Old 07-03-2010, 09:32 AM   #1
strauchpete
Drives: 2010 Camaro 1LT
Question about Nos
I am waiting for a Super charger to come out for the v6... dont think its going to happen anytime soon.
But in the mean time I want to add nos to my car, I am sure that most of you noticed that the car really does not come alive until after the 4k rpm marker. I really dont know much about nos other then having installed them via directions and ect on other people cars.
I am wanting a good kit from what I have read so far probably like a 50 shot, but Im not for sure. But I am wanting help with off the line power and to make the car better on that lower end.
Can someone point me in the right direction, give pointers and do's and dont's of nos.
Thanks
strauchpete is offline   Reply With Quote
Old 07-03-2010, 11:58 AM   #2
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Thanks
Check out the ZEX thread a couple threads below. Full of info and read it all, cuz there lots here and there.
ROD1 is offline   Reply With Quote
Old 07-05-2010, 05:57 PM   #3
PostaL
PostaL's Avatar
Be careful calling it Nos, as some Nitrous circles will not take you seriously.
PostaL is offline   Reply With Quote
Old 07-05-2010, 07:40 PM   #4
strauchpete
lol ya, but meh its all the same people know what you are saying when you put nos
Old 07-05-2010, 07:51 PM   #5
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
yeah, but it's a pet peeve of ours and we will correct you... It's Nitrous Oxide, N20 or Nitrous...
scrming is offline   Reply With Quote
Old 07-06-2010, 10:22 AM   #6
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
to me, it's n2o...I got to be a little diffferent..hehe
PacMan
mrray13 is offline   Reply With Quote
Old 07-06-2010, 02:14 PM   #7
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
or spray!
rhd is offline   Reply With Quote
Old 07-06-2010, 04:45 PM   #8
mrray13
mrray13's Avatar
Giggle gas??
Funny juice??
PacMan
Old 07-06-2010, 05:21 PM   #9
rhd
dirtbag
rhd's Avatar
go go juice......
Old 07-06-2010, 06:02 PM   #10
Cole@Fastlane
Cole@Fastlane's Avatar
Drives: 2010 LSX shootout champions
Thanks
Some call it dope.
For a simple,cheap kit run a single fogger nozzle about 3 inches infront of the throttle blade.
T into the fuel rail at the schrader valve for your fuel supply.
Run a 24 jet spread with 50 psi of fuel pressure.
Example= 50 nitrous, 26 fuel jets will net you 100 hp
Your engine will handle a 100 shot with no problem.If you want to run a 50 just do a dry shot.
Cole@Fastlane is offline   Reply With Quote
Old 07-06-2010, 06:44 PM   #11
scrming
scrming's Avatar
Originally Posted by Cole@Fastlane View Post
Some call it dope.
Don't even think the LLT has a Schrader valve.. Remember the LLT is DI and is not your typical setup...
Also think trying to run a dry shot on this motor would be a mistake... This motor likes to run rich... not sure how it would like a dry shot.....
Old 07-09-2010, 08:10 AM   #12
ROD1
Retired
We are running 46/21 on the Zex kit for 100 shot. Not sure ide go dry with the 50 shot.
Old 07-10-2010, 09:23 AM   #13
strauchpete
well Im not looking for anything crazy I just want that power for off the line and low end help, I keep getting my butt spanked off the line but get them in the top side. So should I run a 100 or so something smaller. I am also going to be adding long tube headers and a custom exhaust, and cold air intake.
Old 07-10-2010, 09:41 AM   #14
ROD1
Retired
If you are willing to get a tune I would go 100 shot without hesitation. This is what Vince at Trifecta said after he got my log file I sent to him running the 100 shot.
The car actually looks happier running NOS than not running it. Lol.
From the logs, I’d consider the tune optimized at this point. Fuel and timing look great.
If you need any other changes, just let me know. Thanks!
Good luck at the track today!
- Vince Geglia
Trifecta Performance, Inc.
If you aren't going to get a tune then I would only run a 55 shot as per manufacturer recommendation. You would have to figure out what the correct jets need to be however since no one has dynoed or logged a 55 shot yet. Not only that, I doubt you can do a 55 shot on this car. Seems that a 55 shot would require a 32 nitrous jet and a 14 fuel jet. The smallest jet they make is 17 that I know of which would prolly work with a 36 nitrous jet and give you about a 65 shot which I would prolly run without a tune but I would dyno tune it first to make sure the air/fuel mixture was correct before actually running it on the strip.
Question on NOS mcdoogle6969 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 08-30-2010 06:30 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
Question re: c.i. displacement and hp Arli 5th Gen Camaro SS LS LT General Discussions 6 03-24-2009 01:20 PM
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 09:06 PM
