Old 07-08-2010, 01:50 PM   #1
GuidosCamaroSS
Drives: 2010 Black Camaro SS/RS MTX
Fender Rolling question
Has anyone on here have their fenders rolled or flared? If so, how much more does the fender stick out?
GuidosCamaroSS is offline   Reply With Quote
Old 07-08-2010, 02:01 PM   #2
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
There is a thread here about a few "wide bodies". I'll try to find it for you....
Hylton is offline   Reply With Quote
Old 07-08-2010, 02:08 PM   #3
GuidosCamaroSS
Thank you much.
Old 07-08-2010, 02:08 PM   #4
Hylton
Hylton's Avatar
Is this what you have in mind?
http://www.camaro5.com/forums/showthread.php?t=42852
Old 07-08-2010, 03:05 PM   #5
GuidosCamaroSS
Kinda but not the "widebody". Just want to roll the fenders out a bit so my wheels don't stick out.
Old 07-08-2010, 03:33 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
How big did you go?
Old 07-08-2010, 03:36 PM   #7
GuidosCamaroSS
Rear wheels stick out 12mm.
Old 07-09-2010, 01:42 PM   #8
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Rolling your fenders won't move them out. It simply lessens the possibility of your fender lip cutting your tire by bending the inner edge of the fender upward. If you want to cover the tire you will have to flair the fender.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 07-09-2010, 01:50 PM   #9
Spiffyguitar
Spiffyguitar's Avatar
I've rolled fenders in a few car myself before using a baseball bat technique (seriously). The key is to work slow and smooth and not be too aggressive. It won't move your fenders dramatically, but mostly will tuck the inner edge of the fender to keep from rubbing on your tires. If you go too aggressive with rolling the fenders, it can turn out looking like crap.
2010 Camaro 2SS/RS -6M
397whp/393 ft/lbs
Spiffyguitar is offline   Reply With Quote
Old 07-09-2010, 02:10 PM   #10
seddon
seddon's Avatar
Drives: 2017 ZL1
I have also done this on a few cars but the Camaro fenders are already flat. The op states the his wheel stick out 12mm no fender rolling will help that. You might need to pull your fenders or run some negative camber. A body shop should be able to pull that much without charging an arm and a leg.
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
seddon is offline   Reply With Quote
Old 07-09-2010, 05:49 PM   #11
GuidosCamaroSS
Ya I was looking into flaring the fender as well as rolling it because I know rolling it won't affect how far the actual fender sticks out. How is flaring the fender done?
Old 07-09-2010, 05:50 PM   #12
GuidosCamaroSS
I want to flare it enough where I can drop it an inch and not have to worry about tires hitting.
Old 07-09-2010, 06:06 PM   #13
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
http://www.eastwood.com/fender-roller-car-kit-2-pc.html
The link above is to eastwood fender roller should be more than able to do the job I think nineball and friends have used this with great sucess!!!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 07-09-2010, 10:56 PM   #14
bkscott
bkscott's Avatar
I used one on my 4th gen when I put the 315's on the back. Worked great, and did not crack the paint.
Fender Rolling? GuidosCamaroSS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 0 07-08-2010 01:47 PM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
A quick question about pricing. Phaze 2 Camaro Price | Ordering | Tracking | Dealers Discussions 2 03-12-2010 02:01 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
