| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#51 | |
![]() Drives: 2009 ZR1 Join Date: Nov 2009
That describes all the FI (Turbo and SC) options to be honest. It is a common misconception that a turbo car is only better from "100mph on up" while a roots-blower is the perfect 0-60 set-up. Both are wrong IMO. *IF* you are driving around on drag-radials or at the track where traction isn't an issue then a Maggie/Whipple could use that huge torque spike to get out ahead of a turbo car. 99% of the time on the street on street tires all it is going to do is spin and it is no advantage at all in terms of acceleration. Turbo's (Specifically mine) have just as much of an advantage in 2nd gear as they do in 4th Jeff |
#52 | ||
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
Maybe I do see what you are saying... if you start at a HP number, 600hp, you are saying that the engine is suffering from less wear and tear because the turbo makes that power with less boost? as a function of better efficiency. Quote:
It comes down to price and the small differences in where the power is being made... and how that equates to their budget and build preference.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#53 | |
Okie doke
Or I could be talking out my butt ... lol .. but I think that is it .. Crowley
#54 | |
The "Lag" misconception is pretty wide-spread as most have ridden in / driven / owned an EVO or STI or DSM that are small 2.0L or 2.5L 4-Cylinder engines with a turbo to make power. They can certainly feel like an on/off switch for sure. Put a 6.2L V8 behind a pair of turbos and there is no "Waiting" for power to come in what-so-ever ![]() Jeff |
#55 | |
One Lucky Guy.
My impression has been that turbos have a smoother delivery, not a hesitation or lag.
#56 |
Drives: 2SS Victory Red Join Date: Jul 2009
There is no extra maintenance with the turbos. Once installed just drive it like normal. Assuming a bottom mount set of twins there isn't even extra heat. I keep reading about how hard it is to install turbo's. They are not any harder or easier that installing a Blower and a set of headers. Even when installing the PD blowers they require a water to air heat exchanger in front of the radiator so that takes as much time as installing an air to air intercooler in that same locations
#57 | |
If you are willing to install headers then you should be willing to install a TT kit. The Twin Turbo kit at 7 psi or more will be king. HANDS DOWN. I said it best a few years back when I wrote an article for M/T. "When it comes to low speed stunt driving and fancy smokey burn outs, you can't be the PD style blower. But, when it comes to harnessing the power of a real American V8 and what they are capable of, you gotta go Twin Turbos" |
#58 | |
#59 | |
Drives a Maro
![]() I'd love to hear the reason from someone who could explain how they got the lag out. Seems to me, that because there is minimal 'blow' from the exhaust on launch, how then does it give you SC type instant power until it can build flow? |
#60 | |
So back t0 the same question - what is the real goal. If it is super safe on the engine and not looking to get over 600 rwhp which is 700 at crank then you can do that with a TT kit and nothing else at 8 to 9 psi A centrifugal can certainly do it but it will take headers |
#61 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
I guess it comes down to your definition of lag. For most, lag came from the smaller displacement motors with bigger turbo's on them. You'd push the gas and it would literally take several seconds for the boost to build up, then you'd be like a rocket. Pushing a big single or smaller twins with 6.2l of exhaust makes boost come on instanteously. Yes it takes time for the the HP/tq to rise to max levels but you can't make instant HP and TQ. Your engine would explode. If you want to get technical, there's lag between the time you push your gas pedal and when the TB opens. There's lag between the time you hammer it down and the Maggie makes power. It's all a question of your perspective. 400ft/lb of tq by 2500 rpm isn't too shabby in my book.
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) JRE tuned Aint nobody got time for that |
#62 |
#63 | |
The statement above is true - if all you wwant is 140 over stock then the Maggie is a great choice - but you can do that with the twin turbo set up as well with even less boost and it will look all original as well. There are many convos going on all intertwined. What I see is 90% agree a TT system regardless of whose you purchase will make 600 rwhp very easily with no cam change and no headers or anything else but the bolt on kit for that matter |
#64 | |
#65 |
Okie doke
If you size the turbos right u will have minimal lag. Too large of a turbo and there will be some lag. Good example of no lag is the BMW bi turbo 3.0L. Very small turbos and no lag at all. The problem is that you could max those out pretty quick.
#66 |
My kid drives the bi turbo x6 with the big V8. It has no lag in auto trans mode. When you convert over to SMG (sequentail manual gearing), upshift to like 4th gear at like 30 mph and then stand on it, it has 3 psi by 2500 on its way to 7.5 psi at 3200 to 6200 rpm - so again that is not realy lag
#67 | |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
The more I read this thread the more I am confused. I THINK that turbo's make power from exhaust and maggies make it from intake. I am not sure which one is better. I was told that I would make almost 600 rwhp if I added a TVS 2300 and that 600 rwhp is a relatively safe number on stock internals for this car. While I know it probably is not the same, my truck has a turbo and while it has power and great torque for pulling it seems to sorta lag when pulling, but it isn't made for speed and gets the job done. I guess in my case I am looking to add as much power safely to my car that will give me longevity so to speak, drivabilty but be there when I want to make some other guy think something is wrong with his car. I have seen a twin turbo in action that eats everyones lunch and yes it's a ricer and front wheel drive, those things make great power and if you are not careful you will get embarrassed by this one, that is mostly a strip car but he does run it around town occassionaly. My car is fast, to me, right now but the TVS 2300 seemed like a great way to add some more power with little risk, from what I am being told 600 is safe power? Thoughts
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
#68 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
I think for 95% of the people on this forum, the TVS2300 fits their exact desires. The maggie is the best STREET FI kit out there and reliability cant be beat. The TVS2300 should have come on these cars from the beginning as it completely changes the car and it does it in a HUGELY positive way. Again, it all goes back to what each individual really wants. All of the turbo kits available are great and produce huge power. I personally had the TVS2300 on my car and loved it until I wanted to start making BIG power and the TVS2300 just isnt made to run at its max rated numbers. It is great for the guy or gal wanting an awesome 600hp street ride but like me I was pushing the maggie to its 900hp rating and it falls flat and is too much torque off the bottom end making it difficult to hook up. I am now going for BIG HP and I decided to go with the
F1-R to accomplish this. I talked with alot of the TT guys and they are great as well, but in the end, the F1-R fits my application better as well as my budget. Any kit you decide to go with will be a huge improvement for the FUN factor and if you are looking for the 600hp range, than you will have no worries with any FI setup as that is a super safe level for the Camaro.
#69 | |
Banned
#70 | |
Too funny....love it
#71 | |
and MR. HYDE
Torque is what really sets you in your seat and most people don't drive over 80 even when doing a little street light to street light thing. For me this will be for the guy in his little Mustang with some headers and exhaust that will come up beside you and rev his motor, which is not alot but it's nice to have when needed. This will not be my daily driver, but mostly for cruises and shows. I love the car and do take it on longer trips just because of the wow factor it has. From all I know and have read 600 is just about the max hp you can run safely on this car without internal mods, Correct? I am prorbaly looking for more realiability and "Good" usabable hp. 850 is not good if it can't be put to the ground. While I am sure that it can be with aloy of mods I am unwilling to go that far.
#72 | ||||||
If you already have headers and 450 RWHP – the Maggie is only 7 psi away from your goal – sounds like you made up your mind Last edited by Granatelli; 07-11-2010 at 01:56 PM. |
#73 |
Banned
I WANNA WHOOSH, AND THAT JET ENGINE WHINE....ALL WHILE I SMOKE TIRES AT 100 MPH, SWITCHING 4 LANES
#74 |
I let you take a ride in my car and see if you still feel that way. Smoking tires across 4 lanes at 100mph really isnt that much fun......of course it wasnt intentional either.....LOL
#75 | ||
well saidQuote:
My take, The Procharger says, I am here HEAR ME ROAR! The turbo is calm, cool and collected. It will just sit there sleathy like until it is time to attack - then it will make mega power if asked or just a little if kept on it leash. Best of all it can do all this with no loud headers, pulley change requirements or rearranging on all the accessories I talked with alot of the TT guys and they are great as well, but in the end, the F1-R fits my application better as well as my budget. Any kit you decide to go with will be a huge improvement for the FUN factor and if you are looking for the 600hp range, than you will have no worries with any FI setup as that is a super safe level for the Camaro.[/QUOTE] |
| Thread Tools | |
| Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 205 | 05-15-2013 09:30 PM |
| Stock L99 A6 Supercharger options, opinions, & experiences | 2010 Bumblebee | Forced Induction - V8 | 103 | 03-24-2013 06:24 PM |
| STS Twin Turbos | SupremacyCustoms | Forced Induction - V8 | 0 | 02-16-2010 01:35 PM |
| STS Twin Turbo Kits Coming Soon!!! | tbyrne | Forced Induction | 18 | 10-19-2009 10:06 AM |
| ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) | Ultimate Performance | Forced Induction - V8 | 496 | 10-11-2009 01:29 PM |
