JDP Motorsports
Old 11-28-2010, 02:07 PM   #1023
baba booey
baba booey's Avatar
Drives: abm 2ss rs
Originally Posted by 2SSRS View Post
+1 insert a small flat screwdriver and fell till you find a spring like part, then push it in as far as it will go and pull on the air bag and that side is out then the outer side. (dont get mad it was almost an Hr for us too)
Got the air bag off but how do you remove the connector on the air bag
baba booey is offline   Reply With Quote
Old 11-28-2010, 02:10 PM   #1024
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
OK, everyone the above pictures are of My car. I helped Ofer on his 2SS on Friday and yes we were using the books (manuels) and also making calls to the guys on the East Coast who were working on theirs as we were working on Ofer's car. The first time took alot longer then the second time and Yes before we started I was unsure if I wanted to tear My car apart for this. Well two (2) 50 Year Plus Guys did this. Again on the first care we were carefull as Hell to make sure that we did not screw up anything. On My car we used what we had learned the day before. The only difference was that My car was an automatic and because I have a Leather Boot around My gear shift (from DSV) Ofer had believed that I had a Manuel, and because we had troble removing the shifter nob (we could not get the set screw out). We were able to manuever the Center Console around the Gearshift. We laid everything out on the Garage Floor NEATLY, keeping everything together and organized. My car took alot less time then Ofer's car, but again at each step we double checked what we had done to make sure that nothing was forgotten. Now I had about a 3.5 hour drive home from Ofer's place and I played around with all the different features on the HUD and also had to completely reset My car. The BEST thing I can say is that GM/Chevy SHOULD have put this HUD Unit in the car from the START, and EVERYTHING is set up for it both in the structure of the car and in the Software. I LOVE THIS FEATURE and for all of the NAYSAYERS out there who say it is not worth it or other things like the display is Blurry. First off CLEAN YOUR WINDSHILD and Second grow some BALLS and take the RISK, and do it the RIGHT WAY. Also, if YOU do not like the feature KEEP IT TO YOURSELF or as the OLD SAYING GOES "IF YOU DO NOT HAVE SOMETHING NICE TO SAY, DO NOT SAY ANYTHING AT ALL."
Walt B.
P.S. Ofer Thank You Very Much For Helping Me With My Car, Both Installing The HUD Unit And Adjusting/Tweeking My ABL.
Walt.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
Old 11-28-2010, 03:01 PM   #1025
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
WCoolbreeze...what do you mean by "completely reset my car" ?
Thanks
Cam 427 is offline   Reply With Quote
Old 11-28-2010, 03:10 PM   #1026
binlow84
binlow84's Avatar
Drives: '10 Camaro, IBM 2LT/RS
Well darn. With each update that I saw from you guys I could feel the likelihood of my completing this slipping away. I am determined to have it done though, so I guess I'll just have to look around for a shop that can do this locally.
[Insert obligatory car/order info below]
2LT RS; Imperial Blue Metallic w/ Silver Rally Stripes; Gray Leather Interior; Automatic; Exterior Painted Interior Trim Panels; Blue LED Footwell Lighting; Dash ABL; DRL Halos
Ordered - 1/16/10 at Weber Chevrolet in Granite City, IL (Excellent experience; Thanks John!)
Produced - 2/24/10
In the driveway - 3/4/10
Total time order to delivery - 47 days
binlow84 is offline   Reply With Quote
Old 11-28-2010, 03:23 PM   #1027
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Dont let the pics scare you. I am 44 years old and was able to do this job by myself over 2 days.JUst needed a hand removing dash pad from car. All you need is time, a torx set and phillips head screw driver, Oh and the balls to cut up your dash. Take the dash apart in sections and bag your screws for each part. If you got the time and can turn a screw driver your gold.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 11-28-2010, 03:48 PM   #1028
WCoolBreeze
2SS
You have to re-index your windows, relearn tire pressure (4), reset date and time, reset your AM/FM/Sat Radio stations. Cell phone and Homelink I did not have to rest, mainly it seeemed like I had to reset all the personal settings, and this is because of disconnecting the battery, not from actually installing the HUD. Again this MOD is worth all the timde and effort, and it was worth the money, time, and the drive to get it done and I would do it again without any second thoughts. It is not worth trading in your car to get this feature, it is more worth it to keep the car You LOVE and ADD this Feature.
Walt B.
2016 Camaro 2SS
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Old 11-28-2010, 03:55 PM   #1029
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Walt B.
Thanks. I've already started on this..hopefuly I will be done in a couple of days.
Old 11-28-2010, 04:29 PM   #1030
STINGS
Live for On Ramps!
STINGS's Avatar
Drives: 2010 Camaro/2LT/RS/T.F./6M "naomi"
Number 5 is done, so now we have 2 from NJ and 1 from CA and 2 from AZ. Thank you for building the harness Ofer, and thank you Patrick for getting us the parts. Brother got here about 11 so about 3 and 1/2 hours to put it back together. Only had to reindex windows and reset time and date. All radio stations were still there.
Joe
STINGS is offline   Reply With Quote
Old 11-28-2010, 04:35 PM   #1031
STINGS
Live for On Ramps!
STINGS's Avatar
Whats an old fart like you...oh wait I'm 57... "Old Guys Rule"
Joe
Old 11-28-2010, 04:35 PM   #1032
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Hi, the connector has two part's too it, If you look close you will see that the top will come up, that is the lock that holds it place, After that you can put a small flat screwdriver under and it comes up.
Old 11-28-2010, 04:41 PM   #1033
STINGS
Live for On Ramps!
STINGS's Avatar
Here is a picture with the locks in the unlock position.
The passenger side airbag has a lock also, here is a picture of the connector in the unlocked position. When you lying on your back looking up through the glove compartment, you will see this connector mounted to the underside of the dash pad.
These should be the only three connectors that have the extra lock on them.
Old 11-28-2010, 04:52 PM   #1034
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
I can provide labor or if needed parts from this website. I live in Michigan. Been a mechanic at GM Proving Grounds for 22 years. Have a lot of back round in complete teardown and reassemble of GM vehicles. Worked on Meda prep show cars, and teardown and display vehicles. currently work on prototype vehicles in durablity. Contact me if interested. Thanks
lionssfan is offline   Reply With Quote
Old 11-28-2010, 04:57 PM   #1035
SteveDoten
SteveDoten's Avatar
Drives: 2003 Z06
I am the NJ HUD installer, was done on site here in CT
Start posting questions, or pm with ph#, I can get you past the tough spots
USAF F16 wrench paid off on this one
SteveDoten is offline   Reply With Quote
Old 11-28-2010, 05:16 PM   #1036
2SSRS@Gen5diy
Thank you for your help, Guys pm some of the members that have a lot of mechanical back round.
thanks for your help and enjoy your HUD.
Thank you Too for all your help, Pm some of the members that have a lot of mechanical back round, Wee have some good members on the site and we can all get it installed.
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 06-25-2017 10:57 AM
February 2010 Camaro production & sales figures. Tops Mustang for 9th straight month! Tran 5th Gen Camaro SS LS LT General Discussions 52 03-03-2010 10:39 PM
DEALER ONTARIO CANADA WE SHIP ANYWHERE IN CANADA 2010 CAMAROS FOR SALE IN STOCK NOW! dz Dealer Camaros for Sale 0 03-03-2010 06:43 PM
Zex Nitrous System for 2010 Camaro SS @ BMC Performance! Kris@BMCPerformance Forced Induction 2 02-18-2010 07:59 PM
2010 Chevrolet Camaro makes finalist list for 2010 World Car Design of the Year Tran 5th Gen Camaro SS LS LT General Discussions 37 02-17-2010 05:22 PM
