Old 07-03-2010, 02:56 PM   #1
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Talking DIY-Center Console Carbon Fiber Arm Rest Install
Ok, so I finally got time to do the swap out of the carbon fiber arm rest lid I won from Thecarbonfiberspecialists
It only took about 30 minutes, a phillips & 2 slotted screw drivers. Pretty simple, but I searched for a how to before I embarked on this one. Having not found one I dove in and crossed my fingers.
It seems like every time I do a mod to my car I leave it a little less than perfect once finished. This one turned out pretty good in that respect.
Start by running the passenger seat all the way back and lay the back down as far as it will go. You will do this on both sides. Starting at the front under the dash insert your fingers under the bottom edge and gently pull out unsnapping the bottom clip, then unsnap the top ones. Slowly work your way down to the rear of the center console. Slide the piece forward to remove and place under the car or in a place you WILL NOT step on it.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 07-03-2010, 04:39 PM   #2
d69chris
Florida C5
d69chris's Avatar
Move both the seats forward and lean the back forward for more room. You can sit in the back seat to do this part.
Then remove the two phillips head screws on either side of the back piece of the center console. Pull the sides out and over the alignment nub and lift it up and out.
Open the console lid. Then use the slotted screw drivers carefully to pry the side of the slot open and pop out each side of the mounting arms. Rotate the lid past the fully open position and lift out to remove.
Old 07-03-2010, 04:41 PM   #3
d69chris
Florida C5
d69chris's Avatar
More Pictures
Old 07-03-2010, 04:48 PM   #4
d69chris
Florida C5
d69chris's Avatar
Install the new lid in the reverse fashion and snap arms into place. Rotate the lid to the closed and locked position. Slide the back console piece down in place. Pull sides out and over alignment nubs and install the two phillip screws on either side. Move seats back as far as they go with the back reclined. Put the side console pieces back in place by putting them up towards the front and sliding down towards the back. Carefully start from the back and snap the top clips in place and then the bottom ones. You will feel the bulge of the bottom ones.
Old 07-03-2010, 04:50 PM   #5
d69chris
Florida C5
d69chris's Avatar
Stand back and ADMIRE!
Big THANKS to Thecarbonfiberspecialists for the piece.
Can't wait for the first show opportunity to show it off!
Old 07-22-2010, 01:40 PM   #6
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
very nice! ....so what you plan to do with that old one???
maybe sell or gift it
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 08-05-2012, 07:19 PM   #7
500hpbluez28
YUDLOSE
500hpbluez28's Avatar
Drives: Supercharged 2010 ABM 1SS
Very nice....was helpful. thanks for the write up. took about 10 mins.
Trey Jenkins
2010 Supercharged ABM SS Camaro LS3 #400 Order Number: NJGC85 Build Date: 06/24/2009
1996 Blue Z/28 Camaro 396 stroker in the process
1994 Red Z/28 Camaro
500hpbluez28 is offline   Reply With Quote
Old 12-24-2013, 02:54 PM   #8
BadAssZL1
BadAssZL1's Avatar
Drives: 2013 ZL1 Black on black
do you have to remove console to replace lid?
Carol
BadAssZL1 is offline   Reply With Quote
Old 12-24-2013, 03:14 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
Nope - you the lid can be removed without having to pull the whole console out.
Click to view my build thread
Old 12-24-2013, 05:19 PM   #10
954camaro
954camaro's Avatar
Drives: Camaro SS/RS inferno red interior
Can you even buy these anymore and if you can could someone tell me what they paid for/ got it from!
SoFlo Muscle Car Group
Miami/Broward
954camaro is offline   Reply With Quote
Old 02-02-2014, 11:17 AM   #11
VACamaro
Drives: 2012 2SS/RS Crystal Red Tintcoat A6
Ebay ... Abernathy Chevrolet ... $174 for one with "SS" stitching
VACamaro is offline   Reply With Quote
Old 03-20-2014, 06:16 PM   #12
gtista
Drives: 2011 SIM 2SS
Mucho thanks to d69chris!! Viewed his post and than did the swap to a red thread console cover in around ten minutes. Only fiddly bit was releasing the cover hinge pins. Took a fair amount of force & I did not want to bust anything.
gtista is offline   Reply With Quote
Old 06-21-2014, 12:35 PM   #13
Highland Ranger
Highland Ranger's Avatar
Drives: 2014 CRT Convertible ZL1
Isn't it easier to just unscrew the top piece and swap tops - leave the bottom piece with hinge in place?
Sent from my Nexus 7 using Tapatalk
Highland Ranger is offline   Reply With Quote
Old 06-21-2014, 12:50 PM   #14
Highland Ranger
Answered my own question. Just swapped plain lid with lid with zl1 logo and Yes you can just swap out tops. 8 screws and separate leather top from plastic base (part with hinge and latch) on new and old parts - then swap. When you reinstall just make sure latch is sitting properly on guide posts. 5 minutes.
Center console different with gauge pack vs. no gauge pack? CasopoliS Cosmetics and Lighting Modification Discussions 28 10-13-2010 11:14 AM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
Center Console doesnt close all the way hollywoodjose Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 08-26-2009 11:41 PM
center console question camarofanatic 5th Gen Camaro SS LS LT General Discussions 21 01-09-2009 08:34 AM
