Caryle Racing
Old 11-27-2010, 09:24 PM   #1009
STINGS
Live for On Ramps!
STINGS's Avatar
Drives: 2010 Camaro/2LT/RS/T.F./6M "naomi"
Originally Posted by Rcfiddy1 View Post
Looks like you left your seats in. I am 6'2" and there was no way I was laying under dash with seats in.
I swear the last time on was laying on the floor this afternoon I dozed off....Actually feeling kinda awake now after getting some dinner.
You can't see it in the picture, but the back seat is out, had nothing to do with this project, but was trying to finish up the last project and hadn't put the back seat back in. Note to self, finish one at a time!
Joe
STINGS is offline   Reply With Quote
Old 11-27-2010, 09:38 PM   #1010
baba booey
baba booey's Avatar
Drives: abm 2ss rs
Originally Posted by STINGS View Post
Well it is dark, and now I know how walt and ofer felt, I'm hungry!! Will have to wait till tomorrow to put the dash pad back in, so hopefully it I can talk my brother to come on down and help put the dash pad back in, so we can get it finished since I need to get to work on Monday!. Just a couple of pic's. Took one from the drivers side, since Guskd was from the passenger side, and yep another yellow one.
To bad they hide the "Aw Sh#t" bar behind the dash pad!
Is it as scary as this looks
baba booey is offline   Reply With Quote
Old 11-27-2010, 09:55 PM   #1011
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
I had a lot of work but as I said I will start on Monday, I'm very excited, this is going to be fun
DWALEX is offline   Reply With Quote
Old 11-27-2010, 10:16 PM   #1012
STINGS
Live for On Ramps!
STINGS's Avatar
Actually no, you find you are taking a section out at a time. There are a couple of things that are not mentioned in the manuals, or if they are, I missed them. There is a small bosch module attached to the underside of the dash pad, which is just easier to unlock the tab and slide the module out. It is located just behind the tachometer, just above the hvac duct. Then you have to unlatch the fuse panel, and push it in, but you can only push it in a 1/4 of the way, (hits a brace/wire harness) until you start to lift up the dash panel, than you can unhook the rest of the way. Think they only show 2, 7mm bolts on each end, but think there is actually 3 on the passenger side. The dash actually sits on 2 pins, (one on each side) and you actually lift the bottom of the dash up and off the pins and than start heading toward the back of the car. Also the wiring harness that you see right behind the speedo/tach is in the way of the HVAC duct, and does require using a panel tool to pop the two cable ties out so you can move the harness toward the steering wheel and down around the two tabs that the tie wraps were attached to. Wish I could have taken more pictures, but was a one man job up untill it was time to remove the dash pad. Other than the problem I had with breaking the SIR coil, it went very smoothly. Hope the reinstallation tomorrow goes as well as the removal.
Joe
Note there were 14ea 7mm bolts and 3 torx that held the dash pad in. There is also 2ea 13 mm bolts holding the bottom of the passenger side airbag in. (Counted them as I put them back in)
Last edited by STINGS; 11-28-2010 at 05:14 PM. Reason: Added total number of dash pad hardware.
Old 11-27-2010, 10:18 PM   #1013
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
This is like watching a horror movie, but you know the movies hero is going to survive.
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 11-27-2010, 10:22 PM   #1014
STINGS
Live for On Ramps!
STINGS's Avatar
What size torx is it the same size as a seatbelt torx
I used a T50 and it had a little play.
Old 11-27-2010, 10:40 PM   #1015
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
nice job stings.....
lionssfan is offline   Reply With Quote
Old 11-27-2010, 11:56 PM   #1016
STINGS
Live for On Ramps!
STINGS's Avatar
Originally Posted by bmrinell View Post
I suppose I should attempt mine since I'm in the Midwest... but I've been too busy cleaning snow lately. The Camaro is all tucked away (covered) in my garage. Would you guys advise buying any service manuals for this? Someone awhile ago said "NO" but I don't want to mess things up.
Good Job guys! I'll have to heat my garage up sometime soon and start on mine!
That is a good question, have to admit, did reference the service manuals quite a bit on this, sometimes it help, sometimes it was of no help. Guess it will depend on what type of documentation comes from the people that have already done it.
Old 11-28-2010, 11:03 AM   #1017
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
damn, I think this may be out of my league. . . . I already bought the harness and HUD though. . . hummmmm.
Anyone want to come to PA and help/ do this for me? lol
The ghosting on the window sucks too.
franknbeans is offline   Reply With Quote
Old 11-28-2010, 11:36 AM   #1018
turboguy327
Banned
Drives: 2011 Chevy Camaro
Can this be done to my 2011 LS??
turboguy327 is offline   Reply With Quote
Old 11-28-2010, 11:36 AM   #1019
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
That's a long drive for me, But will get you some help, Some how, Its rely nice to have The HUD in the car, and the pics are not right, Of the windshield the image is good, Its not as bad as you see it.
Old 11-28-2010, 11:38 AM   #1020
2SSRS@Gen5diy
In a word YES.
Old 11-28-2010, 11:50 AM   #1021
baba booey
baba booey's Avatar
Drives: abm 2ss rs
Was going to wate for Ofer to post instructions but can't wait so I'm going to start now
Just to make sure all I need to do is remove the batt to disable the SIR there is no back up batt or anything like that
Old 11-28-2010, 12:30 PM   #1022
2SSRS@Gen5diy
What we did is first take the center console out the move all seats back then disconnected the battery (both the positive and negative)( you need to give your self min if 10 min before you start on air bags) Then start removing all the parts, AC controls and radio then the glove box and dash trim, side covers and side air duct, Be organized and but your bolts so you remember where you removed them from.
One more thing on the template it was made at the time and i cut it in the car what you need to do is line it up so the top cut (the one closest to the instrument panel) Is parallel with the step in the dash.
Here are 3 pics one is the steering wheel puller you don't need (sarcasm) and two of the dash one with the way to cut out the opening that you need,So you know the template is small and needs to be opened up on the sides, Guys i am tired and will work on a set for all this in the next two days, but not today i am going to be a vestibule today see you all later.
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 06-25-2017 10:57 AM
February 2010 Camaro production & sales figures. Tops Mustang for 9th straight month! Tran 5th Gen Camaro SS LS LT General Discussions 52 03-03-2010 10:39 PM
DEALER ONTARIO CANADA WE SHIP ANYWHERE IN CANADA 2010 CAMAROS FOR SALE IN STOCK NOW! dz Dealer Camaros for Sale 0 03-03-2010 06:43 PM
Zex Nitrous System for 2010 Camaro SS @ BMC Performance! Kris@BMCPerformance Forced Induction 2 02-18-2010 07:59 PM
2010 Chevrolet Camaro makes finalist list for 2010 World Car Design of the Year Tran 5th Gen Camaro SS LS LT General Discussions 37 02-17-2010 05:22 PM
