Old 11-04-2008, 06:23 PM   #1
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
Will you still have a new car warranty with these performance parts?
I don't want to screw up the warranty, do these parts hurt it?
Hoss is offline   Reply With Quote
Old 11-04-2008, 06:26 PM   #2
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
GM Performance Parts, when installed by a properly trained technician, will not void any factory warranty that your GM car has.
got tequila?
SilverTurtle is offline   Reply With Quote
Old 11-04-2008, 07:07 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
make friends with your local dealer service dept, im swapping in a totally different engine in mine and i will still have plenty of warranty coverage
Old 11-04-2008, 07:14 PM   #4
see5
Drives: LS7 441ci powered Corvette C5/
There are no hard rules when dealing reasonably with a sympathetic dealer.
2000, 6M, stroked LS7 (441CI), Halltech, Blackwing, PM100mm MAF, LS3 intake, ported LS3 heads, not too much cam, Fast 50# injectors, C6 oil pan, Accusump, HD rad with EOC, RAM HD clutch, Kooks 1 7/8" headers, 3" catless midpipes, Z06 TIs, hardened 3.90 rear, EFILive V2, PLX wb, always tuning.
see5 is offline   Reply With Quote
Old 11-04-2008, 07:15 PM   #5
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I'm no expert, but I think i've seen where the GMPPs have 12 mo 12,000 mile on them. Not sure if or how it affects any original equipment.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 11-04-2008, 08:00 PM   #6
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
If installed by the dealer or ADI before you take delivery of the car, you get full warranty just like everything else on the car. If you take delivery and then decide to buy these parts and have the dealer or ADI install them, they only have the 12 month/12K mile warranty.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 11-04-2008, 08:05 PM   #7
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
It really depends on the performance part. Oiled intakes, any form of forced induction, and anything that requires you to open your engine will generally cause your GM GoodWrench mechanic to raise an eyebrow. Other parts will generally be fine so long as they don't cause a warranted part to wear or break.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 11-04-2008, 08:11 PM   #8
Hoss
Hoss's Avatar
Please tell me who ADI is?
Do you think the shorty headers & the cat back system will help and would they be worth the money?
Put it another way is any of this going to help performance much?
When you are talking about a good tuner helping you out on performance, are you folks talking about a computer geek who knows these GM engines and works on computer cards?
I sure could use some help on this. I want to keep the 3 year/ 36000 mile warranty.
Thanks,
Hoss
Old 11-04-2008, 09:05 PM   #9
NVMY68SS
Drives #296
NVMY68SS's Avatar
Drives: 1968 Camaro SS - 350/5 Speed
Thanks,
Hoss
I have friends with Z06s that were told that anything they bolted to the engine, i.e. headers would void the warranty. Now, these weren't GMPP headers, they were aftermarket. So, I agree with the others, if you can depend on your dealer for the installs, the warranty should be maintained with the parts they are offering. We haven't seen any forced induction, yet. Def gonna have to go aftermarket for that I guess.
Edit: Just found this........keep it handy and check out the cat-back sounds
http://www.gmaccessorydealer.com/orderfulfillment.asp
ADI = authorized dealer for installations or something like that......someone your dealer uses for doing their installs for them.
The tuner is a small handheld device that can be used to make adjustments to your computer......or it can be a dyno based device that tweaks your computer. Just depends on what you want.
GMs warranty is 5 year/100,000 mile powertrain and 3 year/36,000 bumper to bumper.
NVMY68SS is offline   Reply With Quote
Old 11-04-2008, 09:07 PM   #10
playhard67
come to poppa
playhard67's Avatar
Drives: 67RS,09 Harley FLHX
Some parts will void the warranty, A GMPP Hot Cam for instance will void the powertrain warranty.
Cancelled the 2010 SS/RS (for now) and bought this instead (2009 Harley FLHX)
playhard67 is offline   Reply With Quote
Old 11-05-2008, 11:44 PM   #11
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
you're warranty will be voided if a part that has been installed is proven to be the cause of failure. Things like a catback exhaust can't hurt anything so it would be fine. As others have said, a hot cam or a supercharger is somewhat different.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 11-06-2008, 03:06 AM   #12
turbocrazy
turbocrazy's Avatar
Drives: Cadillac CTS & 2010 BLK SS/RS
Is this really true???
turbocrazy is offline   Reply With Quote
Old 11-06-2008, 03:25 AM   #13
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
pretty much
headpunter is offline   Reply With Quote
Old 11-06-2008, 07:45 AM   #14
NVMY68SS
Drives #296
NVMY68SS's Avatar
Originally Posted by headpunter View Post
pretty much
Not per the link I posted above.........here's an excerpt.
GM Accessory Warranty Coverage & Support
GM Accessories that are permanently installed on a GM vehicle prior to delivery are covered under the provisions of the New Vehicle Limited Warranty. In the event GM Accessories are installed after vehicle delivery, or are replaced under the New Vehicle Limited Warranty, they will be covered (parts and labor) for the balance of the New Vehicle Limited Warranty, but in no event less than 12 months / 12,000 miles.
If a GM Accessory is found to be defective prior to or during installation, the Dealer should exchange the part for a new one through the normal return process.
2010 Camaro for SEMA -- New Videos: GM Performance Parts teases socialomar Camaro Photos | Spyshots | Video | Media Gallery 142 11-05-2008 12:55 AM
New Camaro: Muscle car or Sports car??? bazguitarman 5th Gen Camaro SS LS LT General Discussions 37 09-03-2008 03:23 AM
The Camaro team at GM seeks answers ChrisL 5th Gen Camaro SS LS LT General Discussions 148 08-28-2008 09:47 PM
