Old 07-05-2010, 08:39 PM   #1
PatrickfromMD
PatrickfromMD's Avatar
Drives: Navigator/Corvette/2010 Camaro
Searching for the best wide tire combo for ride and look
Guys,
Iíve been trying to find the ideal tire size. (then have wheels made to work with them)
Wide 20s are ok, but not a lot of departure from stock.
22s donít seem to come tall tall enough (as well as wide enough) to have an acceptable sidewall height. (unless you go with ultra expensive Dunlop runflats)
Pilot Sport PS2 come in the below sizes which seem to be a good balance between look and acceptable sidewall height.
285/30ZR21 apx 27.8 tall and mount it on a 21 x 10
305/30ZR21 apx 28.2 and mount it on a 21 x 11.5
Thoughts?
***56K miles and still going strong***
2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto
ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune
T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back
JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt
T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM
Gary Custom Z vented fenders. Vararam ver 2
PatrickfromMD is offline   Reply With Quote
Old 07-05-2010, 09:38 PM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
personally, for me to buy a set of wheels and tires, and not have to buy new tires on a regular basis, I would be looking at a set where all 4 are the same size. thats me 2 cents.
Old 07-05-2010, 11:16 PM   #3
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
When I go aftermarket wheels, I'm going to go with 21"s and those Michelins. I didn't notice the 285/30 in that tire...I had planned on the 265/35 for the front with the 305's out back. I think the 21" is the ideal wheel size/sidewall height for this car. I also think 305 is plenty wide...it's not 315, but close enough. The only drawback is that the 21" tires are nearly twice the price of 20/22's...
Edit: Check this out from the Custom Wheels thread:
http://www.camaro5.com/forums/showpo...&postcount=486
Kilo-9 is offline   Reply With Quote
Old 07-05-2010, 11:23 PM   #4
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
for what its worth, my goal is 285/40 20" at all 4 corners.
its slightly taller than stock. I figure when I get a little bit of lowering to the suspension it should fill the well nicely.
Mythic is offline   Reply With Quote
Old 07-06-2010, 01:23 AM   #5
World of Wheels
Drives: 2SS Spaceship
I would not go 21x10 or a 285 up front. just my 2c.
[SIGPIC][/SIGPIC]
World of Wheels is offline   Reply With Quote
Old 07-06-2010, 01:35 AM   #6
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
275/40-20, on 9.5x20 wheels front & 315/35-20, on 11x20 wheels rear maintains the stock ride height. side wall = ride comfort
20's help keep your tire cost down in the long run. You have to figure on buying 2-5 sets of tires at least over the life of the car. 21inch tires are really expensive and very limited on sizes.
That way when you lower your car................and you will, your not starting with a lower frame height due to a smaller diameter wheel/tire set up. Keeps you from dragging your chin!
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 07-06-2010, 05:36 PM   #7
Mythic
Mythic's Avatar
any rationale for that? 21" is a GM available rim size.
Pedders has a car running 305 all the way around and seem to be doing pretty well with it.
Old 07-06-2010, 07:48 PM   #8
NinoSS
Drives: 2SS/RS CGM LS3
This is just about the nicest wheel on a CGM...
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 07-06-2010, 09:35 PM   #9
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
The reason most people do not go with 21" wheels is because 21" tires cost a lot more than 22s or 20s. Price check them and see for yourself. Yes, 22s cost less than 21s when it comes to tires.
Fquick.com/NineBall
Old 07-06-2010, 09:48 PM   #10
Boosted IBM
Boosted IBM's Avatar
Drives: 2010 2SS RS
What size Vredsteins are those?
Boosted IBM is offline   Reply With Quote
Old 07-06-2010, 10:29 PM   #11
PatrickfromMD
Perhaps it was a bad assumption where I figured the cost of 21s would be in between that of 20s and 22s.
Iíve put in a couple inquiries to a couple wheel vendors.
I take it your vendors charge more for the lower volume 21 inch wheels that the higher volume but larger 22s??
Old 07-06-2010, 10:41 PM   #12
PatrickfromMD
I spoke to Pete from Pedders at the Camaro Nationals at length. He had his car there. The 305s all round seem to fit nice (although they are 19s).
Still for my application, I like the look of a larger rear tire, so the 285 front seems perfect to me. I'd do a 315 on a 21 is anyone made one. But I suppose a 305 will do nicly, especially if I make the rear rim wider by good margin.
Old 07-06-2010, 10:50 PM   #13
2010SS
2010 SS
2010SS's Avatar
Drives: 2010SS
21" tires have came down in price. I think 22" would be a nice clean look if your in it for the look's and 20" would be the best for performance.
no animated signatures please - Milk 1027
2010SS is offline   Reply With Quote
Old 07-07-2010, 08:09 AM   #14
Nine Ball
Nine Ball's Avatar
Wheel-wise, 21s usually cost the same as 22s. They are both cut from the same forging blank. Just the tires cost more, because 21" is an uncommon size and tire manufacturers do not move a lot of them in that size. Check out www.tirerack.com and www.discounttiredirect.com for pricing comparisons on tires.
Fquick.com/NineBall
