| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: CTS Join Date: Jul 2010
Turbo Vs. Supercharger
Lets start some trouble. What is better Turbo or Supercharger?
And why? I have to admit I have driver a TAFC but I have never had a turbo or blown street car. I will be doing one or the other but i would to see some debate. What would be the hardest on the car? |
RIP JoePa
Drives: 2010 2SS/RS & 2001 Audi S4 Join Date: Apr 2010
put this thread in the Super/turbo forum...
but anyways... a turbo or TT setup will make more boost at lower rpms which will put more strain on the engine there but they will typically make more hp/tq with an overall lower amount of boost i would want a TT setup on my car but they are usually a lot more $$ too
#3 | |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Drives a Maro
What is boost?
#5 | |
![]() Drives: Grabber Blue Mustang GT Join Date: Apr 2010
the simplest and best answer is...it depends. but a turbo is the best power adder. its free horsepower and it makes the most hp per lb of boost. a turbo is exhaust driven. a blower is belt driven. the turbo will require more plumbing, thus is usually more difficult to install. tuning can (not always) be a little more troublesome as well. a good positive displacement blower like a kenne bell or whipple would be a good thing on these cars due to the weight...that being said, a properly sized turbo can easily meet or exceed the torque production of a PD blower too. so how much do you want to spend...thats the real question. |
#6 |
user bann'd
Drives: Chevy SS Join Date: May 2009
I can't say one is better then the other, but I am a turbo person.....
![]() Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Go into the proper forum section and READ.
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) JRE tuned Aint nobody got time for that |
#8 |
I would like to spend no more than 10k. Will that get it done?
#9 | |
remember when you go forced induction its a good idea to get colder plugs, bigger injectors/fuel pump and a QUALITY custom tune. |
#10 |
![]() ![]() Drives: Black 2010 2SS/RS LS3 Join Date: May 2010
The latest twin turbo systems out all come out to around 10k, give a take a few hundred, when you add in the upgrades. There are numerous vendors in the vendor marketplace with their TT setups for sale...
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 E92 M3 Join Date: Nov 2009
i would like a supercharger set to a low psi for safer on engine and .. a nice everyday driving car... and superchargers are easier all around.. but turbos are for big numbers
#12 | |
VIN - 7314
Drives: Black 2010 Camaro 2SS/RS Join Date: May 2009
Vortech is 6-8k depending on type and install Kenne Bell is 6-10k depending on IC or LC (Intercooler or Liquid Cool) T/TT setups cost around 8-10k depending on setup and install. Goodluck!
#13 |
That would be a false statement. PD SC's are harder on the engine than a turbo or Procharger. Insta-tq is nice for roasting tires but it's harder on the engine and drivetrain. This is assuming similar HP outputs. The good thing about turbo's is that you can change boost pressure with a turn of a knob or button on a EBC.
#14 |
![]() Drives: 2010 SS Join Date: Nov 2009
Depends what you want out of your car. Twin screw blowers offer nearly instant boost at any rpm the second u mash the throttle. And single turbo set ups usually build power up higher in the rpm range. Twin turbo set ups though offer strong boost from low rpm ranges and then some.
#15 |
![]() Drives: 2010 Camaro Join Date: Oct 2009
Superchargers take 30-40% of power to turn. A supercharged car producing 500 rwhp is putting roughly the same load on the bottom end as a turbo making 675 rwhp.
#16 |
The torque curve of a twin screw supercharger is pretty flat and make lots of torque down low. Procharger types make less low end power but equal top end power. As posted abve a single turbo has less lowend compared to a twin turbo setup. However I'm not familiar enough to compare a twin turbo's bottom end power to a twin screw supdercharger. It does appear that the TT will make more power per pound of boost.
2SS A6 Black
360 RWHP/382 FTLBS - tune only Mods on: Dynatech LTs, Vararam Intake, Pedders Xa's, DiabloSport tuned |
#17 |
![]() Drives: 2010 Shelby GT500 Join Date: Jul 2010
as stated in a couple of responses - i would go with a procharger - around $7200 for the kit. you'd add 175 hp at the crank i believe.
ive researched kenne belle and whipple twin screw - although both are top of the line, you'll pay for it too. procharger still adds more hp an torque than any supercharger or single turbo. good luck! |
#18 |
Are you sure about that? You might want to do a little more research on this statement.
#19 | |
#20 |
![]() ![]() Drives: 2010 Camaro SS Join Date: Mar 2010
One thing to also look at is a lot of supercharges now don't push out very much PSI when you aren't stomping on the gas. Such as the new Whipple I think is rated at only 5% power when you are just cruising.
#21 |
#22 | |
![]() ![]() Drives: 2012 Challenger SRT8 Auto Join Date: Sep 2009
Too many choices and just one car......
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin ![]() LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!! |
#23 | |
![]() Drives: Z06, 69 Camaro Join Date: Oct 2009
You must be referring to peak HP. Twin screw and turbos at equal boost will make more power under the curve than a centri every time, and always more torque.
#24 |
![]() Drives: 2009 ZR1 Join Date: Nov 2009
#25 | |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
will you take it to the track? do you have plans to make big power (1000 hp) down the road? are you going to keep the stock drive train? How much power do you want now... how much boost. Help us by answering these questions and we can give you better information.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
| Thread Tools | |
| Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 205 | 05-15-2013 09:30 PM |
| Stock L99 A6 Supercharger options, opinions, & experiences | 2010 Bumblebee | Forced Induction - V8 | 103 | 03-24-2013 06:24 PM |
| STS Twin Turbos | SupremacyCustoms | Forced Induction - V8 | 0 | 02-16-2010 01:35 PM |
| STS Twin Turbo Kits Coming Soon!!! | tbyrne | Forced Induction | 18 | 10-19-2009 10:06 AM |
| ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) | Ultimate Performance | Forced Induction - V8 | 496 | 10-11-2009 01:29 PM |
