Jason 98 TA
Old 11-05-2008, 01:25 AM   #1
s.norman
Drives: not worth it
minimum hp gains from gmpp headers/A.I./catback?
what would be the minimum hp gains from gmpp additions? does the car have to be tuned after? will the dealership tune the car if necessary?
s.norman is offline   Reply With Quote
Old 11-05-2008, 02:29 AM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
35hp maybe without a tune
headpunter is offline   Reply With Quote
Old 11-05-2008, 04:54 AM   #3
Cessna510
Gm loyalist
Cessna510's Avatar
Drives: 04 z71 tahoe\99 SS m6
I'm also curious about this,I'd love to get my camaro from the dealership with just shy of 500hp and it still be under warranty.
Cessna510 is offline   Reply With Quote
Old 11-05-2008, 07:40 AM   #4
383ss
Drives: 1985 IROC, 2011 Camaro
I'd say with about 99% certainty a tune will NOT be required.
the shorties will be worth 10hp MAX. CAI may be more like 15 and the catback probably 5.
Id say 25 to 35 to give you around 450hp stock
I can't imagine any problems running high 12's with a good driver with these mods on an average day.
383ss is offline   Reply With Quote
Old 11-05-2008, 10:28 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 11-05-2008, 10:52 AM   #6
Rekt
Rekt's Avatar
Drives: Z34 370Z
25 hp
Rekt is offline   Reply With Quote
Old 11-05-2008, 10:57 AM   #7
Mblock66
Mblock66's Avatar
Drives: 2005 Subaru Legacy GT
I have working the tuning industry (mostly subarus) and you need to be careful withyour predictions. The cars brain is the ECU and it tells the car exactly how to run with what it knows. No there is some level of "learning" in these ECUs but not very much when you add mods like these.
We have seen the addition of a Subaru Performance Parts Intake to a stock application and the car LOST 7hp. After the tune it was up 3hp (this is to the wheels). The stock ECU couldn't understand the new MAF readings and all the additional air so it actually performed worse until tuned.
As for cat backs there is really nothing to tune there but in todays cars there is really not much of a gain there since the stock systems are pretty unrestrictive. Maybe 5 hp TOPS. These are mostly for sound.
Now for headers, shorties will do little for a car tuned for them let alone untuned. The real gain in headers is in long tubes (preferably without cats or hi flow cats). This is where the gains are. Shorties slapped on there with no tune will result in very very little. Maybe another 5.
So you may actually net nothing by adding all of these parts without a tune. And no GM will not be tuning your car lol. If you decide to put them on to "get extra warrentied performance" you probably did nothing but make the exhaust note cooler and empty your wallet. Now if you take that car and get it tuned for the mods, it will get you some better gains but now your warrenty will not be honored and they do have ways to detect if you have flashed the ECU.
I am telling you this from first hand experience, never trust a dyno plot of a part from an actual manufaturer. Subaru provides a dyno plot of their intake on an otherwise stock car with 11hp gain. We did the exact same test on the same car and got -7hp. You can make a dyno look anyway you want it is simple drag and drop lol. Only trust dynos from 3rd party tests and real world applications.
My advice. If you are going to mod....go aftermarket and do it right and cheaper. But understand you pay to play. Once you go this route you need to accept that you may get voided on powertrain when you have an issue. It is just the risk you take.
Either stay stock and stay happy or deal with the problems out of pocket if you decide to mod....
Mblock66 is offline   Reply With Quote
Old 11-05-2008, 06:26 PM   #8
96CAMaro
96CAMaro's Avatar
Drives: '02 Impreza 2.5RS
Interesting, I thought this car, once broken in, would run high 12's all day with an average driver, a nearly empty tank of gas, and a low humidity day.
My predictions: shorties = 10-15hp, CAI = 15hp, catback = 5-10hp for a net gain of 30-40hp netting 452-462hp (6M), 430-440hp (A6).
96CAMaro is offline   Reply With Quote
Old 11-05-2008, 06:52 PM   #9
Wm Holden
Yes, that's my real name.
Wm Holden's Avatar
Drives: 2005 LS2 600hp GTO
all day long.....
Magnuson 112HH supercharger at 7.5 psi (Virtual 9.0 liter) 600hp 1 of 2 torrid/red int /A4/05 555r 275/40/R17's Nitto Extreme Drags 1.7 60 ft Car runs high 11's No other mods. I got the first 112HH Magnuson blower ported for a GTO. Now it appears it was also one of the last....
http://www.ribbonprinting.com http://www.personalizedawarenessribbons.com
Wm Holden is offline   Reply With Quote
Old 11-05-2008, 06:56 PM   #10
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
will long tube headers fit in the car?
logan1080 is offline   Reply With Quote
Old 11-05-2008, 07:00 PM   #11
BowtieGuy
Enlightened
BowtieGuy's Avatar
Drives: Nothing Currently
A tune is not required but for optimum gains it is. As for dealer tuning, there are some instances when GMPP parts are applied by the dealer (only way to insure warranty) and include a canned reflash for the ECM to accept and calibrate the new modifications. This was the case with the Cobalt SS/SC. I don't know if this will also be available for the Camaro, but since they are GM parts and dealer installed there is a very real possiblity of a reflash option or even being included.
If you believe it is your right to speak freely no matter the content, relevance, or intelligence of statement, then it is my duty to the powers that be to set you straight.
People have to talk about something just to keep their voice boxes in working order. So they'll have good voice boxes in case there's ever anything really meaningful to say.
Kurt Vonnegut
BowtieGuy is offline   Reply With Quote
Old 11-05-2008, 07:01 PM   #12
BowtieGuy
Enlightened
BowtieGuy's Avatar
Once they are produced for the car, yes. It will be the aftermarket's responsibility to route the pipes to fit.
Kurt Vonnegut
Old 11-05-2008, 07:26 PM   #13
headpunter
headpunter's Avatar
Drives: Man
a good tune would make the gains from those bolt-ons even more noticeable
Old 11-05-2008, 07:35 PM   #14
383ss
I was being conservative. Also for an average day I'm saying a DA of about 2000 and a descent track.
with great track/weather and driver, I'm sure mid 12's wouldn't be a problem.
Calling JohnnyCamaro from GMPP! If GMPP offered longer stripes, would you buy them? TAG UR IT Cosmetics and Lighting Modification Discussions 158 12-31-2008 10:50 PM
will dealer tune after gmpp header/intake/cat? s.norman 5th Gen Camaro SS LS LT General Discussions 4 11-03-2008 09:23 PM
GMPP Photoshop hack swifttal Camaro Photoshops / Renderings Forum 27 10-22-2008 03:08 AM
Help with GMPP playhard67 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 10-11-2008 10:16 AM
Toyota fears U.S. backlash over gains KILLER74Z28 General Automotive + Other Cars Discussion 6 02-14-2007 09:49 PM
