuidosCamaroSS
I'm planning on buying the Lexani Lx-15. I know they have some offset issues, I believe it's +20 on front and only +25 on back
will 315 rear tire size fit? GQ4Life Wheels and Tires Talk Sponsored by The Tire Rack 15 08-16-2016 10:27 AM
Best tire size for 20x10 wheels robertway Wheels and Tires Talk Sponsored by The Tire Rack 4 11-07-2009 07:31 AM
Hennessey Tire size rasby Wheels and Tires Talk Sponsored by The Tire Rack 5 10-31-2009 08:04 PM
Maximum tire size lcmc Wheels and Tires Talk Sponsored by The Tire Rack 1 10-09-2009 04:24 PM
Spare Tire Question TomServo Wheels and Tires Talk Sponsored by The Tire Rack 10 12-19-2008 08:49 PM
