Old 07-05-2010, 07:22 PM   #1
HJ's Garage
HJ's Garage's Avatar
Drives: Black on Black 2SS RS A6
Question 18" Wheels for Drag Radials on 2SSRS
I have been looking around to find a set of wheels that I can mount up a set of P305/45 Drag Radials. I didn't want to run 20 inchers as there is a limited choice out there and a little more sidewall wouldn't hurt. Both Nitto and Mickey Thompson have a nice range of drag radials for 18" rims. I would need an 18x10 for these tires.
I know a lot of guy's are running drag radials, but I can't beleive everyone is running 20" Nitto555R. Is anybody out there running 18's with 305's?
HJ's Garage is offline   Reply With Quote
Old 07-05-2010, 11:19 PM   #2
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Im running 18" 305s on my V6. Unfortunately you have to swap out the brembos on an SS to get 18s to fit on an ss from what I understand.
ROD1 is offline   Reply With Quote
Old 07-05-2010, 11:52 PM   #3
Supercharged SS
Drives: 2010 Camaro
A c6 zo6 wheel will bolt right up over the brembos.
Old 07-06-2010, 12:25 AM   #4
MadMav
Drives: 2010 SS/RS M6
From what I have read, 18s wills will go over the brakes, but 17s require V6 brake swap.
I'm looking for some 18s too. An easy cheap source for some track use only.
Mav
SS/RS M6, SIM, CGM stripes, Barton S/T, BMR trailing arms, ADM Race intake(no scoop), Texas Speed 1 7/8" headers and full 3" exhaust, RMCR custom tune.
MadMav is offline   Reply With Quote
Old 07-06-2010, 10:13 AM   #5
ROD1
Retired
Mav
Ahh, I stand corrected. I walk funny too Cheap 18s = tire rack! Just plug in an LS Camaro !
Old 07-07-2010, 02:24 PM   #6
HJ's Garage
Thanks everybody. I will check out the sources and let you know how it goes. Have fun out there.
Old 07-07-2010, 03:18 PM   #7
Supercharged SS
Drives: 2010 Camaro
I don't think the ls 18's will fit over the brembos. Better triple check.
And you can get 17's over the brembos. I have them on my car. They are the custom made sjm/bogarts.
Old 07-11-2010, 09:54 PM   #8
mtbikerinme83
mtbikerinme83's Avatar
Drives: IMB 2SS/LS3-M6
some 18" wheels will fit over the brembro's if they are the ones without the weigths hanging off the brake pads, I should know since I have a set of 18x8 wheels that I purchased from Tirerack to use as my winter wheels with snow tires. What I haven't come across is any answers as to who has 18x10 wheels that will clear, I've only seen a bunch of narrower stuff that people use for winter wheels.
IBM 2SS LS3-M6
CAI intake with JRE race scoop, VMax TB, Solo HF Catted Mid pipes, and JRE SCT tune
mtbikerinme83 is offline   Reply With Quote
Old 07-11-2010, 11:18 PM   #9
Dan@showstopper
Dan@showstopper's Avatar
Drives: 2010 Camaro SS
18x10.5, I'll be mounting 305/45 NT05r's
Dan@showstopper is offline   Reply With Quote
Old 07-11-2010, 11:27 PM   #10
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Use a 18 x 9.5" C6 Zo6 front wheel or clone C6 ZO6 front with Zo6 offset. This has worked well for people using the 305/45r18 drag radial and clears the brakes.
Old 07-20-2010, 03:57 PM   #11
HJ's Garage
Thumbs up
I just wanted to thank everyone for the help. I found a source for 18" C6 Z06 Wheels, 18x9.5 with a 53 offset. I also found a pretty good price (I think) on a set of Nitto NT05R P305/45r/18's drag radials. Really looking forward to mounting them up and giving them a try.
Anyway, thanks for the help guy's.
Old 07-30-2010, 09:33 AM   #12
nhra stocker
nhra stocker's Avatar
Drives: 69,10 camaro 71 chevelle
Someone correct me if im wrong but I think you want to go with a 40mm offset not 53.
2010 Camaro SS RS M6 Bone stock 12.58 at 110mph http://www.camaro5.com/forums/showpo...&postcount=263
1971 Chevelle SS 454 365hp NHRA C/SA 10.73 at 122
1969 Camaro (427 ZL-1 clone) M-22 being built
1982 Siverado 4x4 454 Mud truck stock class 3.66 sec in 150' of mud
nhra stocker is offline   Reply With Quote
Old 07-30-2010, 09:53 AM   #13
Supercharged SS
Drives: 2010 Camaro
Like "Stocker just stated. The 53 mm offset is not the correct one. The 40 mm offset is what you need. Below is the link to the wheel you need. Its been posted at least 10 times so far but here you go again. These wheels bolt right up with no issues:
http://www.corvetteguys.com/c6z06-ch...-18x95-40.html
Old 07-30-2010, 09:57 AM   #14
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
I have access to some low priced, lightweight 18x10 or 18x11 wheels that will clear the SS Brembos. Contact me for info, I'd be glad to help.
Tony
Fquick.com/NineBall
What song are you listening to right now Muscle Master Off-topic Discussions 6390 01-05-2018 10:22 PM
Polished Stock Rear Wheels with new Nitto 555r Drag Radials JJ2010 Wheels / Tires 9 05-18-2010 11:34 PM
2010 Camaro Black steel heritage 18" wheels klondike Wheels / Tires 6 04-27-2010 08:58 AM
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill nUcLeArEnVoY Camaro Photos | Spyshots | Video | Media Gallery 129 04-22-2010 03:59 PM
